A very personal question
My husband recently bought me a road bike. Until then I had ridden a Comfort Bike. I am 44 and a bit overweight. I could ride up to 16 miles per ride on the Comfort Bike but after about 6 miles on the Road Bike, my (can I say cl!toris?) hurts and even has a burning sensation. He took me for a $75.00 professional fit but that did not help alot. Is there something I can do? I really want to ride with him but I hold him back too bad when I'm on my Comfort Bike. He has tried tilting the seat down for me but it helped little.Is there a different saddle?
Cycle for life...
Bikes: Trek 5200 | Cannondale Six13 TeamOne | Cannondale Road Tandem | Cannondale Prophet 3 "Lefty"
Quoted: 22 Post(s)
Assuming this is not a troll , you are most likely going to be taken seriously and have a more appropriate audience if you post at: Team Estrogen Discussion Forum
-\Brian
18' Landshark Tandem - Custom
15' Wabi Special Single-Speed Road
06' Cannondale Six13 TeamOne
06' Cannondale Prophet 3 "Lefty"
92' Trek 5200
-\Brian
92' Trek 5200
Guinea Hood
if you click the 'search the forums' link at the top of any page and search on keywords like 'saddle women' you likely will find a lot of good info...
you might need to use a different saddle. or, if it's a fit issue, i'd go back to the place that did the $75 fit and have them keep trying?
good luck!
good luck!
Tom Hagen: 'Thank you for the dinner and a very pleasant evening. If your car could take me to the airport - Mr. Corleone is a man who insists on hearing bad news immediately.'
try a saddle where the center section is open. Try tilting the saddle nose up just a little. This will help tilt your pelvis so you are sitting on your seat bones. That will take the pressure off the other more tender areas.
My wife will only use women's saddles.... she likes Terry and Specialized. I tried to build her a cheapo beater commuter to go with her road bike, but she still insisted on a proper woman's saddle (rather than any of a number I had lying around).
Bikes: 2001 Look KG 241, 1989 Specialized Stump Jumper Comp, 1986 Gatane Performanc
Common complaint. Don't tilt the nose of the saddle down, tip it up slightly. You want to sit on the back of the saddle (wide part).
Finding the 'right' saddle may mean trying about 10 saddles! Plus, there is a break-in period for you sitting area. It takes some time!
Try to get on the bike at least 3 times a week, even if you only ride around the block for 30 minutes or use a trainer.
Gravity Is Yer Friend
Location: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
If you have already played with the seat position/height, type of seat and the reach to the bars I would say take a look at the shorts you are wearing. If there is a seam down the middle then that can very well be the culprit. Even some women specific shorts have a seam there just not on the chamois. Also, are you wearing your shorts commando style (no panties)? If not you should give that a try.
Also check out the Team Estrogen site as woodcycl suggested.
DBD
DBD
A/K/A "Alpha Male"
Bikes: 2005 Trek 1200 (Upgraded)
Wonder where you can get a job fitting for Ladies Saddles? How could you tell? That seems like a very personal area and the fitting should be guided by the "fittee" and not the "fitter"
Orbea Crayola Rider
Bikes: '05 Orbea Onix
you could pm koffee brown (a moderator on here) and talk to her about it. She can point you in the direction you need to go (ie...womens only forum).
mscycler
mscycler
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
Wow, did you ever see so many embarassed men?
Here's the story: EVERYONE has trouble finding the correct saddle for their particular build. Some have a little trouble and some like myself have a great deal of trouble at first.
You need to try various saddles until you find one that works for you. This might turn out to be a long search expensive or it might work on the first try. But there IS a saddle that can work for you so don't dismay.
The suggestions for the various women's sites aren't bad but you're hardly likely to find any better advice in practical terms.
Here's some saddles I'd recommend for a beginner woman:
Terry Butterfly (around $110)
Specialized Dolce (~$90)
Specialized Body Geometry Sport (~$60)
Selle San Marco Atola (~$80)
There are other saddles. Be aware that only 20% of women need "women's specific" saddles. Also understand that often the problem with a saddle is that it is too soft and squishes up and puts pressure in undesired locations. So a harder saddle actually works better though you might be sore until you harden up around your sit bones.
But a saddle is supposed to support your sit bones and not put pressure anywhere else. Having a sore butt around your sit bones will likely go away with practice but pain in your private areas most certainly will not and should NOT be tolerated since it can lead to all sorts of other problems.
along with finding the right saddle and saddle position, my other half uses some cycling specific undies that she claims makes her a lot more comfortable.
You may want to try a Terry Butterfly saddle, or how about taking the saddle off your comfort bike and giving that a try?
Also, have you tried wearing a pair of padded biking shorts?
Sometimes, there's also just a break in period. You may want to try short rides, of say, 5 miles a day for a while until your body adjusts.
The saddle on my bike is one of the cheapest you can buy on the market. I have to wonder whether the reason I never had any problem with soreness, or adjustment period is because I cross-train -- lots of yoga, light weight training, step aerobics, etc. Maybe some good yoga stretches before riding might be helpful.
My girlfriend is riding the Specialized Jett saddle now and loves it. She had a Dolce before and it was too padded. The Jett is basically a Women's version of the Alias.
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
El Diablo
Bikes: Cannondale CAAD8/Record 10s, Felt DA700 Chorus 10s,
Yeah what he said. After 7 different saddles my wife has finally found a saddle/position that she is comfortable with. Even still she doesn't get on the bike (our tandem) enough to really get used to, like Galen said it takes time.
Campy Neutrons for sale!
https://www.bikeforums.net/showthread...86#post2464586
HAC4 for sale!
https://www.bikeforums.net/showthread...83#post2478083
HAC4 for sale!
fredelicious mini-masher
Bikes: Specialized Ruby
This was me a year ago! It HURT...and I changed saddles around, and didn't help much. What changed eventually, was my body - down there. Seriously. It 'tightened' up (I'm middle aged and bore two kids) so it wasn't so, um, low, and I got more comfortable on a saddle. No, sensations are the same , but it's like internal organs and such tightened up with all the exercise and 'jarring around' on a bike, as well as eventually losing 20# from all the road time.
Try other saddles too, that put your weight on your sit bones, but that's just been my experience. (okay guys, you can come back now )
Dolce far niente
Quoted: 20 Post(s)
Liked 17 Times
Ummm.... we never left.....
"Love is not the dying moan of a distant violin, it’s the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
Extreme nutter
Bikes: Scott AFD expert, with some carbon upgrades.
try strengthen you core up abit. i mean te deaper adominal muscles. try something like pilate's, helps maintain and improve you posture on the bike.
Plus try out a few saddle types.
pan y agua
Quoted: 1456 Post(s)
Liked 733 Times
Ditto on trying different seats such as terry. Have you tried putting the seat from your "comfort" bike on the new bike?
Also, try standing up from time to time.
Bikes: 1999 Seven Sola, 2004 Bianchi Axis, 2005 Trek Madone 5.2 SL, 2006 Merlin Works CR 3/2.5, 2009 Kona Ute, Spot Acme, 2017 Raleigh Roker Comp, 2016 Specialized Camber Expert 29
Wife went through a few saddles a while back, even a Terry, before she settled on a WTB. She was ready to switch out the Specialized Alias seat on her new Tarmac for the old WTB since the Alias seat looks pretty minimal, but after a 20-mile first ride with the Tarmac and the Alias seat, she says the cutout works for her. Try some different saddles, work on your position, and hopefully, you should find something that will work for you.
Bikes: Time RXRS, Specialized Stumpjumper FSR
I think, as for us men, you have to look for a saddle that is wide enough for your seatbones and not too soft. Women saddles should take care of the width because that's their primary difference with regular saddles. Some men saddles might work too as long as they are wide enough and relatively flat when watched from behind.
The Gel thing sounds very nice on paper but experience on long rides will prove the contrary. After a while the seatbones go through the gel that pushes upward and starts pressing on the soft tissues resulting in pain, numbness, and more annoying consequences.
The cutouts work well on hard saddles. If the saddle has gel the cutout will be clogged by the gel after a while.
Check the other links regarding saddle comfort, they have a lot of info and you help you. Make also sure that you have a good pair of shorts, a quality chamois makes a big difference.
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
Quoted: 138 Post(s)
Liked 12 Times
My wife also had this issue until we got her a womens specific design saddle. After a butt fitting at our local SPecialized dealer we got her a Specialized Dolce and she said this is MUCH more comfortable...no pain anymore.
The views expressed by this poster do not reflect the views of BikeForums.net.
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
two words
Brooks
Keegles (sp?)
seriously.
What Galen said was spot on, that and
the above seemed to help my wife who can now
do a metric century without discomfort.
marty
Brooks
Keegles (sp?)
seriously.
marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Please didcuss your dificulties/ desires with Andy Muzi at https://www.yellowjersy.org or 608 257-4737. They will let you try/exchange saddles until you are satisfied. My wife and I ended up with a book box of saddles until we found the "right" saddles. My 56 year old wife experienced similar symptoms with about 7 diferent saddles and now has a Brooks Finesse on all 3 (2 road & 1 Hybrid) bicycles. Brooks Saddles are a bit expensive, but less expensive than a new bicycle not ridden/enjoyed due to severe discomfort.
