Shrader vs. Presta -- Adapter possible? Differences?
Quoted: 120 Post(s)
I'm all shrader now. If I got a rim that has a presta hole for the valve stem, what can I expect switching to presta?
Are there adapters to reuse a shrader pump with a presta valve? Or a presta pump with an adapter to a shrader valve stem?
Spare inner tubes I've got now become worthless.
I'd need to get a whole new presta pump if there are no adapters?
Quoted: 550 Post(s)
Liked 325 Times
There are adapters. Shrader pump to Presta valve are so common some bike shops even have a container next to the cash register. You can leave them on the valve stem.
https://www.amazon.com/Slime-23042-P.../dp/B007OX6E3S
Presta pump to Schrader valve also exist
https://www.amazon.com/Schrader-to-P.../dp/B00L3PNK1W
I have a Kuwahara Hirame Presta head on my floor pump because it's the best, and use a Presta to Schrader adapter on the rare occasion I need to inflate a Schrader tube.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
I've got a bunch of those adapters in the shop. If you go that way, send me your address and I'll drop a pair in the mail.
Quoted: 1438 Post(s)
Liked 1,092 Times
[QUOTE=bikerbobbbb;19394966]I'm all shrader now. If I got a rim that has a presta hole for the valve stem, what can I expect switching to presta?
QUOTE]
There are adapters. There are pumps with dual-use heads, or convertible heads like the Topeak Morph series.
Instead of the pump head pushing the valve core open like Schrader, air pressure does it with Presta, AFTER you undo the little nut on the valve. "Burp" the valve before applying the pump head in case the valve has gotten stuck.
QUOTE]
Quoted: 5224 Post(s)
Liked 3,581 Times
Liked 3,581 Times
Quoted: 120 Post(s)
I'm not a mechanic... It sounds safer to sand it a bit or maybe add in rubber around the edges to protect the valve stem even more.
Quoted: 18376 Post(s)
Liked 4,511 Times
You can also get push-on adapters for the pump. I haven't used these for quite some time as many pumps now do both Presta and Schrader.
Zefal Bicycle Presta Adapter, Push-on Alloy with Chain
I've had quite good luck with the JoeBlow pumps (with metal head) (Sport?) which will easily accept both Schrader and Presta valves.
https://www.rei.com/product/657109/t...ort-floor-pump
in the shop , hole drilling in metals, leaves burrs, a de burring tool cuts away burrs, quickly.
sandpaper is not the right tool for everything..
there are many p/v to s/v adapters, rubber grommets are one of them.
Have you used the Forum archives yet,? I recommend doing that .. it's been a rehashed FAQ often.
Liked 3,581 Times
yeah use a little file. files are good to have around. a flat one & one that looks like a pencil cuz you can twist it inside the hole. use the flat one to bring down the burs. I also like to put a little black paint on the edges. take your time, don't rush it
Quoted: 1572 Post(s)
Liked 643 Times
If you'd like, I could argue for a very long time on the relative merits of Schrader vs. Presta valves. And I'm able to argue either side.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
A tapered hand reamer can be used to enlarge the hole from presta- to schrader-sized.
Presta valves on all the bike wheels in our garage except wife's bike.
Liked 4,511 Times
Oh... also, for the mini-pumps, you often unscrew the end. Pull out the rubber piece. Behind that should be a little plastic piece with a pin. Turn it the other way. That fat end of the rubber should slide onto it, then insert it back into the pump, pin down, and skinny end of the rubber up. Screw it back together. And, you've converted your Schrader mini pump to a Presta Mini Pump.
There are probably photos or videos on the internet, but it becomes quite logical once you've done it a few times.
If you're setting up a new bicycle with a unique tire size, I'd probably keep it Presta.
If you have a second bike, or spare wheel, of the same size as others you're using. Then it would be easiest to standardize. You can probably use a Presta valve in a Schrader hole.
But, eventually plan on all bikes with the same tire size being Presta, or all bikes being Schrader.
Don't do a single bike with one being Schrader and one being Presta, unless tube sizes are significantly different.
That said, most pumps at has stations that I've seen now are spoon/lever-type inflators, and it is irrelevant.
Constant tinkerer
I hate those presta to Schraeder adapters. They make the inflation process longer (unless you leave the presta nut unscrewed all the time) and they don't always work.
Since this is the only presta wheel in your fleet, ream out the hole for a Schraeder valve if you can. It's fine to do unless the rim is very narrow.
Personally, I try to run Schraeder where I can because they're more durable and I can always use a spare presta tube if I need to, but the opposite can't be done.
Liked 3,581 Times
Quoted: 1083 Post(s)
Liked 686 Times
Push-on chucks work spottily with presta adaptors. The pin can slip entirely in the adaptor...compounded by the presta valve not having enough resistance to open the pin when pressure is low.
I do find that sometimes if I don't unscrew the presta valve all the way out, or don't thread the adapter all the way on and seat it tight, it can sometimes not work right on the first try. But that's user error, me being in a hurry and not watching what I'm doing.
