Compact pump recommendation?
Old 07-14-06, 03:11 PM
sirthx
I searched a bit but didn't come up with much. My 'Crank Bros' compact pump claims to 'easily inflate to 120 psi' but that's BS. I suppose if you're fresh and properly warmed up and have about 45 minutes to kill you might be able to approach that (assuming you don't bust the stem off in the process, or lose 50 lbs trying to pry the pump off the stem), so I wonder if you can recommend a pump to carry around that can just get me to 100psi or so without too much of a struggle. Smaller, lighter the better, but I'd prefer to stay away from a C02.
Any thoughts greatly appreciated.
-M
sirthx is offline
Old 07-14-06, 03:27 PM
allez
means go
allez's Avatar
Bikes: '06 Pedal Force RS
why?
allez is offline
Old 07-14-06, 03:31 PM
voltman
It is fantastic.
voltman's Avatar
Bikes: 05 Specialized Allez Elite; 06 Fuji Team Pro
You searched and didn't come up with the Road Morph?
voltman is offline
Old 07-14-06, 03:36 PM
Nubie
Nubie's Avatar
Bikes: 2021 Specialized Diverge Carbon Comp, 2020 Specialized Roubaix Expert, 2020 Specialized Creo Expert
Quoted: 13 Post(s)
Liked 3 Times in 3 Posts
Now Topeak makes a "Mini Morph" that's even smaller than the road morph and has a bracket that attached to your braze-ons.
Nubie is offline
Old 07-14-06, 03:42 PM
TSUTexan93
Bikes: Trek / CCM
The Road Morph w/gauge or mini Road Morph w/o gauge are both awesome. I have the regular Road Morph because I wanted the gauge. It is only like 1 5/8" longer than the mini but does have a different mounting bracket.
TSUTexan93 is offline
Old 07-14-06, 04:07 PM
johnny99
Quoted: 104 Post(s)
Liked 5 Times in 5 Posts
The mini-morph is not bad. It is half the size and weight as the regular road morph, but it does take twice as many strokes to pump up your tire. If you don't get many flats, it is a reasonable compromise.
johnny99 is offline
Old 07-14-06, 04:32 PM
bilydu
Island Time
Bikes: 2002 Giant TCR 1
i agree with the topeak road morph, i use it and love it, easy to get to high pressures and fast too, the gauge is a nice plus
~bilydu
bilydu is offline
