1987 Specialized Crossroads threaded headset specs?
I've got a 1987 Specialized Crossroads and the threaded headset needs replacing. Does anyone know the inside diameter of the head tube?
Would like to order the headset bearings before I source the tools to re & re.
Thanks in advance
Thanks in advance
Quoted: 1943 Post(s)
Liked 2,164 Times
While I don't know the specs of that model, this thread may help to figure it out. Also, the stack height is very important.
https://www.bikeforums.net/bicycle-m...dset-size.html
John
John
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Chances are it's either ISO 30.2mm or JIS 30.0mm; you can't really tell until you pull the cups and measure. A JIS spec frame and fork can easily be milled to ISO spec, but not vice versa. The path of least resistance might be to order an ISO headset with the same or shorter stack height as the original, and then deal with any mismatch when you get the old headset out.
Thanks guys.
Just got the bottom cup off 29.9 mm inside head tube. Cup reads 30. mm.
Old fart
Liked 3,400 Times
That's JIS spec. Have you measured the ID of the crown race? is it also JIS (27.0mm) and not ISO (26.4mm)?
JIS headsets are readily available. You need to find a replacement headset with the same or lower overall stack height.
Likes For JohnDThompson:
Thank You, I will be washing up now. Then ordering on Amazon Prime a JIS Headset
Quoted: 1819 Post(s)
Liked 1,693 Times
If the bike has a replacement fork, the only way to be sure of the headset specifications would be to do what you have done, taking measurements.
Likes For alcjphil:
