high power readings on brand new Garmin Vector 2S
Old 07-25-15, 10:20 PM
petermk
Bikes: Wilier Gran Turismo 2013
Hi all,
I just installed Garmin Vector 2S power meter pedals and saw pretty high power numbers when tried it on my Kinetic Road Machine 2 trainer. I am a casual weekend rider and my estimated power on Strava is usually 130-150 watts. When I tried the Vector, my power never went below 300 watts and I was doing only around 70 rpm and 16-17 mph. The Vector has the latest firmware (v3.50), I set the installation angles and calibrated without any problems, my head unit is Edge 810. What could be wrong?
Thanks
petermk is offline
Old 07-25-15, 10:56 PM
gregf83
Quoted: 1186 Post(s)
Liked 289 Times in 177 Posts
Did you tighten the pedals with a torque wrench to the recommended values?
gregf83 is offline
Old 07-25-15, 11:02 PM
MattFoley
MattFoley's Avatar
Crank length is set correctly, and not just the angles?
MattFoley is offline
Old 07-25-15, 11:38 PM
petermk
I used a regular pedal wrench, as Garmin says that overtightening a bit is fine. Undertightening might result in lower power numbers but it's not the case here.
The crank length is manually set in the Edge to 172.5, which is what I have.
petermk is offline
Old 07-26-15, 12:30 AM
kingfishr
kingfishr's Avatar
Bikes: Ridley Noah, Trek Emonda, Colnago C59, Colnago Master, 1980 Colnago Super, Wilier Blade
I have had garmin pedals for a couple of years, and recently purchased the Vector-S. Proper torque is crucial. Twice in the installation page of the owners manual Garmin repeats: Garmin recommends torque of 25-30lbf-ft (34-40 n-M). And every power reading issue I have had has been due to improper torque.
kingfishr is offline
Old 07-26-15, 08:27 AM
mkadam68
mkadam68's Avatar
Bikes: 2012 MotorHouse road bike. No. You can't get one.
Liked 9 Times in 6 Posts
Well this is one area you can improve on...
... my estimated power on Strava ...
Online power calculators are rarely (ever?) accurate. Don't compare anything with them.
Also, proper torque, as said.
mkadam68 is offline
Old 07-26-15, 08:45 AM
RChung
Perceptual Dullard
Quoted: 915 Post(s)
Liked 1,132 Times in 488 Posts
I just installed Garmin Vector 2S power meter pedals and saw pretty high power numbers when tried it on my Kinetic Road Machine 2 trainer. [...] What could be wrong?
Presumably you bought one-sided pedals because you believed that accuracy doesn't matter. So there doesn't appear to be anything wrong.
RChung is offline
Old 07-26-15, 10:17 AM
petermk
I reset the installation angles this morning while on the road, recalibrated twice and everything seems to be normal now. Thanks, everyone.
petermk is offline
jason70
7
10-01-16 09:26 AM
chong67
7
09-22-16 09:37 AM
Plainsman
Road Cycling
5
09-12-16 03:18 PM
spessx
"The 33"-Road Bike Racing
11
02-15-12 12:36 PM
steaktaco
Road Cycling
6
04-02-10 01:37 PM
