Looking to buy a new gravel bike. Sizing confusion help
I've been riding a 56cm Trek Checkpoint ALR5 for 5 years now and ready to upgrade. I'm a guy who's 6foot (183cm) tall and has an cycling inseam of 80cm. I'm looking to buy a few different brands but they have this sizing system of S,M,L, etc. I'm right in between a M and a L for the bikes/brands I'm looking into. Just not sure which size to buy; and I'm gonna spend a shxtload, around 5 grand on a new bike. Is a M gonna be too small for me? Well, I guess this totally depends on which brand I end up buying. Hmm
BTW, i will get fitted to this new bike as I did for my Trek years ago.
Quoted: 6972 Post(s)
Liked 10,970 Times
I've been riding a 56cm Trek Checkpoint ALR5 for 5 years now and ready to upgrade. I'm a guy who's 6foot (183cm) tall and has an inseam of 80cm. I'm looking to buy a few different brands but they have this sizing system of S,M,L, etc. I'm right in between a M and a L for the bikes/brands I'm looking into. Just not sure which size to buy; and I'm gonna spend a shxtload, around 5 grand on a new bike. Is a M gonna be too small for me? Well, I guess this totally depends on which brand I end up buying. Hmm
Where's the problem?
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
I'm 5'-9" and ride a 53-54. In S/M/L designations, I'm pretty consistently a M. My best guess is that L will probably be the best size for you, but with the amount of money you're spending taking the step to get properly fitted is a good plan.
I appreciate your input, thanks!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,472 Times
When I bought my gravel bike, I found this explanation by Santa Cruz very helpful:
Body Dimension
Not all bodies at a given height are the same. If you have longer legs and a shorter torso than the average person your height, that may push you towards the smaller of the recommended sizes. If you're all torso and arms, most likely you'll want to size up.
Lastly, the height-based size guide is just an approximation. You do not need that as you already have a bike which you have ridden for 5 years. Does it fit you reasonably well? If yes, you can start by comparing the respective geometry numbers of your existing bike and your target bike. Then you can also consider, for example: (1) how your fit has evolved over the course of the 5 years riding your existing bike; (2) existing cockpit setup, e.g., stem length and angle, headset spacers needed, seat post setback, saddle rail clamping spot, etc.; and (3) whether you would like to go a bit lower, higher, more or less stretched out, etc.
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
This website can help: https://geometrygeeks.bike
Likes For Polaris OBark:
Liked 10,970 Times
If your Trek fits well, look up the geometry specs. For the new bike, try to get a close match for the Stack, Reach, and Effective Top Tube numbers. Small tweaks can be accomplished by changing stem length and angle.
Likes For Koyote:
First, is that your pants inseam or your actual cycling inseam? I am guessing the former?
Body Dimension
Body Dimension
that figure is my cycling inseam... thanks for all of the input here, helpful!
Liked 1,472 Times
Hmm ... an 80 cm inseam seems kind of short for someone who is 6 feet tall. The advice from Santa Cruz would suggest that you take the larger of the two sizes you are in between.
Good luck shopping. Which gravel bikes are you looking at?
Likes For SoSmellyAir:
Liked 10,970 Times
I have not heard of Pearson… But at least here in the US, the Lauf gravel bike options are absolutely screaming deals. The prices are extremely reasonable for the quality and build kits. And again – here in the US at least — the return privilege should pretty much eliminate any worries you have about sizing.
Likes For Koyote:
In general I prefer a bike that is slightly too large to one that is slightly too small. I found a number of local bike shops that rented "demo" bikes for a day. Not a cheap rental but it gave me time to evaluate a couple bikes before buying one.
Liked 1,472 Times
The 2019 model year is the earliest Trek Checkpoint ALR5 in Trek's archives: Checkpoint ALR 5 - Trek Bikes
The Lauf Seigla frame has a lower stack:reach ratio, and is longer and lower.
so if my 56cm Trek fits me well I guess i should go with a Lauf Seigla Large, yah? then get a bike fit..
Liked 1,472 Times
No. The 2019 model year would have been released in 2018, so if you had bought it new, then you would have ridden it for about 5 years.
Not necessarily. You have to (1) compare the geometry numbers between the two bikes, especially stack, reach, and effective top tube; (2) evaluate how your current bike is setup, e.g., seat post setback, stem length and angle, spacers under stem, etc.; and (3) consider whether your torso can go lower and longer and your arms can reach lower and further. Although the components under #2 can be changed (e.g., during a bike fit) to compensate for the lower stack:reach ratio of the Seigla and to arrive at close to the same fit between the two bikes (e.g., shorter stem, higher stem angle, more spacers under stem), the result could be ugly and might affect handling.
i really appreciate all of your feedback and help here.. im a total dumbass in all honesty with all of this fitting/sizing ****. and i really dont care to take the time to learn, in all honesty; i just LOVE riding simply.. but i guess i need to take some time to learn at least some of this..
thoughts on these 2 comparisons?:
https://geometrygeeks.bike/compare/l...-5-2018-56-cm/
https://geometrygeeks.bike/compare/t...a-2022-medium/
Liked 1,472 Times
Also, only you and a competent bike fitter can figure out how your body would do on a lower and longer frame. So best to get a bike fit from a competent fitter, preferably one with experience with Lauf Seiglas.
I myself am 188cm and ride Giant Defy M/L with 120mm stem and this fits me very well and according to Giant chart, I should be on XL or at least L.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
It's like riding a bicycle
