Fixie road-bike tricks that anyone can learn
The tricks in the video below can be learned by anyone within a few hours or days. The girl in the video is doing a sport called artistic cycling. Her bike is almost the same as most fixie bikes with the exception of the road bars and pegs.
I find novice videos can be great for learning the basics that help to build a good foundation. Another bonus is that you can do these tricks anywhere there is flat ground—even on the ride to show off a little!
I'll be getting my first fixie in about a week and wanted to share some of the tricks I'll be learning.
Bikes: Mongoose Maurice FS 2011 fixed gear, custom 2017 Haro Master Flatland bmx, Contrast FL475 mid school flatland bmx
Quoted: 15 Post(s)
Liked 11 Times
I ride flatland bmx; I can tell you that some acts are quite easy to learn given that you already have a bit of balancing ability. Through my experience, being able to ride backwards while sitting on the handlebar is a fastlane ticket to some tricks, so does being able to perform the trackstand on a fixie or doing a fakie.
But there are other simple things which may take longer painful journey. If you overcome the painful ones, other good things will come to you quite swiftly. Just don't put too much pressure on yourself or you'll get frustated. And allow yourself good recovery times between injuries. Yes, you'll get those as you're doing all sorts of movements that your body's not used to. Anyhow the reward is priceless.
Like you said, it is extremely rewarding.
When I see people (typically teenager) doing this stuff as they ride towards me on the MUP, I yell. I YELL! I YEEEEEELLLLLLLL!!!!
I like what you're doing -- keep it up. That was just a dumb joke about another thread on this forum: someone got bent out of shape because he saw someone riding without the hands on the bars on a bike path.
Anyways, thanks for the support.
Quoted: 15 Post(s)
Liked 11 Times
If I may suggest, you might want to consider a bit of a protection 'down' there, via a nut protector commonly used by hockey goalies. We have the tendency to hit that part against the tt, stem etc.. Believe me I learnt the hard way!
Likes For acir71:
