Surly 1x1 and 700cc wheels
Too Much Crazy
Bikes: Eriksen 29er, Gunnar Roadie, Niner RLT, Niner RIP 9
Quoted: 116 Post(s)
Does anyone know how big a 700cc tires you can fit in a 1x1 frame and fork?
thanks
thanks
dc pirate, 4evah.
Bikes: several. blue. fun.
really big. it's the fatties fit fine thing-- i'm sure it will take anything you can find in a 700 tire. (700s don't usually come all that fat anyway, mtb tires are 26")
Too Much Crazy
Quoted: 116 Post(s)
I was looking to fit 700x49's in there. Is it a possibility or not?
Thanks
Cornucopia of Awesomeness
Tire clearance: FFF(Fatties Fit Fine) chainstays up to 2.7"
I don't think width is going to be a problem. But since 700c rims already have a larger diameter than 26" rims, you might run into clearance issues with the brake bridge.
Why not use the Karate Monkey, which is designed for 700c wheels in mind.
Or ask surly for their opinion.
Too Much Crazy
Quoted: 116 Post(s)
I appreciate your quick responses though.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
49*.0393 = 1.9ish. So yes you can fit 49's
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Too Much Crazy
Quoted: 116 Post(s)
I already have a 1x1.
I do not have a karate monkey.
Too Much Crazy
Quoted: 116 Post(s)
Originally Posted by jim-bob
Why would you want to do such a thing? It's gonna hose your handling.
How is that? I am not disagreeing just wondering.
I mean, a large volume 26'' 2.7 tire is not going to be far off the circumference of a 29'' 1.75'' tire is it?
Too Much Crazy
Quoted: 116 Post(s)
Originally Posted by ink1373
or just get a pugsley!
Would love too. Wife says 5 bikes is enough though
hateful little monkey
What are you planning on doing about braking?
I'm thinking your best bet is to find a friendly shop with a bunch of fat 700c tires and just mess around to see what you can get away with. Unfortunately, this requires the aforementioned friendly shop.
a 700c wheel has a bead seat diameter of 622mm
so you're looking at a ~63mm (2.5 inch) difference in wheel diameter right off the bat.
I'm assuming you're going to run discs?
Too Much Crazy
Quoted: 116 Post(s)
well a 26" wheel has a bead seat diameter of 559mm
shoot up or shut up.
Bikes: yes please.
my friend had a moots ybb that is designed for 26" wheels, but ran 700c x 35 wheels/tires on it, with front and rear disc brakes. it worked perfectly. he probably couldn't have run a larger tire though, with consideration for mud clearance. with the capability of running 2.7 wide 26" tires on the 1x1 and as cynikal pointed out, a 49mm tire would be 1.9 inches wide. i bet it would work.
See "Da Bizniz At Hand" for Surly's comments on 29" wheels on a 1x1. https://www.surlybikes.com/2005_02_01...ogarchive.html
loves living in the city.
For those too lazy to search the blog:
Da Bizniz At Hand:
A) Several folks have been asking lately about using the 1x1 frame with 29" wheels. Is this on a chatroom somewhere? The answer is yes and no.
>CAN you do it? Yeah. 29er wheels will fit, and even have decent mud clearance.
>SHOULD you do it? No, probably not. Not only will it alter your geometry somewhat (notably BB height), but also, since the larger diameter wheels have to sit further back in the dropouts, you lose a bunch of dropout length normally reserved for tensioning the chain. You may get lucky and choose a suitable gear combo that allows the perfect amount of chain, but this will require quite a bit of playing around with rings, cogs and chains and may still be fruitless. So really, no, the 1x1 is not a 29er. But hey, don't let me stop you...
Oh, and you'll have to use disc brakes if you do this, of course.
A better bet might be to throw a 29" on the front and leave it 26" in back. Better up front traction and a stronger, more torquey rear. It's the latest thing. Better jump on it. Of course the 1x1's geometry will be screwed doing it this way, but it'll only feel weird for a little while. Or longer. But it's not for me; I'm sticking to one wheel size for the bikes I ride (as opposed to my many ongoing experiments), if for no other reason than only having to carry one size spare tube. I'm too disorganized to find more than one spare tube as it is.
Perineal Pressurized
A while back Tony over at IRO (www.irocycle.com) had a pic of the Mia with 29'ers mounted.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Too Much Crazy
Quoted: 116 Post(s)
On tire circumference, according to the schwalbe website, a 26'' 2.4'' tire would have to same circumference of a 700x28 tire (too small to ride offroad).
However, a 700x40 (1.6'')tire would only have an additional 70mm in circumference than a 26x2.4 tire.
70/pi=22.3mm approx. in additional tire diameter /2=11mm in additional bb height and 11mm in additional tire clearance (height) needed. I think 1.115cm seems doable, especially since we are using 26x 2.4'' tires as an example and the 1x1 says 2.7'' is fine.
I am going to try it and let you know how I do. Could be a while to get the parts an build the wheels though.
Thanks for the input guys and gals
BFSSFG old timer
Search the MTBR.com 29er board, it's been done and there are pix out there. You'll get a higher BB, but the rest of the geometry should pretty much stay the same. DH bikes run a higher BB, you might compare it to some of them and see what the numbers look like.
Too Much Crazy
Quoted: 116 Post(s)
I knew I read / saw it somewhere before.
Looking at the pix, I should be more than fine with 1.5-1.75 tires.
