Best Oil Can For a 3 - Speed?
Old 01-17-15, 04:03 PM
dweenk
dweenk's Avatar
Bikes: 1972 Fuji S-10-S,1970 Raleigh Sports, and more
Quoted: 762 Post(s)
Liked 153 Times in 112 Posts
Getting oil into a 3-speed hub can be messy. I would like to see the best practices from the members ( I just bought a 6 oz. oiler with a flex spout BTW).
dweenk is offline
Old 01-17-15, 04:09 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 727 Post(s)
Liked 247 Times in 153 Posts
You can always go in through the side door if you have trouble injecting it in the oiler. If you remove the indicator, you can put the oil in that way.
Dan Burkhart is offline
Old 01-17-15, 04:16 PM
FBinNY
Quoted: 4362 Post(s)
Liked 24 Times in 23 Posts
An eyedropper does a decent job. Also, if you have a steady hand, anything that lets you dispense drop by drop works. Get a falling drop to land over the hole, and it draws in very neatly. This is how I oil electric motors all the time, and it works very well (until I miss).
BTW - here's a trick for getting oil into a hard to reach place. Use an icepick or skewer of some kind, and put one end at the oil port, and sloping up from there. Apply a drop to the end and it runs down very nicely.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 01-17-15, 05:17 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,308 Times in 821 Posts
Dan's Side Door, There is a hollow end of the axle ...
the shifter has a pin threaded into the piece that does the selecting. removing that pin
the chain on S-A hubs ... I squirt a little Phil Tenacious Oil from its container down that hollow end
and then screw the indicator-shift chain back In.. Quite Un Messy that way..
fietsbob is offline
Old 01-17-15, 05:38 PM
AnkleWork
Bikes: old clunker
Quoted: 684 Post(s)
Liked 102 Times in 80 Posts
This one is best:
John Dow Industries Fluid Dispenser JDI 5DP | eBay
AnkleWork is offline
Old 01-17-15, 05:39 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1524 Post(s)
Liked 1,038 Times in 711 Posts
I use an old Rem oil bottle. The ubiquitous red plastic straws fit right in it and let me get right in there. I use synthetic 10-30 because I run it in my truck.
File Type: jpg
dedhed is online now
Old 01-17-15, 08:00 PM
Gresp15C
Gresp15C's Avatar
Quoted: 932 Post(s)
Liked 452 Times in 305 Posts
I use a syringe.
Gresp15C is online now
Old 01-17-15, 10:27 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2490 Post(s)
Liked 1,022 Times in 662 Posts
I use this, found in the garage of the house we bought almost 30 years ago:
JohnDThompson is offline
Old 01-18-15, 07:53 PM
tcs
Palmer
tcs's Avatar
Bikes: 1980 Mike Melton, 1982 Stumpjumper, 1982 Santana, 1984 Alex Moulton AM, 2008 BikeFriday tikit T-11, 2010 Dawes Briercliffe, 2017 Dahon Curl i5, 2019 Surly ˝DT14
Quoted: 791 Post(s)
Liked 267 Times in 180 Posts
3 in One Motor Oil (Blue label! NOT black label) is probably the closest equivalent we have to the Sturmey Archer Oil of yore, both as a lubricant and as a dispensing container.
tcs is offline
Old 01-18-15, 07:55 PM
bikebuddha
bikebuddha's Avatar
I use these little hair dye bottles my wife gets. Their nozzle is just the right size.
The few, the proud, the likely insane, Metro-Atlanta bicycle commuters.
bikebuddha is offline
Martin Genet
Touring
12
08-21-17 05:11 AM
roccobike
Classic & Vintage
27
07-16-15 05:32 AM
TurbineBlade
Bicycle Mechanics
1
05-14-12 08:31 PM
seanspotatobiz
Bicycle Mechanics
2
08-15-10 11:23 AM
