Got a free bike, now what?
Bikes: Raleigh Gruv 2, KHS Comfort Recumbent
I got a free bike (and a free helmet) from my neighbor yesterday. It's a Specialized Allez Epic. I was told it is about 15 year old. But it rides fine for me. Just a couple of questions,
1. Do I need to tune it up? I know I can do it at my local sports store (G.I. Joes). Since it's free, I'm hesitating to spend $50 or more for this.
2. I felt pain on my groin even after a couple of minutes ride. Will a seat cover solve this problem? I found the following thing on Amazom.com,
Bell Gel Relief Seat Cover
https://www.amazon.com/gp/product/B00...ance&n=3375251
3. I'm also thinking to buy a small pump like the following one. But it says this is a mountain pump. I think the road bike needs a smaller adaptor, right? Should this pump work for me?
Blackburn 108197 Mountain Air Bicycle Mountain Pump
4. What else should I prepare/buy before a real trip? So far, I just ride in my neighborhood.
Any input is welcome!
All the best,
Tom
All the best,
Tom
Quoted: 11 Post(s)
Liked 15 Times
if the helmet is 15 years old, then retire it to the museum. most likely it'll be worthless in a crash.
get the bike tuned. it was free, so don't be so cheap.
doubt a saddle cover will make things easier on your groin. if that's where your pain actually is, maybe the saddle is twisted, or pointing up. saddle pain is usually behind your sack.
buy: pump/spare tubes/tire irons/allen key set/water bottles/gloves/shoes
ride and enjoy
ride and enjoy
100% USDA certified
Liked 5 Times
Awesome! How does it shift? How are the brakes? If they'res anything wrong, just take it into a local bike shop (LBS) for a quick minor tune. Might cost $40, but you won't regret it.
If you feel pain, you ought to make sure that the bike FITS. Fit is probably the number one most important element in deciding if a bike is right for you. If a bike doesn't fit, then it won't work for you, regardless of components or frame material or whatever else cyclists care about. This would be something to consult the bike shop about. They'd probably be glad to give you a few pointers on how to adjust your seat height, handlebar height, etc. to make your bike fit better.
The Mountain Air is, well, a mountain pump. I bought one when I first started road cycling, but it's not suited. It only goes up to 90 psi, which is enough air pressure for almost all mountain bikes but not enough for a road bike tire. Check the recommended pressure marking that should be written on the side of your tires and get a pump that will be able to fill your tires up to that number.
I know you don't want to spend money, I hated buying bike stuff back when I was fifteen. But be willing to set aside a certain amount of money for occasional repairs, accessories, etc. You should get yourself a small bike bag to mount onto the back of your seat, maybe a few tools. Your LBS can teach you how to use these and they'll basically tell you everything you need.
Have fun riding, I still remember my first road bike and how much I loved it. I got it when I was fifteen as well.
Senior Member (Retired)
Bikes: Vittorio, Centaur triple; Casati Laser Piu, Chorus Triple.
Ride it a lot, and enjoy it!
ride it into the ground, learn how to do the maintennance yourself then when you have the cash buy another bike. The cycling bug will bite
Fuji Shill
Bikes: Fuji Roubaix
Personally, I would stay away from those Gel Seat Covers. You would be better off laying your money across the seat and sitting on that.
Burning Matches.
Bikes: Motobecane Le Champion SL, Cervelo P2SL
Quoted: 3131 Post(s)
Liked 249 Times
Bikes: Univega Via Montega, Nashbar Aluminum frame/105 roadbike
About seat covers, get a pair of biking shorts with a chamois instead. (That's a crotch pad if you're not up on your cycling lingo)
I've found that's the single largest improvement in cycling comfort you can make.
I'd second the bike shop advice. Get them to give the bike a once over to make sure it's safe. That is unless your neighbor has got a notion about maintaining bikes and can look over it with you. If he hasn't ridden in a few years, he was probably never that into bikes, and the bike shop is probably a better idea.
Where are you? Maybe you could meet up with a Bike Forum member and they could give you some advice about whether the bike fits and if it's worth getting a tuneup done?
-Greg
-Greg
All my saved money are quarters in my piggy bank
Tom
-Greg[/QUOTE]
I'm in Portland, Oregon. Hope to see some of you guys soon.
Tom
-Greg[/QUOTE]
Tom
Tom
Tom
Quoted: 11 Post(s)
Liked 15 Times
Originally Posted by tommyx
I saw there is a sign on the body of the bike saying "Carbon Fiber" and I thought this should be pretty good. Am I right? Tom
how well does a top shelf computer from 15 years ago compare to todays computers?
....gets the cheese
Bikes: Cannondale Synapse, Cannondale Caad 8, Wilier Triestina Jareen
Quoted: 10 Post(s)
Why buy another bike later? Do you mean this model is not good enough? I saw there is a sign on the body of the bike saying "Carbon Fiber" and I thought this should be pretty good. Am I right?
Tom
Tom
Hook up with a BF member in Portland or take the bike into the local bike shop for a tuneup. After that, you can work on the bike yourself, especially if you know someone who knows his/her way around a bike.
Cheers.
Form*r Ho*rd*r
It's great that you now have a bike worthy of riding and that you want to get into it. That said, unless you know what you are doing or are willing to spend the money at a local bike shop, chances are real good that your bike is far from ideal for your body. In other words, it likely isn't fitted properly for you. Which is probably causing the pain you feel.
Now, if the frame is the right size, getting it to fit should be fairly simple. If it isn't, well, you might want to consider selling it.
If you are interested, I would be happy to meet with you and check out your basic situation. Might save you some $, time and headache. I work in downtown Portland and live in Sherwood, so arranging an early morning, lunchtime or late afternoon meeting should be fairly easy.
55/Rad
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 321 Post(s)
The Specialized Allez is a great bike - upper middle end. You could make a modern classic just by installing a new component group but that should wait until you've become a REAL(tm) bicyclist. To tell you the truth, if it was the steel Allez you probably have something that qualifies as a modern classic.
There are two kinds of groin pain - the sore butt and the SCREAMING PAIN or NUMB NUTS nuts kind.
The first kind will slowly go away with miles. The second is caused by the saddle not fitting properly because of SHAPE or WIDTH (usually the first) or because the bike doesn't fit you properly and you're sliding too far foward on the saddle.
A tuneup by a bike shop is a good idea if you're not mechanically inclined and even if you are you should find a shop that will let you watch the process so that you know what it entails. A tuneup isn't hard but there's a large number of things you need to learn about.
Helmets - it pays for a new rider to wear a helmet because for the first 5 years you have the greatest chance of crashing (mostly in single vehicle "oh *****" accidents). But you HAVE to remember that a helmet will offer you almost no protection in an accident and you need to be studied in your riding, not taking excessive chances and not pretending that a helmet makes you invulnerable. You should also learn to fall by riding around on a grass field and falling over several times to develop a technique for falling so that you know what to expect.
If you fall over without knowing what to expect you're likely to be stunned by the feeling in midair and not protect yourself properly simply because it's a new and strange feeling (before the impact - pain has always been a familiar feeling to me - I grew up with two brothers.)
Principiante
Bikes: Masi
As they say: Hai voluto la bicicletta....adesso pedala!
Yes you should bring it in at a shop and have them take a look, G.I. Joes or a bike shop, there are many around Portland, ask them many other questions and get a second opinion too. For sure have them check your helmets, you can get a new one cheap if that is too old, there is even a program for free helmets in Portland! Or very cheap from Legacy Hospitals. If the seat is not comfortable and hurts you can start with something a bit softer and wider, first get the bike shorts.
For local info check bikeportland.org
Ciao
Paolo
P.S.: 55/Rad You are such a great ambassador! Well done.
Ciao
Paolo
15 year old tires & tubes? Get some one to look at em. My suggestion is to have your LBS go over the bike and do a tune up. Last time I had this done it was $40 and included truing wheels. Good luck.
Originally Posted by 55/Rad
Tom,
55/Rad
55/Rad
Thank you so much for the kind reply. I really want to meet you someday in the near future. Actually I live in Hillsboro. In order to meet you in downtown Portland, I might need to find a way to attach the bike to my car. Once I figure that out, I'll PM you and let's schedule a time. Thanks again for the help!
All the best,
Tom
Form*r Ho*rd*r
55/Rad,
55/Rad
JOCP Lives!
Bikes: 2005 Felt F90 (my pride and joy)
How old are you? You sound young from your posts, and it's nice too see some other young riders. I'm 16 and I just got into road cycling last year. Just like you, I was a TOTAL newb and didn't know a single thing. Luckily, I became a regular on this forum. In a span of a few months, I've learned more than I ever thought I would need to know. lol.
My advice.
Read and post frequently on these forums, get that bike checked up and fixed, and keep riding.
My advice.
Bikes: Trek 5500 OCLV, Trek Fuel EX 9
Tom,
55/Rad
55/Rad
55/Rad is a highly-respected BF member who is always generous with his comments, time and cycling knowledge. You will find no finer offer of assistance from such a reliable source. Make every effort to hook up with him soon -- I guarantee you will not regret it!
Burning Matches.
Liked 249 Times
Originally Posted by Old School
tommyx,
I bought that same seat cover last year, when i got my bike. They sell them at wal-mart. If you're getting the numb nuts, it won't help you. If you're getting the sore ass instead, this will give you the numb nuts instead of the sore ass.
This past weekend i went to the LBS and bought a new seat (Cloud 9, with its own springs) for around $25. I haven't had the chance to test it yet as I live in Illinois (it's been raining here since late Friday night), but i'm hoping to be able to feel my nuts after the ride tomorrow.
