what kind of stir fry oil is healthiest and/or tastes best
What kind and how much do you use?
I have been using peanut, olive and sesame.
I noticed "wok oil" is cottonseed oil.
Comedian Bill Hicks once said, "Money can't buy happiness, but it can buy a jet ski, and you never see an unhappy person riding a jet ski."
Lost in the Black Hills
Tomac Mountain Bikes | Light-Bikes l Magura USA | Industry Nine | Schwalbe Tires | Caffélatex
Originally Posted by mx_599
crisco
nope, not for me, thanks.
Olive oil that has been filtered, extra light olive oil, has a higher smoke point than peanut oil, but the best way to determine if the oil is hot enough is to put a small piece of garlic or onion in the oil when the oil is cold to watch and see when it starts to fry; then it is hot enough to add the rest of your stir fry in. Don't let oil get to the smoke point. It is already starting to degrade at that temperature.
Bikes: bianchi boron xl, kona explosif, kona unit, khs comp tandem
try macadamia nut oil. it's supposed to be just as good for you as olive oil, but has a
higher smoke point. i have used peanut oil also-it is used alot in chinese cooking.
steve
steve
Guest
Posts: n/a
Quoted: Post(s)
A recent study someone emailed me out of San Francisco said that prostate cancer growth in vitro was twice as fast when oils high in Omega 6 fatty acids were added to the mix. For men, I would say to avoid stuff like corn, canola, and vegetable oils and look towards olive and flaxseed oils and other oils high in Omega 3 fatty acids.
Disturbing stuff. My dad has prostate cancer, and it's suddenly skyrocketed, so we've moved him into foods high in Omega 3 fatty acids and completely weaned out foods with Omega 6 fatty acids.
Koffee
Koffee
Bikes: Cervelo Prodigy
Quoted: 402 Post(s)
Liked 43 Times
The Flax Council of Canada has a pamphlet on flaxseed. According to their information the fat composition of flaxeed oil are as follows: Polyunsaturated fats 73% of which 57% is Omega-3 and 16% is Omega-6; saturated fats 9%; monosaturated fats 18%.
Bikes: Vintage Jim Merz
i use a mix of sesame oil and hot chili oil, which has soybean oil in it. if i need more, i use peanut.
i tend, though, to use oil primarily for flavor. if you use nonstick cookware, you need very little oil.
Quoted: 2873 Post(s)
Liked 333 Times
Cottonseed oil and soy oil are the worst options. Cotton is classified as a non-food crop so more pesticides can be used on it than on "food" crops but then pesticides concentrate in the seeds and we use that for "food". Real cleaver! Don't start me on Soy.
While I'm all for omega-3 fatty acids they don't make for good cooking oils. Unrefined coconut oil is the healthiest option being the most heat tolerent but peanut oil with seasame oil for flavor isn't the worst option out there.
Regards, Anthony
Quoted: 402 Post(s)
Liked 43 Times
Stir fry is most associated with Chinese cooking. Depending on what is to be cooked, the wok is fired up to a certain temperature. While the cooking oil has a taste, its the food and seasoning that ultimately decide the taste.
If you're doing a meatless stir fry, it can't just be done "dry" can it?
Regards, Anthony
Regards, Anthony
Bikes: '03 Fuji Roubaix Pro; '03 KleinGi Attitude; '06 Soma Rush; '04 Surly Cross-Check; '06 Soma Rush; '07 Scott CR1 / Chorus
steve
steve
As to the 'how much do you use' question... I use a carbon-steel wok. If I heat it to a good high heat, it only needs a tablespoon or less for each new batch. For stir-fry for two, I'd brown the meat in the first batch then remove it, then add a bit more oil for the aromatics (onions, garlic, ginger, chillies, spices) and build the stir-fry from there. If it's stir-fry for four, then two batches of meat (wok loses too much surface temperature too quickly if it's all added together, so the meat would stew instead of fry).
Liked 333 Times
Not a fan of tofu?
The other traditional preperation methods are fermented soy sauce, miso, nato and tempeh. Its the modern western preperation methods that you have to look out for based as they are on ignorance and foolish pride. Tradition has a lot to teach us but even the traditionaly prepared asian products should be consumed in moderation due to their estrogenic properties.
Regards, Anthony
Sophomoric Member
Cold pressed peanut oil tastes the best IMO. Andrew Weil says peanut oil is unhealthy. For everyday use I would go to canola, expeller pressed. But it doesn't taste as good as peanut oil.
I think it's healthier to use olive oil and a lower temperature saute, but you sacrifice the oriental wokked flavor and get a more mediterranean flavor. Do you think you would like that?
Oriental flavors: peanut oil, soy sauce, ginger, garlic, chilis, toasted sesame oil.
Mediteranean flavors: olive oil, wine, tomatoes, basil, garlic.
"Think Outside the Cage"
Seems like there should be a consensus on whether peanut oil is healthy, or not...
Liked 333 Times
If you wan't a trully healthy oil use virgin/unrefined coconut oil.
Here's a reference. The WAPF puts seasame oil in the preffered list and doesn't actualy mention peanut oil in the intro which I will assume means indifference. Again WAPF considers quality to be very important. https://www.westonaprice.org/knowyourfats/index.html
Regards, Anthony
Dubito ergo sum.
Bikes: Bessie.
If you just quickly hand-wash your wok, no need to oil the surface at all.
