Does anyone use wing mirrors?
#51
ya, thanks on the adapter referral (dont need one, but might one day)
and also on noting that the compact is a more rectangular shape, I didnt notice that as I was only looking at the rod lengths.
would be interesting to try a compact one day.
I still think the Take a Look design is so elegant, simple, sturdy and so adjustable, both the mirror and the three point mounting areas.
A great product.
here is a well made diagram showing how versatile it is for changing its position in all kinds of ways. It is completely adaptable to all sorts of riding positions, helmets, glasses, shoulder size, you name it.
https://www.bikepeddlerbikeproducts.com/events
A great product.
#52
Quoted: 623 Post(s)
Liked 396 Times
I used the Take A Look for many years. I was looking for tools online and saw the EVT Safe Zone Bicycle Helmet Mirror. I did not like helmet mirrors until I used this one. It has a 2 1/2" round mirror.
#53
My problem with mirrors that size is that they are too big of an object in my field of view looking forward.
#54
I use the Ortlieb 'Ultralight' mirror. It's super-light so road vibration does not routinely dislodge it - only once in awhile - the ball joint maintains its position. However, being 'ultralight' means that the hose clamp is plastic on which a metal worm-screw rides - you can only tighten it so much before the metal screw just shreds the plastic hose clamp. Despite this it mostly stays put - a little electrical tape would help. The mirror is convex - takes a little getting used to.
Another possibility that I am considering is the Busch and Muller mirrors (lower photo). They have different length arms and supposedly come with hardware for mounting bar-end or attached around the handlebar. https://www.peterwhitecycles.com/mirrors.php
#55
I really like the Ortlieb Ultra Light. I put one on my Surly LHT, and one on my wife's old mountain bike with trekking bars last spring. I tried using a helmet mirror a few years ago, but got a headache everytime I rode with it.
#56
#57
I'm about to purchase the take-a-look but I am unsure which to go for - the compact or the original. I am based in the UK so I will be using it on the right-side and I read in a comment section on a webpage the following:
We’ve been told that the Original mirror can only be fixed on the right hand side of the helmet or glasses, whereas the Compact mirror doesn’t go on the helmet at all, just on glasses, but you can swap sides with this one.
This seems a bit of odd information about the Original considering the main market for this is USA.
I'm trying to find an email address for take-a-look but cannot find one even on their website. Does anyone know how to contact them?
#58
read and watch video here, it is very clear how it works on both sides
Its a brillant and simple and robust design
Take-A-Look Mirror | TravellingTwo: Bicycle Touring Around The World
#59
#60
Quoted: 318 Post(s)
Liked 149 Times
I measured the arm on my original and the length (excluding the clip and excluding the mirror) is about 3 and 1/2 inches. Just eyeballing it. it looks like the arm on the compact is an inch and a half shorter. The mirror surface on the compact is smaller, but it's closer to your eye, so not sure if the image is about the same size? I really have to find one to try.
#61
I have the original and I'm using it on the left (as pictured a couple weeks back here above). I could have used it on the right; it works on either side, but I'm in the USA so the left side it is.
#62
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
There was a guy at NAHBS selling heavy duty tools, and he had helmet mirrors with stalks made from the oil squirter tubes used on lathes and mills. I can't speak for or against it except it looked like a neat idea. Wish I could figure out which company... can't find it now.
Genesis 49:16-17
Genesis 49:16-17
#63
here is a side shot of mine, perhaps it is a compact, as the length seems to be shorter than the last photo.
3 inches from first mounting point rubber thing to the 90 degree bend where the mirror is.
#65
I see now that the compact has a more rectangular mirror, mine is slightly rectangular, but the compact has a wider rectangle, which I can see from experience would be handy to have a wider view.
As to the shorter rod, I would have to use one to see how that is, although I think its reasonable to say that if you attach this to a helmet visor edge, like I do, then the actual distance from your eye will be diff from helmet to helmet.
Mounting it on eyeglasses may be a different matter, but I have never done this.
I do know I put a slight bend to the main "rod" on mine to have a slightly outward position, to see a bit better past my helmet or shoulder. Perhaps a compact on glasses would be a bit too far inboard--but this is a guess on my part, it could be perfectly fine.
#66
it protrudes less from your head so I snag it far less. It’s much close to the rim of my helmet and I think that’s the reason.
The shape of the compact is more rectangular so it gives, IMHO, a better view behind. You don’t need vertical space on the mirror, you need horizontal space which limits head movement to a degree.
The rectangular shape seems to be less invasive in forward field of view.
Ive tried the regular a few times again but I always come back to the compact and find I like it far and away better.
#67
As far as I can tell, the store that sells them here in Montreal only has the regular, but I will keep an eye out for the compact version. Mine must be 9 seasons old now, and lots of trip time in there also, so I would purchase a compact if I could find one.
Good sales job in any case.
#68
very good point about less head movement. I can very much see how this would be an advantage.
#69
found these details of dimensions (cant speak for accuracy)
-Available in two sizes: compact, which extends 50 millimeters and has a mirror size of 20x37 millimeters (HxW) and normal, which extends 85 millimeters and has a mirror size of 28x37 millimeters (HxW).
and just measured my mirror, its 27mmx35mm
so it would appear that both have mirrors that are the same width, 2mm longer than my old one, but they diff in height of mirror--so ultimately, they have the same side to side view, but the shorter compact one may be less obstrusive to peoples vision.
AND as the main rod is shorter, still not sure if for me this would be better or worse.
- Overall Length: 87mm (shorter than the Original)
- Mirror Dimensions: 37mm x 17mm.
#70
The shorter mirror works a lot better for me since it’s not sticking out so far. I also wear prescription glasses and have no issues with that either.
They are about $15 on amazon so it’s a pretty small risk and it is returnable.
REI also carrries them, IIRC. Their return policy is legendary.
Have you checked your LBS? I know mine carries them.
#71
any mirror, or changing mirrors takes a bit of time to adapt.
Simpler easier and less expensive to buy a compact here.
Thanks for reply though
#72
#73
I've always found my body takes away any vibrations, but then maybe I have a soft head, which people have inferred over the years, so it could just be that.
#75
another opinion here, I've always used them attached to my helmet visor and have never had an vibration issues, unlike the various handlebar/hoods mounted mirrors that I've used going back 25+ years.
