When should I increase my pedal release tension?
Quoted: 38 Post(s)
Liked 34 Times
I'm new to clipless pedals, and am using an SPD-SL setup. Prior to my first ride, I set the release tension to its lowest setting - as long as I don't start having problems with my shoes spontaneously coming unclipped, is there any reason to ever increase the tension from its lowest setting?
Nope. If your happy on the lowest setting then keep them like that. Iv never accidentally unclipped from mine on there lowest setting. I have 105 pedals.
adjusting the tension means re-learning what it takes to unclip. Increasing your chances of falling over. not worth it really.
Likes For Roobz:
Quoted: 4806 Post(s)
Liked 3,928 Times
I've been riding a long time. I've seen plenty of crashes that started as the foot coming off the pedal, often when the rider has had a scare. If you are going fast, you usually fare a lot better securely on the bike and committed to staying upright. My advice would be to periodically tighten the release a click or two. Little enough that the added resistance won't be more than a momentary scare but such that ultimately it takes a little effort to unclip.
I raced in the days of toestraps pulled tight. We didn't unclip mid-ride very often and we rode through hairy situations. Yes crashes happened, just as they do now. The crashes played out differently. The injuries were different, but not, in general, worse. We lost more skin, I suspect we broke fewer bones. Yes, the gymnasts do better with clipless and their trained falling techniques. But many of the rest of us do better to just stay with the bike and slide. (I'm clumsy. I knew at an early age I had no business learning those falls.)
I ride my clipless pedals cranked tight and yes, I do fall over occasionally. If you accept that you just made a fool of yourself, relax and present the ground with everything you've got, you rarely get more than a small bruise or two. My clothes rarely suffer more than dirt.
Ben
Ben
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
I'd leave them on the lowest click. Like Roobz I've never accidentally unclipped. In fact, there have been a couple of times when I wished I had
Glenn
Glenn
Liked 2,968 Times
tighten more each ride only if you wish to entertain others at random times unintentionally. Want to really provide entertainment? Tighten each pedal to different tensions.
-Oh Hey!
-Oh Hey!
Quoted: 3450 Post(s)
Liked 420 Times
Accidentally unclipping is the only reason why you would want to increase the release tension yet even at the lowest tension SPD-SL's aren't that low. If you have poor technique and twist your foot around as you sprint then you may want to increase tension. If your a MONSTER sprinter off the line you may want to increase the tension.
Quoted: 38 Post(s)
Liked 34 Times
Thanks for the replies - there's some rotational play between my shoes and the pedals, and I wanted to make sure it was just the float in the cleats, and not the pedal retention latch beginning to release the cleats prematurely.
Liked 420 Times
SPD-SL cleats are available with and without float. If your foot does "float" around too much when you sprint then you may want to increase the release tension.
Quoted: 6963 Post(s)
Liked 10,962 Times
The only time I've seen a rider's foot inadvertently come out of an SPD-SL pedal was when the cleat broke. We were just winding up for a town-line sprint, and the guy was up off the saddle, doing 30mph at that point. It was pretty spectacular.
So, yeah, unless you have a high-wattage sprint, you can leave it on the lowest setting. And keep an eye on the wear indicators.
Quoted: 4559 Post(s)
Liked 2,802 Times
I always keep my SPD-SL and Look Delta pedals at the lowest tension and would prefer if it was even lower. I've never unclipped accidentally, even when I'm standing to sprint up short steep climbs and literally pulling the rear wheel an inch off the ground (not a good practice, just poor technique).
If there's enough float it's very unlikely these will unclip accidentally when the feet are normally positioned. It could conceivably happen with zero or low float cleats.
I've seen other folks in local group rides accidentally unclip but they were using other clipless systems.
The most notable incident I can think of was Lance Armstrong at the start of a time trial. Don't recall which clipless system he was using or how much float.
Liked 2,802 Times
Yeah, regarding that cleat breakage thing, be sure to inspect your cleats often and replace them when necessary. I went almost three years before replacing my Look Delta cleats and nearly waited too long. There was barely any tongue left on the left side plastic cleat. That could have been disastrous and seriously painful if it had broken while standing to climb or sprint.
SPD-SL are very similar to Look Delta, but add some grippy rubbery tips that make it easier for walking, but harder -- IMO -- to unclip. Waxing the friction surfaces helped smooth out the clipping/unclipping. I just use leftover candle wax. Doesn't attract grit like oil or grease. And SPD-SL float is slightly less than Look Delta, so I need to adjust a bit when I switch bikes.
Quoted: 896 Post(s)
Liked 2,063 Times
My right foot came unclipped a few weeks ago when I was doing hill repeats. I was full throttle (for what it's worth) and eased up for an instant as I shifted. Evidently twisted just enough to unclip. I kept the rubber side down and on the pavement, but I'm sure it was comical to see. Crotch on the TT, one arm flailing in the air, right foot dragging on the ground, body practically laying on the stem. Somehow kept the thing pointed forward, and let gravity bring me to a stop.
I cranked those suckers down a few notches from the light setting.
YMMV.
YMMV.
Quoted: 365 Post(s)
Liked 419 Times
See, that's the thing with this site. You go into a thread that you think will be stupid (I mean, the answer to the original question seems self-evident), but then you learn a couple of things.
And some of us are just lazy. The pedals on my "work" bike came out of the box very tight, since my ride to work is 5km/3m of low traffic country roads I have never had a problem. The pedals on my "good" bike came out of the box very loose, on my Sunday rides I end up in strange territory or busier urban areas and unclip a lot more. Maybe this is dumb luck or maybe it just proves that a person can adapt to anything.
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
I moved from "rat traps" to Shimano SPD 520's in the late-90's(?). I set them at the lowest setting (to Learn).
I'm still using 520's for several of my bikes and still on the lowest setting. Never unintentional came out of them but there were a few times I was glad they were set low.....
Likes For Speedway2:
When you feel secure enough to not need this forum's approval ?
Time ATAC had no adjustment other than which cleat went on which shoe.
Quoted: 325 Post(s)
Liked 109 Times
With Shimano SpD MTB pedals the cheap ones release easily and are pretty difficult to get into. The high performance pedals are exactly the opposite - they are easy to enter and damned hard to release. After you are experienced enough to automatically release without thinking about it, you can change. The most common cause of mishaps with clipless users is not being able to get out in time. to put a foot down and avoid a fall.
