Are SAPIM J-bend spokes shorter than nominally identical DT ?
Quoted: 125 Post(s)
Liked 29 Times
Is it true that SAPIM measures their spokes from centre of the bend while DT from the inner edge? Shall I subtract 1mm from DT swiss calculator results when using SAPIM spokes?
Senior member
Quoted: 937 Post(s)
Liked 652 Times
Not sure where you got that from, but I have tons of both brands here and never found that to be true. Most of the time, I'm cutting spokes to length anyway, but for those times I'm not, the Sapims always measure accurately out of the bag on my spoke ruler.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
I've never heard that either. I ordered Sapim spokes from Danscomp a few years ago for a project, and the spoke ends landed exactly where I expected them to.
@avrilboazmoss, I have a radical idea for you: have you considered emailing the company to find out?
Quoted: 125 Post(s)
Liked 29 Times
Nothing authoritative, just a random post withing rounding up/down discussion in 2016 on mtbr forum:
Just to toss more confusion into your woes, perhaps you should find out how spokes mfgs measure their lengths. I know DT DOES NOT measure from center of the J-bent section to the tip of the threads. They use inside to tip length, so if you use 2mm, you should add 1mm. Sapim, on the other hand, DOES measure center to tip and their labeled lengths are exactly 1mm short when you lay it on a Park spoke ruler (what I used for the DT also).
Quoted: 4172 Post(s)
Liked 3,791 Times
One hopes that 1mm of spoke length change won't ruin your wheels.
I've cut hundreds of spokes on a few different Phil machines and assume on a .5mm variance is resulting length. If I need a closer length tolerance I have cut/thread the spoke long and ground to the length and run the spoke through the cutter/threaded to clean up and resize the threads. Andy
AndrewRStewart
AndrewRStewart
Bikes: old clunker
Quoted: 684 Post(s)
Liked 104 Times
Senior member
Quoted: 937 Post(s)
Liked 652 Times
OK, how about some actual confirmation. Here I have a spoke taken from a bag of Sapim Race spokes marked as 268mm
And a DT Swiss
As near as my old eyes can tell, the Sapim is pretty much dead on 268 whereas the DT is about 1/2 mm short. I consider that within tolerance.
And a DT Swiss
Likes For Dan Burkhart:
Quoted: 350 Post(s)
Liked 122 Times
For the last wheels that I built, I accidentally measured from the end of the bend instead of the middle of the bend. This made me order 1mm longer sapim spokes. Then, the spokes I received had up to 1.5mm of differences in length. And the holes on the flange can be a little off center, I'd say 0.5mm.
So the result was most spoke tips ending 1mm above the nipple slot, but a few were at the top of the nipple head. Sapim 12 and 14mm nipples can have the spoke tips bottom out when they are around 0.5mm above the nipple head. But there were 2 spokes that went a further 1mm, so the tip was 1.5mm to 2mm above the spoke head. I simply turn the spoke 2 or 3 revolutions further after bottoming out. I don't think it's a problem and may help with retention.
Likes For tomtomtom123:
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
DT Swiss measures from center to end
All others that I know of measure from inside to end.
For 14g (2.0mm) spokes - it is about a .5mm diff.
So it's basically something only to be concerned with with DT Swiss spokes AS-IS from a box.
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
