Head tube cable stops
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
When did cable stops on the head tube first start to appear? Asking for a friend.
https://utahrandonneur.wordpress.com
Quoted: 2363 Post(s)
Liked 1,749 Times
Can't say I've ever seen one. :shrug:
Quoted: 1136 Post(s)
Liked 650 Times
Richard Sachs and Waterford are probably the most notable for their current use of them in the brifter era, but I'm sure someone did it in the bar-end era.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
For those wondering...
image from Ceeway's website.
This one's cast into the bottom lug. I'm sure someone must have brazed them on prior to availability.
I'm going to guess it was sometime in the 90s after the introduction of brifters. I don't recall seeing them ever during the bar end era (which in reality was the DT shifter era).
However, it is very possible some custom builder brazed on head tube stops long before that. In fact I'd be surprised if someone hadn't. I've worked on a lot of bikes, but haven't seen everything.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I've got them on a 2000 LeMond, though obviously they appeared earlier than that. Frankly, they're a bit inconvenient even with brifters because they tend to put a shift cable in conflict with the front brake cable.
My Bikes
My Bikes
blahblahblah chrome moly
Quoted: 1172 Post(s)
Liked 2,567 Times
Specifically centerpull cables, including cantilevers. Bad combo -- the centerpull cable kinks the shifter housings at the braze-on, when the bars swing to the extremes on either side. You never do that while riding of course, but it'll inevitably happen while transporting, parking etc.. No so much of a problem with sidepulls, including dual pivot.
Late '70s, early '80s, place I worked put them on a few custom racing bikes that were going to use bar-end shifters. Obviously the customer had to be pretty sure they liked bar-ends. We knew not to do it if the brake was a centerpull.
Advantage was the bar-end cables don't rub the paint on the head tube when you swing the bars from side to side.
A variant was stops on the DT, but rings on the HT to corral or guide the housings, again preventing paint rub. Still a no-go with centerpulls.
Mark B in Seattle
Mark B in Seattle
Bikes: Yes
Liked 3,868 Times
Specifically centerpull cables, including cantilevers. Bad combo -- the centerpull cable kinks the shifter housings at the braze-on, when the bars swing to the extremes on either side. You never do that while riding of course, but it'll inevitably happen while transporting, parking etc.. No so much of a problem with sidepulls, including dual pivot.=13.33px
My Bikes
My Bikes
Quoted: 18371 Post(s)
Liked 4,507 Times
My Argos has bell shaped head tube cable stops. The idea is that it allows the ferrules to pivot when one turns the steering. I'll try to get some close-up photos soon. I haven't ridden the bike much as I had intended to do some updates on it.
This is an older photo from when I bought it.
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
Found this pic from a 1989 Sancineto, so at least the late 80's!
Liked 1,749 Times
^^^^^ Except those are more guides, than stops.
bocobiking
My 2003 Serotta. Both my Serottas came with them. No brake cable interference. I just had some put on my new Gunnar. The cables don't wear the paint on the head tube the way they do with downtube stops.
