Long axle for two wheels
boattail71
Bikes: Too many to list. Raleigh carbon racer (17 lbs.) and fast to a '37 Columbia (17 lbs. wheels alone) Even an Aerocycle (not ridable yet), love the middleweights too.
Quoted: 28 Post(s)
I'd like to costruct a simple trailer; I have a couple of 24" wheels (fronts from old middleweights) that I want to connect to an axle. How can this easily be done?
This may have already been addressed in past threads but I failed to find it in my search.
Thanks for any advice.
Bikes: Trek 800, Free Spirit Town and Country, 80's Norco Nomad
Always good to use google and look up bike trailers, see what works for ideas. I know a lot of kid trailers use 20" wheels, I'm guessing because they're cheap but also low, which is always good on a trailer.
I find the simplest way to make a trailer is to find a used kid trailer and convert it to cargo...the bike hitch is the biggest PITA part to make, but with those, it's already done.
Generally a common axle is not used for a bike trailer. That being said, I converted mine (a former child carrier) to common axle using all-thread from the hardware store. It's so-so, not as good as I'd hoped it would be.
boattail71
Quoted: 28 Post(s)
Ranko. Confused still. How does a threaded rod tie in to the hubs? The threads of the nuts and cones of the hubs do not match the tpi on the all-thread.
The Drive Side is Within
probably best to go in this direction since bicycle wheels "want" to be supported on both sides.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
Quoted: 7350 Post(s)
Liked 2,475 Times
I wonder if you can buy a suitable axle and wheels from Worksman. https://worksmancycles.com
Quoted: 19 Post(s)
Liked 7 Times
You can support bicycle wheels with a stub axle on one side only. This is how wheelchairs and tricycles work. Some bicycles such as recumbents and Cannondale Bad Boy, Giant Halfway use stub axles.
My Y-frame uses wheelchair QR stub axles which slot into holes in a a block of aluminium. The 2x 20" trailer is rated to 90kg.
If you take a front BMX wheel with a rear BMX axle, you probably have enough axle to fix into an aluminium or steel block. Some BMX axles are extra thick for jumps, 14mm rather than 9mm.
Some guy bought off of me 2 front wheels and later 2 front forks for a cart non-bicycle trailer. After a bit I wondered if rear wheels would have been better. Once you pull the freewheel off, there is quite a bit of axle hanging out, remove the lock nut spacer that holds the bearing cone and you've got almost 2 inches hanging out to mount something to. If you shorted up the outside axle since it wasn't going to be connected to anything that would be even more.
with a bearing pressed in the hub, like adult tricycles use so common and relatively cheap
the axle can be running through the hub .
want 1 long axle ? Washers and nuts will locate the wheel where it needs be ..
another classic weld on a washer for theinside limit, another washer and a cotter pin
in a hole through the rod.
Sounds like I was wrong-- I'm just sure that I would make too much of a kludge out of it to try the through-axle thing. My instep trailer has wheels on one side of course.
Bikes: trek fx7.2/trek marlin 6
you can always try gokaart parts
https://www.uscoolsports.com/atv_s_ax...les_s/2034.htm
or try these guys
https://www.equinoxtrailers.com/store/browse
or try these guys
These wheels did not have the cup and cone of typical bicycle wheels, they were press-in bearings that supported a non-threaded rod held together with a C-clip, which then went through two brackets in the frame of the trailer and was secured in such a way as to make the wheels easily removable. (See any child trailer at your LBS/WalMart for a visual example)
boattail71
Quoted: 28 Post(s)
At this point, unless someone has an eureka suggestion, I think I'll build (or recycle) individual forks for each wheel similar to some I've seen in online pics. Although a more complex design, I can then have a lower floor to the trailer which is a good thing. Right?
