V brake upgrade for Tern Node
I've had my Tern Node D7i for over a year now. My biggest frustration has been with the V-brakes, there's a not a lot of distance of travel for the pads so they easily rub against the rim or the balloon style tires unless the adjustment is perfect. They are also easily thrown out of adjustment because of the folding process.
They are just generic brand brakes, what are my upgrade options?
Quoted: 980 Post(s)
Liked 582 Times
Consider yourself lucky: it's worse with smaller diameter wheels!
As for the brakes being affected by folding, I've found that keeping the pivots for the brake arms well lubricated helps. When they're freely moving, the only thing that's likely to make them out of balance is the position of the cables after unfolding the bike. If you can make sure the cables return to the same place after the bike is unfolded, I think you'll have less problem with this.
The brakes on your bike, though generic, are probably fine. You can certainly upgrade them, but as I've said, the main issue is the relatively large discrepancy between the tires and rims. Only wider rims or narrower tires will help.
Steve
The thing on my tail
Bikes: TERN Node 8, Fuji Oragami , Durban Street 24
Ive used some thin koolpads on mine... works pretty well.... the cartridge models.
Bikes: to many
Quoted: 213 Post(s)
curse of v brakes ... little travel at brake long travel at lever ..that's what makes them strong.
on smaller wheels a good shorter than usual pad will help on the Node it is what it is
same as all other bikes. Nothing different on the node than any other bike in that regards
different v brakes .. yeah there are better ones, but all work the same
Quoted: 980 Post(s)
Liked 582 Times
Steve
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
Koolstop thinline have worked excellently for me. I used them with my tektro brakes and just recently went to Avid single digits and they work well with the thinlines also.
Upgrade: Magura hydrostop hydraulic rim brakes mount on V brake posts..
HS 11, 22 & 33.
other than that cable V brakes are Levers, longer lever , more power, but the gap to the rim has to be narrower as a direct result of the increased leverage.
longer caliper lever demands more cable pull , so hand leaver has proportionately lower mechanical advantage to pull more cable.
HS 11, 22 & 33.
Liked 374 Times
After a year or so I sold the e-bike to another recent retiree who wanted to start riding again and I've been on regular bikes ever since. E-bikes are gateway vehicles to regular bikes. However, I'm weird in that I've always like to tinker (built computers in the 70's, etc.).
Quoted: 317 Post(s)
Awww ..... when I retired I had been commuting by car and was soooooo sick of driving, I couldn't bear driving anymore. I put around 800 miles a year on my car now. I got my son (29 yo) into cycling and now he rides a Jamis and has no car, lol. I started out with an e-bike because I had all those insecurities about getting stranded, etc. Have you talked to your mom about using an e-bike on a MUP away from traffic? Maybe rent one? Sell it as an opportunity to spend time with you, include a very nice lunch stop in the deal =). Maybe having a hobby to share with you will be a good enticement.
About the tinkering you are wrong. It is the gals who are NOT tinkering that are weird- not us
