Considering a new stem, opinions please...
Bikes: '16 Specialized Tarmac Comp (5800), '10 Spec Roubaix Expert (5800), '04 Specialized Roubaix Pro (3500)
Quoted: 20 Post(s)
I've had my bike for a couple of months now and I think that I have the 25 mile circuit that I'm going to ride for a while. I've noticed that in the last three or four miles my lower back starts to ache. Maybe I just have to build up some stamina but I've also noticed that while it's not uncomfortable per se, using the drops when riding into a head wind isn't my favorite position because it just doesn't feel "right" (not sure if I just need to get used to it). I do 90% of my riding on the hoods and really like that position but after about an hour of riding, the heel of my hands start to numb and I end up riding for a few minutes on the top bar. So it has occurred to me that I can try out a new stem to see if I can ride in more comfort in all positions.
My '14 Allez Sport came with a 10cm/6* stem. I'm considering a 9cm/10* stem to bring the bars up and closer to my body but I'm wondering if it's too much change at one time. Would I better off getting a 9cm/6* instead? I do feel that my bars are the right ones for me (42cm width/14cm drop/8.5cm reach). The bike was fitted to me when I purchased it but I have to admit that the geometry changed a little when I purchased a new seat post and saddle (but I did my best to make sure that my leg position is the same as it was originally with the old saddle and seat post--not so much my upper body).
Thank you for your opinions.
Quoted: 15 Post(s)
Specialized has an adjustable stem. It uses shims to give you a couple of different angles. Its on sale right now for $26.
mike
mike
Quoted: 6556 Post(s)
Liked 58 Times
If your relationship to the bottom bracket has not changed, then neither has your relationship to the bars. If your fit to the bars has changed, then you did something wrong setting up the saddle. Get the saddle right first, before you contemplate anything different regarding the handlebars.
Quoted: 20 Post(s)
Quoted: 20 Post(s)
Thanks for that suggestion, I think that I'm going to go with this option. Where did you see the $26 price? The only place I saw that price was on eBay.
Bikes: Cannondale Synapse, Focus Izalco, Focus Mares CX, BMC GF02, Giant VT3 MTB (upgraded), Felt Brougham SS
Quoted: 56 Post(s)
You could also go to a LBS that sells your bike model and take a look at how the new ones are set up. Most good shops will work with you for a basic bike fit...just do them a solid and pay the little extra to buy a stem from them if you do need one.
Quoted: 20 Post(s)
I made not less than a dozen adjustments when I switched from the very nice OEM to the fizik Arione--most of them being fore/aft changes. I had no idea that installing a saddle could be so frustrating.
Thanks for getting me all excited with your suggestion. I ran to my bike thinking that I could do that quick change but of course...the two spacers were already under the stem. But thanks for that suggestion, I never would've thought of that.
I grew up in Burbank, did you grow up there also?
Quoted: 20 Post(s)
Thank you every one for your help. I'm going to look for an adjustable 90mm stem and go from there.
Quoted: 15 Post(s)
Quoted: 1814 Post(s)
Liked 923 Times
I put a shorter (9cm) stem on upon getting back into riding.
Bought a selection from Nashbar for~$15 ea.
Over a number of years, have since gone to longer, lower position.
Go for it- don't be afraid to experiment, your riding position will change over time.
Quoted: 20 Post(s)
Just an update: I found a 90mm, adjustable stem by Specialized used for $35 on eBay; it wasn't the cheapest but it was what I was looking for so I went for it. I got it on Friday, installed it yesterday and was shocked to see what about 20* of rise looks like on a shorter stem!
I did my 25 mile circuit today and loved it! There's a five mile length of the bike trail that's totally exposed to wind because there's no wall in that particular stretch. I try to go down to the drops to be more aerodynamic but would only last about a half-mile because my lower back would start aching--this morning I did about 90% of the exposed trail with no ache! I noticed that I have to adjust myself on the seat when I use the drops but I noticed that my seat bones seem to rest on the wide part of that stupid fizik Arione saddle that I bought much better now (maybe it's the slight difference in the position of my upper body?).
Anyway, thanks again to everyone for your suggestions. I finally have the bike dialed in and now I'll be able to enjoy my riding in comfort.
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
exactly wrong answer.
You get your position in relation to the pedals right first, then you adjust height and distance to the bars.
You do not move the saddle to alter the reach to the bars.
You could get lost and die.
You could hit a tree and die.
To Function, does not even need the specialized Logo , just fit the steerer and the bars,
and be the length & angle you want..
shop online? get several around the target position and Try them..
0-45 degree
0-45 degree
Bikes: 2009 BMC SLX01/2016 Santa Cruz Bronson
Quoted: 8 Post(s)
The back pain sounded like an issue with his back being bent over instead of his hips, sorry for giving out bad info.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I question whether you have the right bars. A 140mm drop is a lot, and you're already not comfortable riding down in them. To move the bars closer you could also perhaps consider shorter reach. Eg. Maybe look at something like a Zipp SL-70 and leave the stem alone?
