Your Personal Advice on Fenders...
Old 10-13-09, 09:43 AM
metalchef87
Bikes: 1990 Specialized Hard Rock
So I am using my 89 Nishiki as my daily commuter and I want (kinda feel like I need) to get fenders for it before the bad weather comes, but I am running into a couple of dilemmas. First of all the bike does not have any eyelets to secure the fenders with. Secondly there is not very much room at all, maybe enough space for my finger to fit through, between my tire and the brakes.
I have done some research, but I am not sure what type of fenders to get, if they make some small ones for road bikes that would be great. Secondly I just figured you guys have probably got some experience in this sort of thing...so whatcha got?
metalchef87 is offline
Old 10-13-09, 10:10 AM
20grit
Curmudgeon in Training
20grit's Avatar
Bikes: 1974 Gazelle Champion Mondial, 2010 Cannondale Trail SL, 1988 Peugeot Nice, 1992ish Stumpjumper Comp,1990's Schwinn Moab
Quoted: 18 Post(s)
Liked 6 Times in 5 Posts
there are some that zip tie to your rear triangle. they're called race blades. they might not actually use zip ties. i've just seen pictures. never really figured they'd work very well, but anything is better than nothing.
20grit is offline
Old 10-13-09, 10:26 AM
bbattle
bbattle's Avatar
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Trevisio, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 51 Post(s)
Liked 3 Times in 3 Posts
sks raceblades
bbattle is offline
Old 10-13-09, 10:33 AM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 1940 Post(s)
Liked 716 Times in 452 Posts
no eyelets on your frame how awful but it sounds like a good excuse to get a new bike!
Bianchigirll is online now
Old 10-13-09, 10:34 AM
metalchef87
What about these? https://velo-orange.com/vo52posmfe.html I could probably rig em with zip ties to stay...I am more concerned about the clearance issue...
Old 10-13-09, 10:45 AM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 6674 Post(s)
Liked 2,238 Times in 1,182 Posts
I can't even get my finger in on my bike. I just go with the backscratcher and wear waterproof shoes.
LesterOfPuppets is offline
Old 10-13-09, 10:48 AM
Noah Scape
can't member
Noah Scape's Avatar
Quoted: 13 Post(s)
I recently did a build using the Planet Bike Cascadias in the 35mm width. And I use the 45mm Cascadias on my daily commuter. They are great full coverage fenders that are easy to install. You could attach them with "P" clips.
Noah Scape is offline
Old 10-13-09, 10:55 AM
Mr_Christopher
insert witty comment here
Mr_Christopher's Avatar
Bikes: 2016 Specialized AWOL, 2011 Electra Bike Ticino, '09 Trek 7.2 FX, Peugeot UE 18
Quoted: 11 Post(s)
Poke around the VO site, they have a page that tells you what and where to measure. it's pretty straight forward. AFTER you take all the measurements of your bike you might send Chris at VO a note and find tune your understanding of how to install them. I say AFTER you take all the measurements because no one can answer the clearance issue but you (you can measure your bike, I cannot). Once you have the measurements then you will know what size will fit your bike and then you can pursue a means of connecting it all. They have those bits too but as one caller suggested, I'd get a fender friendly bike before I'd start duct taping fenders on one where fenders were never intended.
Good luck!
Chris
Mr_Christopher is offline
Old 10-13-09, 11:07 AM
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 1022 Post(s)
Liked 295 Times in 206 Posts
Your tires may fit, but there's no way those are going to stay where they need to with zip ties.
USAZorro is offline
Old 10-13-09, 11:18 AM
joe v
joe v's Avatar
Bikes: ca.1975 Gitane Interclub - 90's Colnago Master Competition- ca.'84 Merckx Corsa - '77 Groene Leeuw - ca. '78 Guerciotti - ca.1984 L'Express - 1974 Gitane 'Super Olympic' - Peugeot 1981 PXN10 - 1975 Peugeot PR10 -1974 Norta -1974 Peugeot PX10 LE
SKS fenders -the full size, NOT their way too short 'race-blades' - easy to mount even with very little space and no eyelets (zip-ties used there), here on a 1984 Merckx Corsa. Used these in some pretty crap weather with no problems at all. Just don't go wider than 23mm tires!
Manufacturer's site :
https://www.sks-germany.com/sks.php?l...e07d322ea773e5
Joseph
joe v is offline
Old 10-13-09, 11:23 AM
kbjack
Makeshift
kbjack's Avatar
Bikes: 2002 Bianchi Vigorelli, 2002 S-works CX, 1973 Raleigh Super Course conversion, 1979 Raleigh Competition, 1973 Raleigh Professional Track, 1980 Austro Daimler Inter-10
I've used SKS Race Blades for a couple years now. I was worried in the beginning that they wouldn't stay put (they use a rubberized band similar to trunk rack mounts to secure to the frame), but after initial set up, I've never had to fiddle with them.
I'd highly recommend them as an alternative to the jury-rigged zip tie route--especially if you're already gearing up to spend ~$50.
They don't look C&V like the VO's, but they do the job and have their own utilitarian aesthetic.
kbjack is offline
Old 10-13-09, 11:26 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1781 Post(s)
Liked 273 Times in 184 Posts
Yep, I like the way you're thinking!
rhm is offline
Old 10-13-09, 11:48 AM
metalchef87
You can make anything stay with enough zip ties
Old 10-13-09, 11:50 AM
LesterOfPuppets
Bikes: everywhere
hehehe, stack 'em up all the to the dropout. acts as a frame protector, too!
Old 10-13-09, 12:16 PM
USAZorro
Señor Member
USAZorro's Avatar
I'd much sooner use p-clamps.
USAZorro is offline
Old 10-13-09, 12:41 PM
treebound
aka: Mike J.
treebound's Avatar
Bikes: 1995 Trek 520 is the current primary bike.
Quoted: 99 Post(s)
Liked 22 Times in 15 Posts
Has anyone mentioned the splitter brackets (enter proper verbage) that you basically cut the fender in half and attach it ti the bracket. The bracket then attaches to either the rear brake bridge or to the fork in front.
Ascii art: __|--|__ (upside down ascii art)
I'll see if I can find an image someplace....
treebound is offline
Old 10-13-09, 12:50 PM
treebound
aka: Mike J.
treebound's Avatar
Quoted: 99 Post(s)
Something like this one:
https://www.cyclofiend.com/Images/wor...nd_example.jpg
For low clearance needs.
You'd still need p-clamps for the fender stays, but the bracket would do the bulk of the support work.
Old 10-13-09, 01:26 PM
metalchef87
^^^That is very interesting! I may have to go with that...though I did measure and I believe that the 35mm set may work...I may just barely have enough clearance...I guess I can go to a shop and see before I commit to buy anyway.
Old 10-13-09, 02:09 PM
BGrayvy
I use these SpeedEZ from Planet Bike on my old Trek 2100 and they do a decent job. Not the same as the full coverage I have on another bike, but a good compromise for my "fast" bike. The Trek has low clearance and no eyelets.
BGrayvy is offline
Old 10-13-09, 02:19 PM
metalchef87
DOH! I am stupid or something! I do have eyelets...I don't have braze-ons...my bad.
Anyway now my main concern is clearance...I really do believe that the example on the Eddy Merckx above will fit...
If nothing else maybe I can go with the split fender example...
ilikebikes
K2ProFlex baby!
ilikebikes's Avatar
Location: My response would have been something along the lines of: "Does your bike have computer controlled suspension? Then shut your piehole, this baby is from the future!"
Bikes: to many to list
Quoted: 15 Post(s)
Liked 44 Times in 24 Posts
Originally Posted by bbattle View Post
sks raceblades
+1, I used them for a while and have no complaints.
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
ilikebikes is offline
Old 10-13-09, 03:26 PM
metalchef87
Thanks for all the advice...now if I can find 39.00 dollars laying around...
Old 10-13-09, 03:28 PM
due ruote
due ruote's Avatar
Quoted: 765 Post(s)
Liked 252 Times in 174 Posts
If you can fit your finger between the tire and fork and brake bridge, I think you'll be OK. I've used both SKS and Planet Bike Freddy Fenders; nothing high class. Both of the ones I mentioned work well and seem durable for plastic fenders. I like the hardware a bit better on the PB ones, but SKS looks a little more vintage. It's a good idea to put some blue loctite on the eyelet screws, btw.
due ruote is offline
Old 10-13-09, 03:34 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 207 Post(s)
Liked 213 Times in 101 Posts
Well, now you don't have to worry about P-clamps. I like the sks fenders I am using, the planet bikes look really nice too. I think the Planet bike fenders were also less expensive. The SKS fenders have a safety release clip on the front in case they jam up on the tire (and it has happened to me once so far)
mkeller234 is online now
Old 10-13-09, 03:49 PM
prettyshady
12345
Your Personal Advice on Fenders, what a nice title!
One day my traditional rain gaurd got into my spokes going down hill to work, might have been at the eyelet?
the rain gaurd shatterd, alot of spokes snapped, and the nipples got pulled though the rim.
So my Personal Advice on Fenders, are these new 7 euro for a pair, clip on plastic items.
see youtube video I just uploaded --> https://www.youtube.com/watch?v=GQwocFyhzO4
It doesn't rain too much here, so if its predicted I can just clip these things on. 7 euros a pair, 20 seconds to install. And if its not rainning then my bike doesn't need to have them on.
prettyshady is offline
