Inner thread for bottom bracket is useless
Hey everyone.
I need to remove the bottom bracket of this bicycle, but the threads on the right pedal aren't functional. Any ideas on how I can remove it?
Thank you!
Thank you!
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
Read the whole thread, but I think the problem you have so inadequately expressed (what does removing the pedals have to do with anything?) might be answered here: https://www.bikeforums.net/22879514-post20.html
Quoted: 4420 Post(s)
Liked 1,568 Times
If you mean that you can't get the right side of the BB out, are you aware it is usually reverse thread?
Likes For Kontact:
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
I think he means the crank extraction threads are stripped.
/markp
/markp
Quoted: 4212 Post(s)
Liked 3,883 Times
JA Stein makes a tool that oversizes the extractor threads, in the crank arm and it comes with an oversized extractor. Few shops even have one.
Some will slightly loosen the retaining bolt and ride the bike till the arm comes loose. Others have used a gear puller. I have used a hacksaw at an crossing angle to cut a slot that a pry tool can be used to open the arm's fit. I also have removed the LH arm and cup then used a heavy hammer and punch on the axle end to drive it out of the arm. Andy
AndrewRStewart
AndrewRStewart
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
OK cool, thanks for clarifying. when you cannot post pictures, clear communication is key if you want help.
this is probably the single biggest problem with BF in fact - ambiguous language and no pictures to help your friends here understand how we can help you !
Not blaming you in any way ! just stating my opinion
while the JA Stein tool is great, it is expensive for a single use tool if you're not a shop. here's what I would do to address this :
Loosen the crankbolts about 1 turn so they are loose. And then go for an easy ride around the block. A couple hundred yards.
and then you should find that they are loose enough to remove by hand. Maybe try prying with a soft lever like a hammer handle.
This is probably the easiest way to remove them without resorting to pulley removers, wedges, etc.
Good luck and report back
/markp
/markp
Likes For mpetry912:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For dedhed:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
This is a pretty reliable method, but take care to not go too far from home, as you'll want to walk the bike back to avoid damaging the crank arm by riding with it loose.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Stuart Black
Stuart Black
Liked 1,568 Times
Likes For Kontact:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Or use a pickle fork. Just about any auto parts store should have them. No waiting.
Quoted: 1438 Post(s)
Liked 1,092 Times
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Agreed, we have a set of Jacobs wedges for when we are being careful for damage and the pickel fork for full dismantle and salvage ops. (it is already toast)
Liked 4,222 Times
Stuart Black
Stuart Black
SE Wis
Liked 3,401 Times
or Harbor Freight and save a few dollars https://www.harborfreight.com/16-in-...+rod+separator
https://www.autozone.com/tools-and-e...t/loan-a-tools
Liked 1,568 Times
Or you loosen the bolt and ride the bike and need no tools at all.
Bikes: A Janky Schwinn
Quoted: 59 Post(s)
Liked 17 Times
Aluminum expands easily with heat. Use a cheap propane torch on the crank arm for about 30 seconds near the BB but don't heat the BB. Rotate the crank arm to evenly distribute the heat. Then spray penetrating lube into the hole. Then use a mallet on the back and smack it off. Don't be gentle. It will work. The AL will expand and the steel of the BB will not expand leaving room for the penetrating lube to suck in. The heat will suck it in. Basics of removing stuck parts 101. Every single auto or aircraft mechanic knows this. This is basic and bread and butter knowledge.
EDIT: Get the propane torch. It is great for a multitude of things. Making creme brulee, lighting a grill, loosening stuck bolts, etc.
