Are these monoplanar brakes Chorus or Athena?
Old 11-04-19, 09:11 PM
Mushrooom
Mushrooom's Avatar
Bikes: Vitus 992, Vitus 979, Marinoni Ciclo 1999, Marinoni Fleur de Lys 1979, Fiori Roma
Quoted: 18 Post(s)
Liked 5 Times in 1 Post
Title says it all. I read a lot of stuff about them but still have trouble making the difference between the two. Would be really grateful if someone could help me out.
Here are some pictures:
Mushrooom is offline
Old 11-04-19, 09:16 PM
Chombi1
Chombi1's Avatar
Quoted: 1063 Post(s)
Liked 76 Times in 61 Posts
Uhmmm......those are not monoplanar brakes.....
One of the arms on the caliper needs to go through a slot on the other caliper arm for it to be a monoplanar design. That's what essentially makes monoplanar brakes, different from other side pull brakesets. The stubby, rounded looking caliper ends are the only feature that Campy monoplanars share with this brakeset.
Google "Chorus monoplanar brakes" to see pics of what monoplanar should look like.
BTW, Campagnolo expanded the monoplanar design from the Chorus gruppo to the Athena line after about a couple if years as the Chorus Gruppo only feature. It was the typical trickle down technology practice that Campagnolo did in the late 80's and into the 90's. That's why it is sometimes hard to determine what gruppo some components came from. Campagnolo did revise the caliper arm end shapes on their monoplajars as the moved it down their model lines though. The change wasn't that obvious, and you usually have to have both caliper models next to each other to spot the differences.
Chombi1 is offline
Likes For Chombi1:
Old 11-04-19, 09:26 PM
Mushrooom
Mushrooom's Avatar
Quoted: 18 Post(s)
Ohhh shüt. I get it. I was way off base here!! Do you happen to know what group and/or era these are from?
Old 11-04-19, 09:33 PM
Chombi1
Chombi1's Avatar
Not sure, but it could be early Athena? See my added info above regarding later monoplanar Athenas.
Chombi1 is offline
Old 11-04-19, 09:43 PM
Mushrooom
Mushrooom's Avatar
Quoted: 18 Post(s)
They look very much like Athenas D500, so that must be it... Mine weight ~375g though.
VeloBase.com - Component: Campagnolo D500, Athena
Old 11-05-19, 07:55 AM
Spaghetti Legs
Bikes: Numerous
Quoted: 978 Post(s)
Liked 178 Times in 106 Posts
One difference, which I can’t see in your pictures, between the Chorus and Athena, is the anchor point for the spring. Chorus has a grooved round roller fitting (see the Chorus brakes in the For Sale section) and Athena has a fixed lip.
N = '96 Colnago C40, '04 Wilier Alpe D'Huez, '10 Colnago EPS, '85 Merckx Pro, '89 Merckx Century, '85 Moser, '86 Tommasini Professional, '04 Teschner Aero FX Pro, '05 Alan Carbon Cross, '86 De Rosa Professional, '82 Colnago Super, '95 Gios Compact Pro, '95 Carrera Zeus, '84 Basso Gap, ‘89 Cinelli Supercorsa, ‘83 Bianchi Specialissima, ‘85 Pinarello Record
Spaghetti Legs is offline
Likes For Spaghetti Legs:
Old 11-05-19, 11:36 PM
P!N20
P!N20's Avatar
Quoted: 353 Post(s)
Liked 170 Times in 132 Posts
Yeah I'd agree with that. Although not strictly Monoplaner, they still have the fat arms that made the Monoplaners look cool.
P!N20 is offline
Old 11-06-19, 01:41 AM
Mushrooom
Mushrooom's Avatar
Quoted: 18 Post(s)
They look pretty darn cool if you ask me!
Old 11-06-19, 05:10 AM
Wileyone
Wileyone's Avatar
Quoted: 1141 Post(s)
Liked 79 Times in 60 Posts
:Look cool and weigh a ton.
Wileyone is offline
Old 11-06-19, 08:58 AM
Spaghetti Legs
Bikes: Numerous
Quoted: 978 Post(s)
Old 11-06-19, 09:56 AM
Mushrooom
Mushrooom's Avatar
Quoted: 18 Post(s)
Surprisingly enough, they weight just a little bit more than my 2nd generation chorus calipers. My scale isn't very precise, so don't quote me on that, but I couldn't tell the difference just by holding them in my hands. Here goes them photos:
Old 11-06-19, 11:28 AM
Wileyone
Wileyone's Avatar
On my last "parts bin" build I had the choice between Chorus Mono's and Suntour Cyclone's The Cyclones were almost 50 grams lighter. And had releases on them.
Wileyone is offline
Old 11-06-19, 01:25 PM
SurferRosa
SurferRosa's Avatar
Quoted: 717 Post(s)
Liked 310 Times in 207 Posts
Hey, @mushroom, you probably know this, but an easier way to store these without losing the barrel adjuster is to remove the adjusting nut and then thread it at the bottom after the barrel is inserted in the brake.
SurferRosa is offline
Old 11-06-19, 01:34 PM
Chombi1
Chombi1's Avatar
"Weight weenieism" was definitely not in Campagnolo's design agenda back in the mid to late 80's. My Delta calipers are about twice the weight of my Spidel sidepulls! A lot of their then new slant parallelogram RDs had big solid chunks of aluminum at the pivots that also weighed them down.
Campy rims were also typically heavier than a lot of other rims in the market.
Chombi1 is offline
Old 11-06-19, 01:43 PM
Chombi1
Chombi1's Avatar
One thing I really like about Monoplanars and these similar looking Campy late 80's sidepulls brakes are the steep cantenary arch design of the calipers. They seem to tuck in nicely against the profile of the frame tubes, giving them a nice, modern aero look. Older side pull calipers look "bow legged" in comparison.
Chombi1 is offline
Old 11-06-19, 01:58 PM
SJX426
SJX426's Avatar
Quoted: 538 Post(s)
Liked 63 Times in 48 Posts
One thing I really like about Monoplanars and these similar looking Campy late 89's sidepulls brakes are the steep centenary arch design of the calipers. They seem to tuck in nicely against the profile of the frame tubes, giving them a nice, modern aero look. Older side pull cslipers look "bow legged" in comparison.
I too like the looks of them. In my case the curve of the pad mount arm nearly lines up with the fork crown. the have substance without being overbearing like the Deltas.
P1010581, on Flickr
P1010557, on Flickr
SJX426 is offline
