Feasibility of this towing idea
Towing a pop-up camping trailer (the kind of trailer normally seen behind cars) behind a trike.
To add a bit of clarity to the picture, I'm thinking of a very small example of said pop-up, that weighs in around 1,000lbs, behind a Worksman PAV3. (The PAV3 has a combined rider and cargo weight limit of 550lbs, I weigh 150lbs and the trailer is likely to have a tongue weight in the 200-250lb range)
Why? Because I'm just a touch crazy. And I hate my legs. Watching the Youtube video of the couple on a tandem pulling an Airstream didn't help matters any.
I figure that I have three major issues with which to deal: steering, acceleration and braking.
As for braking, my thoughts are that placing the hitch forward of the rear axle centerline will reduce the tendency to jackknife under braking, and possibly cause the transverse twisting of the trailer to bear down on the rear wheels, making them more effective during braking.
For acceleration, the PAV3 has 20" wheels, so that's a help right off. I was figuring on either a NuVinci N360 or a Shimano Nexus 8, with 28/22 sprockets. A Rohloff Speedhub would be nice, but it's out of my price range. I'm coming from the derailleur world, and so I'm new to hubs, and I've been unable to find any information regarding the torque limit of either of these hubs. Does anyone know if either of these hubs is capable of the torque that would likely be seen from moving around a combined vehicle weight of around 1,250lbs?
And as for steering, well... I dunno. I'm hoping the steering will be relatively normal.
Anything else I'm missing?
I hadn't thought about aftermarket brakes... That is something I'll have to look into, thanks.
Bikes: 2013 Surly Big Dummy, 2008 Giant Rincon, 1980's Raleigh Century, 1970's Apollo Deelite
One concern for brakes with that kind of weight is over heating them. Which can cause brake fade, or sudden failure.
That is something I would be concerned about if I were to rely merely on the trike's brakes, however, hopperja's suggestion of adding brakes to the trailer has had me searching, and the cheapest brakes I can find that would fit seem to be designed for trailers up to a full ton...
I'd never seen the Scooter Schooner before. From what I've found in a few minutes of googling, it weighs 275 pounds. That weight is feasible behind a bicycle and you wouldn't necessarily need any add on brakes (good disc brakes on the tow bike would probably be needed, though).
I've spent a fair amount of time towing around that amount of weight or even more. On flat ground, I can probably ride 10 to 12 mph consistently for 60 to 90 minutes. After that, I'd probably be considerably slower. On a trike, I'd probably also be slower. Any grade to ride up and that would slow me down a lot too.
Other options that would be lighter:
Tony's Trailers
Kamp Rite Bushtrekka
This one
Several on this page
If you really want to do it, more power to you. Good luck!
Tony's Trailers
This one
I had seen the Bushtrekka, but not having bothered to look for it on Amazon, I hadn't found a place selling it, and assumed it would probably run in the thousands as similar (motorcycle) trailers do.
My original reasoning for going with a full automotive trailer was pricing: I see a few trailers now and then that are in reasonably good shape for <$1k, but this is very competitive.
Bikes: Specialized Hardrock Mountain (Stolen); Giant Seek 2 (Stolen); Diamondback Ascent mid 1980 - 1997
Quoted: 62 Post(s)
In this application, I presume that disc brakes would be better then rim brakes, correct? Also are we talking an "old farts" trike or a Catrike or similar 'bent trike? If we're talking a 'bent trike wouldn't adding a Bionx kit improve things? Maybe even to the supplying the brakes on the trailer with power?
Quoted: 62 Post(s)
Tony's Trailers
This one
Tony's Trailers
This one
Trailer jackknife, when trailer leads the towing vehicle, is an ugly thing..
was in a following van, watching some Coasties (USCG) let the trailered Zodiac
180 & pull them into the ditch on the far side of OR 30.
Bikes: xtracycle, electric recumbent, downtube folder and more
How many feet do you plan on towing this monster? I use a trailer behind my pickup for trash hauling or yard waste and I would never think I could pull 1,000 pounds behind my bike for very far. Find a neighbor who has a utility trailer and load it with some weight and try to tow it even with a rope.
You are better off building a trailer for your needs, using motorcycle trailers as an example. You can use chloroplast plastic, bicycle wheels and honeycomb plywood to make it very light weight.
I'd like electric assist, but I'm not sure if I could handle the extra cost, and whether or not I'd be able to charge any given day.
Bikes: Too many to count
Quoted: 8 Post(s)
I would think a tandem would be the way to go?
https://www.bicycle-riding-for-boomer...-tricycle.html
Quoted: 8 Post(s)
Bikes: 85 botteccia, 85 mcmahn tiatainium, 90 something trek clyde, early 70s schwinn tandem single speed, early 90s gary fisher aquila (the daily rider now!)
Quoted: 11 Post(s)
Liked 18 Times
those links hopperja posted, wow! the bushtrekka is a good looking trailer. the dethleffs looks interesting as well, aloot of sail area there tho.
Disc brakes can overheat, causing the brake fluid to boil. This would result in greatly diminished braking capacity, but not catastrophic like a rim brake failure/blowout would. I've never heard of this happening on a bike, but have heard of it happening on a car. You could also use the biggest rotors available (8 in). The larger diameter will have more surface thus less heat buildup. Look at what downhill racers are using for their preferred set-up.
If brake failure was likely and you couldn't install any trailer brakes, then a set of rim brakes and disc brakes on each wheel, with perhaps even a drum/hub brake would be another (though possibly expensive) option.
You should also be concerned about the strength of the rim/hub/fork/rear triangle that is going to be subjected to extreme braking forces. I know when I have weight on my trailer and I apply the front brake (Hayes 9 hydros), I can see my fork blades (Surly fork) bend backwards.
That being said, I don't see any way either of these failures could really happen. If you are towing that kind of weight (I've towed ~500 pounds myself on my bike), then you are not going to let your speed get out of control on any downhills. You'll keep your speed slow and steady, so as to not cause any prolonged braking applications where the heat has a chance to build up. Alternating front and rear brakes can also help control heat build-up.
As far as hubs, I would think the Nuvinci would be the strongest of the ones your considering. I bet it's as strong or stronger than Rohloff hubs, though substantially more weight.
https://www.eharmony.com/
Sorry, a little rude I know!
Both rim and disc brakes are theoretically susceptible to overheating. With rim brakes, the rim could heat up, thus heating up the air in the inner tube, causing it to expand, and possibly causing a blow-out. I've heard of this as a potential problem with rim brakes, but I've never heard of an actual case, so it could be urban legend.
If disks can be fitted to the trike I'm set on, and it's an affordable option, I will definitely do it.
Quoted: 62 Post(s)
I think it would be considered an old farts trike. Scroll down this page to the PAV3 for a picture.
Because I thought I could
Bikes: November, Trek OCLV, Bianchi Castro Valley commuter
Yes, you are crazy and towing something that outweighs the tow "vehicle" by that much is going to last only until the 1st stop sign you encoutner. Any slight grade could be another ride-ender.
Are you THAT against pitching a tent or hammock? A Bob or Nomad-style trailer and lightweight backpacker-quality tent or hammock will cost MUCH less than any pop-up option, let alone the medical bills and insurance deductible from trying to pull the pop-up.
Quoted: 2338 Post(s)
Liked 2,827 Times
Ok. so is your intent to really go touring, pulling a trailer designed to be pulled by a car
I am guessing that you don't have the bike yet, but that is not 100% clear
Politely put this is quixotic at best...... totally not feasible is more accurate.
Bluntly put: this is stupid and not feasible, don't do it is is dangerous.
First lets look at the bike
https://worksmancycles.com/shopsite_s...html/pav3.html
Look good to excellent for an OFGAB (Old Fart Get around Bike), but I question that it is well suited to touring or longer distances. If you on anything but flat ground you will need some very low gearing.....might have to go rolhoff if it will work. Electric assist may help
This really looks like like round bike and square usage hole deal.
If you are dead set on that bike...get it and try to pull something around of even 500 lbs. You will make your decision very quickly
Then look at all the issues with towing heavy loads. If the trailer ways more than you and your bike or even similar uphill will be torture witout proper gearing and down hill or even stopping from 10 mph is going to be a real safety issue.
creative thinking is good, but this sound like drilling holes in the bottom of a boat to make it lighter so it floats higher.
