Tubeless... What would you do?
Quoted: 431 Post(s)
Liked 460 Times
Have ran a set of tubeless tires for a while. Over time, one tire developed a puncture such that anything above 40psi will cause sealant to spray out. It seals at ~20psi but that's too low of a pressure for the tire width and my weight.
So I took the tire off to go back to tubes, but the inside of the tire has a bunch of dried sealant stuck to it. It does come off with effort and patience but I want to devote neither to it as I thought tubeless was supposed to make my life simpler, not more difficult.
So, curious to hear what options there are and what you would do in this situation. Here are a few thoughts that came to mind:
- Toss the tire - it doesn't hold air without leaking down to a too-low psi. This defeats the purpose of going tubeless.
- Patch it from the inside using a tube patch. This requires cleaning out the dried sealant and locating the puncture - not easy to do when the tire isn't mounted to the rim anymore.
- Plug it from the outside with a plug. The issue with this is I'm having a hard time locating the hole if it's not actively spewing out sealant (which it's not, as I've already removed the tire from the rim)
- Clean out the dried sealant and run tubes - is there a hack to this?
- Don't clean out the dried sealant and run tubes - I don't mind the mess or even the potentially lumpy ride, but the thought of those extra single digit grams trigger something in me.
Quoted: 313 Post(s)
Liked 682 Times
Assuming the tyre is in otherwise good condition, I'd spend a little time locating the hole and then patch it from the inside.
If the tyre were still on the rim I'd shove a tubeless plug in the hole to seal it, so the other option is to re-mount it, whack in new sealant, pump it up and find the hole that way, then plug it.
Quoted: 6972 Post(s)
Liked 10,968 Times
Dude, I'm currently running a rear tire with two plugs in it, and it holds air just fine. Instead of pulling the tire, you should've just put in more sealant, pumped it up to 45-50psi, and then jammed in a plug wherever you saw sealant burbling out of it.
Likes For Koyote:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
I did not know that sealant also bonds the plug to the tire!? (As detailed in my other thread, I am a tubeless noob.)
Likes For SoSmellyAir:
Liked 10,968 Times
(Now, this is all in theory, assuming all works properly. Sometimes a hole of cut is too large [you can add a second plug, then], or perhaps there isn't enough sealant in the tire, etc.)
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
I would take the time to find the hole and patch or plug it. The advantages of tubeless are worth it…and tires aren’t cheap.
As for removing the dried sealant, pull off the tire, turn it inside out, and scrub it with a stiff wide brush (commonly found for house-cleaning work). It takes a little work, but again…tires aren’t cheap.
Likes For Eric F:
Quoted: 431 Post(s)
Liked 460 Times
Koyote Eric F tempocyclist thanks for chiming in.
Likes For tFUnK:
In theory the patch is a more sure thing for larger holes, but the hole you describe sounds like one a plug will handle fine. I have actually never needed to resort to a patch in my tubless setup and in fact have seldom even needed to even use plugs despite riding where before going tubeless have to patch tubes very frequently.
Liked 10,968 Times
Yeah, when it first occurred the choices were either as you suggested or put a tube in it. Opted for the tube but was then put off by the mess and the globs of dried sealant. May remount to try this. But may first try to clean out the tire.
Likes For Koyote:
Liked 10,968 Times
That is what I would have done at that point. The times I have done that, it has always worked. Since you have a tube in I might consider mounting it as tubeless again without sealant to find and fix the hole from inside with a patch before adding sealant since it is already dry and you have a tube in it now. Then again I might just take the tube out, add sealant, and plug it.
Likes For Koyote:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Find the hole and patch from inside. A little time spent now will buy months of confident riding.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
So, is there any solvent that will clean the sealant out? Two ounces every couple of months will add up eventually. I just made my bike tubeless so I am curious to what everyone does.
Liked 10,968 Times
More to the point: don't make this harder than it needs to be. You're not adding sealant...You're replacing it as it dries (to an almost weightless residue) and/or gets sprayed from punctures while doing it's job. You don't need to "clean" it out.
Habitual User
Liked 8,098 Times
I have cleaned dried sealant out of tires before, but it's not generally necessary. For the most part, you can just peel it off. A stiff-bristle brush can also be helpful, as can a little bit of water. As Koyote said, using any kind of solvent stronger than water is probably not a good idea.
Likes For Eric F:
Quoted: 313 Post(s)
Liked 682 Times
Warm water, a stiff brush, and your fingers will do the trick. Nothing stronger is required.
Likes For tempocyclist:
Liked 1,471 Times
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I've never removed old sealant. Maybe it's because of my tire choices and the terrain here, but I think my tires would be worn out before enough sealant built up to be noticeable weight-wise. Plus, if you rip the old sealant out, aren't you potentially opening/re-opening porous areas in it again? I know the sealant gets into the teeny holes but it could still get destabilized by pulling all that settled-in gunk out, no?
Likes For pbass:
Cool beans. Thanks Everyone. Water or nothing is what it will be.
Quoted: 431 Post(s)
Liked 460 Times
Likes For tFUnK:
Quoted: 1400 Post(s)
Liked 1,885 Times
I have tires that were previously run tubeless on two bikes
I run tubes (including Aerothan) - so I removed all existing sealant / residue from the inside of the tire and beads before installing the tires with tubes
some of the residue peeled off by hand fairly easily - some residue removal required soap / water with the rough side of a small 3M dish sponge
after all residue removed I applied baby powder to the inside of the tires before mounting
Likes For t2p:
Quoted: 2496 Post(s)
Liked 739 Times
I don't know ... you really think so after this thread and so many others like it? I mean, are y'all's really having fun? My idea of fun ... slapping on a pair of Marathon Plusses and not having to think about anything having to do with tires (except to put some air in whenever you remember) for the next 5 to 7 years ...
Quoted: 431 Post(s)
Liked 460 Times
Then when I'm done with this there's the other tire I've set up tubeless that I need to pull to swap tires. Basically once I get this pair of Conti Terras cleaned up they're going back on the XO2 with TPU tubes. So the Schwalbe G1s currently on the XO2 need to come off (and the rear is set up tubeless with fresh sealant just a few weeks ago 🤦♂️). Not really looking forward to any of it, but it is what it is.
Quoted: 242 Post(s)
Liked 455 Times
Dawn is your friend. We use Dawn in a bucket of warm water and a sponge with a scrubby side to remove dried sealant. A lot will just peel off but this makes is a bit easier.
Patch the hole from the inside.
I'm not sold on tubeless and still use a tube but that is me...you do you.
Liked 10,968 Times
As has been explained, there's no need to remove the dried up old sealant. In other words, you're doing it wrong...That's not an indictment of tubeless.
Likes For Koyote:
