Well, that was a learning experience
old newbie
Bikes: Specialized Roubaix
Liked 508 Times
I finally got out to ride today. The path around a local lake has a lot of up and down, sharp curves and several humped bridges with posts at each end and 90* turned before or after. It isn’t a place for high average speed but it’s close. It’s a good 6 mile loop.
There is a climb near the end no matter which direction you ride but one direction the climb is a little steeper. I did one lap in each direction and save the steep climb for last. I was getting a little tired and wasn’t thinking about anything but getting close to finishing. That climb hit me hard and I had to walk it up the last 50-60 yards. When I got to the top and got on my bike I realized that I had left the front derailleur on the big ring. I have been leaving it in the high range and it’s no problem going the other direction but this direction definitely needs the lower gear range.
Betcha I remember next time. 😎
Likes For pepperbelly:
Liked 5,404 Times
In a month or so of regular riding, you'll be able to do it with no issue in the big ring. It's supposed to rain here for the next few days.
Likes For Iride01:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Liked 830 Times
One guy just started riding a couple years ago, and he laughs at the hills now. He says he thought they were mountains when he started.
Likes For andrewclaus:
Liked 2,398 Times
There was a cycling pro in the 80’s, Sean Kelly or Stephen Roche, or somebody, who was known for his climbing skills, was asked his secret to ascending - “I put it in the big ring and spin”. Or something to that effect.
Likes For Steve B.:
Liked 3,020 Times
Yeah, it's a nice surprise and boost to the ego to realize you've been in a higher gear than you thought. It's happened to me.
Likes For noglider:
old newbie
Liked 508 Times
I used to ride in the small ring. Either way I tend to cross chain. The lake trail I ride has me constantly changing gears.
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Liked 103 Times
When I were a lad, about 65 years ago, it was considered a bit wimpy to get out of the big 52T ring while riding in hilly SW England. We rode 52/42 with a 6 speed rear cluster (no cassettes then). In winter we converted to fixed, usually 69 gear inches or 82 for 25 mile out and back hilly TTs. I never broke the one hour; best was 65 minutes (with asthma for company😊.
Nowadays I’m not ashamed to use a bit of e-assist, usually 50W, to get me and my failing lungs up from 12 mph to 15.
Liked 3,680 Times
the only ppl that don't make mistakes are ppl that don't do anything
Likes For rumrunn6:
OM boy
Adding a sizable distance length to your 'normal' ride distance is always accomplished with less grinding of teeth, with judicious use of all your gearing.
This may not apply in Florida or anything flatter - until you have to bore for miles on end into a 12+ mph headwind...
That said, 'Big Gear' Intervals (note I haven't said Big Ring) are great in the tool bag of a time/mileage constrained rider...
Ride On
Yuri
Likes For cyclezen:
old newbie
Liked 508 Times
All fine and dandy if you're riding solo all the time. If at any time you're riding in a more 'sportive' group, versatility in gearing becomes a must.
Ride On
Yuri
Ride On
Yuri
My bike is a 2013 Specialized Roubaix Comp. I have no idea how it’s gearing compares to other bikes. I do know it has 2 gears that are almost the same.
Bikes: 2018 Specialized Allez Sprint Comp (main ride); older Trek 820 Mountain Track (commuter); 2012 Specialized Tarmac (project)
Liked 629 Times
Every week I meet a small group of senior men (70 +/-) for two laps of the 8 mile scenic loop at Saguaro NP. There are some 8% grades, one of them long. There's usually one guy who forgets to downshift, and everyone laughs.
Likes For Duragrouch:
Watching the current Giro. During the time trial, 42 kms with a steep hill at the end, one of the riders had a single 66 tooth chain ring. Wonder what the biggest 11-?? cassette is.
Might make no front derailleur more interesting, maybe.
Seat Sniffer
Liked 2,226 Times
Likes For Biker395:
just another gosling
Liked 2,099 Times
Our tandem has a 40T in back and of course I can't see the chainrings. Several times that's happened to me, partly because when one is running a big cassette, the g.i. are closer together at the big end of the cassette when in the big ring than when in the middle ring at similar g.i. I expect that is also true for those running 1X.
Cross-chaining hasn't been a big deal for the last couple of decades.
Results matter
Results matter
Likes For Carbonfiberboy:
Grupetto Bob
Bikes: Bikey McBike Face
Liked 6,612 Times
If/when you fitness improves, it is quite satisfying to climb a hill in the big chain ring, where in the past, it had to be small ring. A good feeling of accomplishment and improved fitness.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
If it was an Ineos rider (probably Geraint Thomas, because he's a top GC contender and a strong time trial rider and so would get a lot of attention in a TT), he had a two-speed Classified PowerShift rear hub, which gives the rider 1.0 and 0.7 gear ratios with any rear sprocket. It's a wirelessly controlled substitute for a front derailleur setup.
Likes For Trakhak:
Liked 830 Times
...Or a nicer bike. I just traded in a heavy aluminum gravel bike for a lighter aluminum gravel bike, identical gearing and geometry, and on its first climb up Lookout Mt in Golden, I was nearly to the top when I noticed I was still in the big ring.
Grupetto Bob
Liked 6,612 Times
What a fantastic surprise. Lighter bike + more fitness = good times!
Likes For rsbob:
