is there a way to improve antenna signal strength?
Old 01-19-15, 06:43 PM
windhchaser
Bikes: Felt nine flow
Quoted: 662 Post(s)
Liked 7 Times in 5 Posts
on my tv I barely get nbc what can I do to get a better signal do amps work? if so what amp do I get?
windhchaser is offline
Old 01-19-15, 07:01 PM
bikebuddha
bikebuddha's Avatar
Find out where the transmitting tower is and reorient your antenna, depending on the spread between the towers in your area you might need two antennas.
The few, the proud, the likely insane, Metro-Atlanta bicycle commuters.
bikebuddha is offline
Old 01-19-15, 07:09 PM
skijor
on by
skijor's Avatar
Quoted: 811 Post(s)
Liked 414 Times in 247 Posts
I have a post-amp paired with an attic antenna and the results were initially acceptable, but have detiorated over the last few weeks to the point of getting half the channels. Weather isn't the issue...we haven't had anything resembling a real winter yet. FTR, I'm ~25 miles from all of the transmitters. Will be erecting a traditional outdoor antenna to be done with it.
Repositioning to avoid trees and other obstacles may help. Elevate if that's an option. The digital signal is fussier than analog.
skijor is offline
Old 01-19-15, 07:12 PM
katsrevenge
covered in cat fur
katsrevenge's Avatar
Bikes: Papillionaire Sommer, '85 Schwinn World Tourist, 2014 Windsor Kensington 8, SixThreeZero SS Cruiser
We always used tinfoil. And sometimes a fork, stuck on the end...
katsrevenge is offline
Old 01-19-15, 07:19 PM
windhchaser
Quoted: 662 Post(s)
its pointed in a great postion I think nbc is just a tad out of range I get many channels with four bars
Old 01-19-15, 08:08 PM
CliffordK
CliffordK's Avatar
Quoted: 13267 Post(s)
Liked 1,777 Times in 1,343 Posts
I haven't been using the TV much, but I have a disc shaped omnidirectional antenna with a signal booster. It seems to get most of the local channels. It really needs to be mounted in the attic, or on the roof for better reception, but the reception does change somewhat depending on where I have the disc located.
CliffordK is offline
Old 01-19-15, 09:03 PM
skidder
Bipsycorider
Quoted: 567 Post(s)
Liked 289 Times in 211 Posts
Do a little searching on the internet and you should be able to find a government website where you can search for the locations of the TV stations in your area, then make sure your antenna is aligned in that direction. The broadcast towers in my area are all about 30 miles away, and I get clear reception. You might also check the antenna itself, as you might need something different depending on the exact broadcast signal frequencies of the stations, maybe a bigger antenna, maybe mount it higher, and something entirely different depending on whether you're trying to pick up digital or analog frequencies.
Currently using my antenna for radio reception, but I may drop cable TV and go back to regular antenna TV; there's not really much interesting programming to justify the cost of cable TV.
skidder is online now
Old 01-20-15, 12:20 AM
eschlwc
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 9 Times in 7 Posts
don't discount the power of brain wave interference.
i make my cat wear one too ... at least when she's anywhere near the living room.
i'm not saying this will absolutely work for you, but i am saying, you should try it and report back.
eschlwc is offline
Old 01-20-15, 01:01 AM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 20565 Post(s)
Liked 3,629 Times in 2,660 Posts
...I use a signal booster i bought from Radio Shack for FM radio, but once they made the switch to digital, I found it impossible to get decent TV reception here.
3alarmer is offline
Old 01-20-15, 05:34 AM
maddmaxx
Boomer
maddmaxx's Avatar
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 15686 Post(s)
Liked 1,350 Times in 981 Posts
Yes there is. Call the cable company.
maddmaxx is offline
Old 01-20-15, 06:20 AM
cradom
cradom's Avatar
Bikes: Schwinn Sport Tourer, Dawes Lightning Tourer
Go here: TV Fool
Find out exactly where the transmitter is, point your antenna at it.
Larger, outdoor antennas are best. Don't be fooled by "digital" antennas. A signal is a signal.
cradom is offline
Old 01-20-15, 08:52 AM
genec
genec
genec's Avatar
Quoted: 9873 Post(s)
Liked 2,064 Times in 1,416 Posts
Start with a better antenna... and amplifier will only amplify what the antenna first receives... if you are off tune (not pointed the right way) you will only amplify more garbage.
So best to start with the best antenna you can find, and then make sure it is oriented in the right direction... then it is highly likely that you won't need an amplifier.
A decent TV antenna is more than rabbit ears, or a loop. It is a large yagi with lots of elements... and from there you need to use good cable, so you don't degrade the signal. If your cable is a long run, then it makes sense to have an amplifier... as close to the antenna as possible.
genec is offline
Old 01-20-15, 01:00 PM
dstrong
dstrong's Avatar
Bikes: Specialized Roubaix, Interloc Impala, ParkPre Image C6
Quoted: 225 Post(s)
Liked 32 Times in 21 Posts
Interesting stuff. Now I want to go the antennae route, if only to be able to use the phrase "large yagi"!
Are these HD signals? Like 1080?
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
dstrong is offline
Old 01-20-15, 02:44 PM
no motor?
Unlisted member
no motor?'s Avatar
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 429 Times in 294 Posts
chromecast
no motor? is offline
Old 01-20-15, 02:45 PM
no motor?
Unlisted member
no motor?'s Avatar
Don't you need to the digital to analog converter now?
Old 01-20-15, 03:57 PM
genec
genec
genec's Avatar
Here is a clue... and I see this all the time and laugh... there is NO SUCH THING AS A DIGITAL RF SIGNAL... hence while the HD or 1080p may be encoded into the modulation, what you are receiving is an analog wave form. And in order to receive that analog wave form, you need the proper tuned bits of metal... an antenna.
Here is a further hint... next time you go out to the entertainment super store, and you see headphones advertised as "digital ready," ask yourself just what part of your analog ears are these headphones going to work on?
So many marketeers throw these terms around as if they mean something... and the unknowing public just jumps on them... seeking the latest greatest... "this way to the egress... "
Your TV may be digital ready, and able to decode HD from the RF waveform, but the bottom line is that the antenna you seek must obey the basic laws of physics regarding wavelengths, harmonics and signal strength.
genec is offline
Old 01-20-15, 07:06 PM
windhchaser
Quoted: 662 Post(s)
weird today we had cable internet outage it was out in my area and sure enough I got 3 bars on nbc I didn't put the 2 together till it came back on and my bars went back down.so I disconnect my cable modem and they went back up.so now I moved modem and I got 1 bar I guess its interfering with my signal strength .what do you think I should do?
Old 01-20-15, 07:50 PM
Juan Foote
LBKA (formerly punkncat)
Juan Foote's Avatar
Quoted: 1255 Post(s)
Liked 227 Times in 159 Posts
That converter was for the TV to see the signal when tuned to pickup "analog". New TV's are "digital ready" (see the informative above post) and already decode that signal.
Juan Foote is offline
Old 01-20-15, 08:05 PM
windhchaser
Quoted: 662 Post(s)
I called charter they said its interference lol duh
Old 01-22-15, 09:06 PM
windhchaser
Quoted: 662 Post(s)
its a tad better I moved my cable modem donstaires I now get nbc and almost get pbs the cable company told me to order cable tv if I want tv
Old 01-22-15, 09:56 PM
skijor
on by
skijor's Avatar
Quoted: 811 Post(s)
skijor is offline
Old 01-22-15, 10:16 PM
windhchaser
Quoted: 662 Post(s)
I told em ill rip all there cable from my property she I cant do that lol . I said you wanna bet
Old 01-22-15, 10:42 PM
Maybelater
Quoted: 8 Post(s)
I made my own antenna from plans @ How to Make a DIY Homemade TV Antenna | TV Antenna Plans I made one antenna from a 9 inch lid off a cookie tin and it worked well but not as good as the DB4 antenna. These home made antennas will pick up any digital signal for up to 30 miles. I built the DB4 antenna for around two bucks in materials. Pics in this gallery...
https://neuro.smugmug.com/Other/DIY-H...0203&k=c5XSL6H
Maybelater is offline
