Wrench question
Wrench question
I want to remove this freehub. My 10mm hex was too small so I ordered a 12, assuming (falsely) that this would have to be it. The 12 is too large.
Does anyone know if this requires a special tool? It is off an older, mid-level, Giant Cypress. It has a Shimano Altrus RD if that matters. Thanks!
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
it's a 12 point inside there, no? will a 7/16 allen work?
Quoted: 4420 Post(s)
Liked 1,568 Times
This sounds like an off brand hub, so it won't accept a Shimano freehub body. So there are very few reaosons to remove it and that might be why it takes a non-standard tool.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Ok, I just ordered the 11mm. I've read the advice to chuck the wrench in my vice and turn the wheel. I just want to verify that this is a normal (RH) thread.
Also, some people say the some hubs have to be turned out from the ND side. If this is the case, would it still be a RH thread? Thanks!
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
and most "non-branded" hubs are made by a company called Formula... They love to swedge freehubs in place because it's cheaper than cutting a twelve point hex into the freehub's I.D.
clean the grease out and take a good look.
Quoted: 5793 Post(s)
Liked 2,593 Times
Yes, it is a RH thread, but that's only half the story and can be misleading. That's because the nut acts from the back to draw the freehub against the shell. So, removintg the freehub means moving the nut deeper into the shell, or turning it to the RIGHT. That might be why some people think you have to work from the opposite side, where you'd be turning to the left as expected.
FB
Chain-L site
FB
Chain-L site
