Giant Roam 1 Disc 2019: correct tyre pressure?
The above has 700 x 38 wheels and the tyre wall shows max 75 psi.
I have a 'thing' about my tyres being solid to the touch when pumped up.
My pump won't allow me to go above the recommended pressure, no doubt for good reason but when riding the bike on the flat, for example the tyres make that slurping sound as if they are (almost) flat.
I only weigh about 11.5 stone or 160 pounds.
Am I doing something wrong or expecting too much?
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I presume you're hearing some sort of tread noise on smooth surfaces. At or above 75 psi on a 38mm tire for a rider of only 160 pounds means you're likely riding on only the very top of the tread pattern, and you're likely to experience some sort of tread noise that most wouldn't experience just because only the tops of the tread features are in contact with the pavement.
I don't know what tires you have on your Giant. Are they the stock Crosscut tires, as shown below?
roam08 by jnjadcock, on Flickr
I'd say you're putting too much pressure in your tires. I weigh 85 kg/190 lbs, and have found that the optimal pressure for my 700cx38 Schwalbe CX Comps is around 55-60 psi, depending on the road conditions. It may vary a bit for each tire, but I don't think the difference would exceed 10 psi.
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
My Specialized Crossroads Armadillos run the same 75-100 PSI. Specialized made a new version of the Crossroads Armadillo that has much lower PSI. 700 x 38mm, psi 50-80.
Thanks for the responses.
The tyres are the Giant Crosscut AT ERT 700x38C tubeless, and the tyre wall shows the maximum pressure at 75psi.
To me, at that level they feel under inflated..
I can't post a photo of the tyres because of a ridiculous rule that I must have made 10 posts first.
Liked 762 Times
I'm 240 pounds, and I ride my 38s at about 40 psi in the front and 55-60 psi in the rear. I promise you that 75 psi is not underinflated. If you're used to road bike tires, which have smooth tread surfaces, you may just be feeling tread squirm from the taller tread features.
Quoted: 576 Post(s)
Liked 1,003 Times
aka Phil Jungels
Once you wear the square leading edge off those knobs, they will be quieter, and have less buzz!
