Help! Derailleur wire fixing bolt is loose
Old 08-28-12, 12:57 AM
pyrocyborg
Hi!
Here are the instruction of the front derailleur, just to make sure that you understand what piece I'm talking about (I'm not good at properly defining things like that). By the way, bikes' a 2012 Scott Metrix 40, 1 month old.
My derailleur wasn't properly calibrated anymore, so I turned the fixing bolt of the front derailleur ( they call it "wire fixing bolt" in the manual, in the third section) and tried to adjust things properly and put it together the same way it was. However, now, the wire fixing bolt is loose, whatever I do: I cannot tighten it enough so it could hold the wire as it becomes loose again. As a result, the wire is loose and nothing can hold it in place.
What should I do? Should I insert a nut to try to tighten everything together? I've seen that there were some blue Loctite on the bolt itself... did I broke something and will I need to buy those pieces again?
Thanks
pyrocyborg is offline
Old 08-28-12, 06:43 AM
DataJunkie
Liked 3 Times in 3 Posts
Did you forget the nut? You should have a bolt and a nut. The bolt holds the wire in place against the nut. Usually it is a specially shaped nut.
Meaning bolt, nut, wire, and finally the derailleur body.
DataJunkie is offline
Old 08-28-12, 07:25 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Quoted: 1465 Post(s)
Liked 1,542 Times in 806 Posts
Stripped threads on the bolt? Take the bike to your local bike shop and have them look at it. They may replace the bolt with a new one. Should take them 5 minutes. PG
Phil_gretz is offline
Old 08-28-12, 09:02 AM
pyrocyborg
Thanks... looks like the bolt is stripped... or maybe the nut is (square shaped).
I will bring them the bolt/nuts and see what they can do about it.
jonwvara
Classic & Vintage
4
10-27-16 12:54 PM
ckarr
Bicycle Mechanics
5
10-02-16 01:31 PM
TCR Rider
Bicycle Mechanics
5
02-19-16 08:22 AM
TitanicThompson
Bicycle Mechanics
7
06-06-12 09:41 AM
jonwvara
Classic & Vintage
11
07-22-11 07:45 AM
