How do body comp scales interpret glycogen?
Newbie racer
Bikes: Propel, red is faster
Quoted: 1091 Post(s)
Liked 874 Times
This is just for pure curiosity. I don't think you can do anything with this. But I'll get to that. I have a Withings and it gives weight and % water, % fat, % bone, % muscle.
Alright. A big contributor to day to day weight swing is water and glycogen usage and storage. I'm curious how something like a Withings interprets liver and muscle glycogen. Will that fall under water weight, muscle, or fat. I can rule out bone as bone % stays identical on every reading, as I would hope it to!
I weigh sometimes after a workout. Just notice the % for water doesn't do what I'd expect. I simply rehydrate after workouts as necessary without a scale. So wouldn't change that, just curious.
Hits [ENTER] b4 thinking
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 2473 Post(s)
Liked 1,163 Times
Mostly they guess. It's not something that can be directly measured. Your weight is about the only thing that it can tell you as result of direct measure. Everything else is a result of some indirect measurement and comparing that to some study of what it was for a group of people that may not be you.
Typically it's accurate to some degree. But leaves lots of room for argument if you are going to compare your results with another.
just another gosling
Quoted: 2904 Post(s)
Liked 810 Times
I have a similar scale. I notice that the day after maybe a 2 hour workout, if I did not adequately replace carbs, my weight the next morning is down by a pound or so. If I do have an after-workout carb drink, my weight doesn't change as much, maybe down by .2. I assume that most of that weight change difference is due to glycogen replacement, i.e. mostly water. My water percent bounces around so much that I confess I haven't paid too much attention to it. I think my muscle percent is more reflective of my glycogen balance.
I only pay close attention to my scale numbers when I weigh myself first thing in the morning. If I weigh myself later in the day, all my numbers are different, especially my muscle number will be way up. Maybe more blood in the muscles increases the scale number? I don't bother weighing myself before and after a workout.
Tell you what . . .I'm doing a somewhat glycogen-depleting workout this morning. I'll weigh myself naked before and after, before my "after" drink, and post the results.
One can't compare one's numbers with anyone else's, but comparing the changes in numbers might be interesting.
Results matter
Results matter
Newbie racer
Liked 874 Times
I've had some instances of workouts where the fat % drops a solid 1 to 1.5% and the water % goes up by 1 to 1.5% while my bone and muscle isn't too changed. Was just curious about that.
I really just pay attention to the trend line in their app. If that's where I want to be. Making sure fat % and muscle % go the desired directions. Overall weight doesn't bother me too much as I'm not a pro.
I got the scale because of knowing about how water weight can toss your perception, and because from Nov thru Dec I drank a ton of red wine and had a lot of pastries with my coffees. So put on a bit of fat.
Liked 810 Times
I've noticed roughly the same. I was assuming the glycogen was wrapped up in the water %.
I was doing a 16' warmup, a 20' 53 rpm interval at 95% FTP but below AeT, and then a 10' cool down. During the 60% FTP normal cadence cool-down, it was like, "Where'd the chain go? Or is my PM broken?"
Results matter
Results matter
Likes For Carbonfiberboy:
Newbie racer
Liked 874 Times
I actually weighed my normal mid-later day weight after a ravaging 1:20 on the TT bike on Tuesday. But, my water % on the scale had gone WAY up. Then after a lot of pee that evening and a solid night time pee, the weight during my normal after breakfast weigh in the next morning was down. Water weight % back to normal. But, glycogen not likely restored yet as I am NOT a big breakfast person any longer.
Some yogurt and a black coffee if I'm not riding early in the day. I simply found the "eat now so you don't eat a lot later" did not work for me. If I ate a good breakfast just to go sit at work, I still would eat the same lunch, same dinner, same evening snack with Netflix.
So, unless I'm riding early day I don't do the whole "nice breakfast" any longer. It wound up just being about 300cal a day of "filler".
Liked 810 Times
I think this got it.
Results matter
Results matter
Liked 1,163 Times
These scales essentially just run an electric current through you and measure the resistance don't they? Maybe some passive electrical too.
I've wondered how much moist feet one day versus dry feet another day change readings. However even though I have a scale that does similar stuff, I tired of using those functions long ago and never got interested enough again to try out the moist vs dry feet thing. I just use the scale to weigh.
Maybe even one moist and one dry to throw another twist at it?
Understand I'm not discounting how accurate they may be, but like a lot of other things they are relying on generalizations from indirect measurements.
Bikes: Shmikes
Quoted: 5933 Post(s)
Liked 2,626 Times
Incidentally, you don't necessarily pee out the water bound in glycogen, nor the water formed in the metabolism of carbohydrate to water and CO2. It goes into the plasma just like any water you drink and if you're working out, it leaves the body as sweat and respiratory water as much as urine.
Likes For MoAlpha:
Liked 810 Times
Yes. Each of these components has a known conductivity and I'm pretty sure the body is modeled as a set of parallel impedances. I'd be willing to bet that glycogen content doesn't affect the conductivity of muscle much.
Water content changes muscle conductivity. My muscle percent between when I get up and later in the day goes up 1 or 2 percent. Similarly after exercise and my thighs are still pumped, it also goes up. However if I don't recover the lost glycogen, the next mourning my muscle percent number will have gone down 1 or 2 percent from the previous morning as well as my weight dropping 1 - 1.5 lbs.. I doubt that's from dehydration since I pee a few times in the night no matter what. OTOH if I do recover the glycogen, neither my morning weight nor muscle percent will have changed. It helps to have paid attention to one of these scales for many years. Whether that's glycogen being measured or simply the water content of the glycogen really doesn't matter. It does get measured.
Results matter
Results matter
Bikes: Shmikes
Liked 2,626 Times
https://tanita.eu/body-composition-scales/
Bikes: Shmikes
Liked 2,626 Times
Liked 810 Times
OTOH, if you want to know how one can tell exactly how many calories/kg of glycogen, both muscle and liver, one has on board, I don't think one can without doing some very specific and rather odd workout(s). There was that old thing about glycogen depletion as part of a glycogen maxing effort before an event, but even then, one wouldn't really know, too much other stuff gets in the way. However, since some of us do have body comp scales, one could look at one's weight and body comp which one had before an exceptionally good ride and try to duplicate that. And in fact, that's what one does. I think that's what the OP was wishing to discuss.
Results matter
Results matter
Bikes: Shmikes
Liked 2,626 Times
Well, one can tell one's low on glycogen if one just can't move the bike normally - assuming there's no other good reason, like lack of recent exercise or really sore muscles on the bike. Glycogen synthesis normally varies with quantity of carbs ingested, though when on a carb-restricted diet, gluconeogenesis will occur to some extent. As that banana's guy says, "Carb the F up!"
Liked 810 Times
I see. It's simply having a strong ride, for which the forecast is having normal numbers on the scale in the morning. Learned correlation. A long time ago, I tried to do a 40 mile moderate pace "recovery ride" after a particularly hard ride the day before. That's the only time I ever had a liver glycogen bonk. I thought I did well to make it home alive. So that's the limiter on the other end. I didn't have the scale then.
Results matter
Results matter
Bikes: Shmikes
Liked 2,626 Times
These types of scales are not really made for giving good quality snapshot numbers. The technology behind them is not that accurate. As has been mentioned above, they send a current through your body and measure resistance. Differences in resistance are due to water content in the body. Muscle has more water then fat. So a higher water percentage equates to more muscle mass. The calculations also use height (don't give yourself two extra inches like in your Tinder profile
), and - I think - age. So the scales measure two things: weight & electrical resistance. All of the other numbers the scales give you are just the results math formulas.
Some of the detailed numbers and analysis mentioned in this thread above are difficult to get in a laboratory much less from a $100 bathroom scale.
Any one single measurement on any of these scales is pretty much worthless if you are expecting accurate numbers. And comparing numbers between just-rolled-out-of-bed and right after hard workouts on the same day may be interesting but is not what these scales are designed to do. I did some research about getting a scale last year and everything I read suggested taking your weight at the same time every day and the best time to do that is when you wake up, after emptying your system, and before eating or drinking anything. Due to the six to eight hours of sleep and fasting that will give a more consistent measurement from day-to-day. Waiting until later in the day will likely skew results based on what you've eaten & drunk and what exercise or other activities you've done each day.
Does that make these scales a waste of money? Not at all. Over time you'll see trends in the numbers to help see if your fitness and health plans are working. Maybe you are trying to lose, maintain or gain weight, or trying to get more lean, or adding muscle mass at a faster rate than fat mass. Over the course of several weeks the numbers from these scales should show the trend. Personally, I use my scale every morning I'm at home and log the numbers in a spreadsheet. I also keep a seven day rolling average of those numbers and pay most attention to the trend of those 7 day averages.
Having dropped 48 pounds since Jan 1, 2020 (based on seven day rolling averages of course) the numbers and trends from my scale have been additional confirmation that my exercise and diet plans are working. That's in addition to how my clothes fit, blood pressure, my performance biking, running, lifting weights, and just looking in the mirror. I don't care if the fat or muscle ##s the scale gives me are spot on accurate this morning. But I can see that they've changed in the right direction compared to two months ago. And by looking at the rolling averages I can see whether I've been consistent or jumping around over time (happy to say I'm usually consistent although there was a definite blip following my birthday weekend earlier this month
Likes For telebianchi:
