Need for locking out suspension.
I am 70 years old with back problems. I bought a Cannondale Super with full suspension and also have a Trek X-Caliber with front suspension.
I have a lot of rough streets in my neighborhood and I really like the suspension.
I have read that most riders lockout their suspension on smooth roads.
I guess it's a matter of personal preference but is there a reason for this?
aka Phil Jungels
It is much more noticable when trying to go up hill,,,,, I also like suspension, unless going uphill!
Loose grip on the bars helps with non suspension bikes
air oil shock forks you can stiffen/soften them with more/less PSI of air.
Quoted: 8279 Post(s)
Liked 9,035 Times
When climbing or even just riding along on a rough surface, the suspension is an advantage. I've only used suspension on a mountain bike but I've never felt the need to lock it out. There are some designs which bob more than others, and the longer travel systems would probably be the greater offenders.
Whether the movement of the suspension (on a smooth surface) bothers you is something only you can decide.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
The only bikes I have with suspension are only ridden offroad. They have lockout settings on the suspension, but I never have a need to use it.
Quoted: 1572 Post(s)
Liked 643 Times
What is your objective?
Since you are riding a full suspension mountain bike on the streets I'm guessing that you value smoothing out the bumps over the last increment of high speed performance. We all do that to some degree, even the pros use different bikes for cobblestone race routes.
Ok, never needed one ..
Bent elbows and knees were sufficient for suspension .. Though I now have a suspension seatpost on a bike.
