Stretching
Stretching
OK, with the colder weather I'm stiffening up about 30 minutes after my ride. I don't mind this too much but I'm getting a pain right where the hamstring joins the glute (right below my butt). This really hurts and I can't seem to stretch it out to loosen up. Anyone got any suggestions.
Guest
Posts: n/a
Quoted: Post(s)
Sounds like the periformis muscle. If you're not careful and it gets too stiff, you could end up with some back pain.
I hope this is descriptive for you.
Lay on the floor. Raise the left leg and bend. Then raise the right leg and place the right foot on the left knee. Slowly bend the left leg in towards the torso and hold. Then reverse for the right leg.
Alternatively (or additionally), you could do it standing. You'd still bend the left leg, then lift the right leg and place the right foot on the left knee. Then sink down, bending the left leg even lower and deepen the stretch.
You may want to get the book called "Stretching" by Bob Anderson. It is the best book out there I've ever seen that goes through stretching every muscle group, has illustrations, and gives progressive stretches, so you can start with very little flexibility, and over time, you can build to more advanced stretching.
I hope this helps.
Koffee
I hope this helps.
Koffee
Cheers!
Bikes: Scott Addict R15, Cadd 9
Doing plenty of stretching before hand is vital. My hamstrings will tighten up on really hard rides. Stretching them before and after is vital.
Bikes: Giant OCR 2, Flyte SRS 2
I just turn on the seat heaters in my car the next morning. It is the only way I can tolerate the ride to work.
KL
KL
I hope this helps.
Koffee
I hope this helps.
Koffee
Thank you for the suggestion.
George
Guest
Posts: n/a
Quoted: Post(s)
Very cool. When I moved, it was one of the few books I kept. I donated and gave away quite a few books but never once considered giving up the stretching book. It is easily found on amazon.com and barnesandnoble.com too.
Koffee
Koffee
By-Tor...or the Snow Dog?
Bikes: Bianchi Cross Concept, Flyte Srs-3
Koffee
Koffee
seated on the floor both legs out stretched and flat on the ground... bend one of your legs so your knee is up to your chest. lift the foot of the bent leg over the other leg... your heel should be on the floor and on the outside of your hip. take both of your hands and basically hug your bent leg and squeeze it into your chest... this will stretch the area you are talking about.
