Tubeless or not?
Tubeless or not?
Old 08-08-20, 07:49 AM
  #276
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Originally Posted by guadzilla
Ha, yeah... i have 2 stealth Rovals. Need something more bling
So i did dig into the Zipps a little more after your review. In the end, dont see the point. I will be putting them on a gravel bike with a 34-35mm wide tires. Since the OD of these rims is a lot lower, I am going to pay a pretty hefty aero penalty with the bulbuous tires. Given that, i might as well save a bunch of money and get a Light Bicycle wheelset instead. Or bite the bullet and go BIG with the 3T Discus wheels. 45mm deep, 40mm wide. It's about the girth these days, anyway.
Yeah - for gravel I would probably go wider, maybe even 650B.
Sure, LB were pretty tempting to me, also. In the end, availability in covid times played a big factor as did the lifetime warranty, not only for manufacturing defects but also for mild boneheadedness. I'm not completely inept, and I do have a spoke tensiometer, but it's nice to be able to send the wheel off for a rebuild if a spoke breaks rather than replace and maybe chase additional breaks.
The other major bonus for the Zipps - SO divisive. With many other brands, I'd have to explain who they were, where they were from, how much I paid, etc, etc and, even then, most people still wouldn't be sure if they should hate/love me and/or the wheels. I can't live with that kind of indifference.
WhyFi is offline
Likes For WhyFi:
Old 08-08-20, 12:28 PM
  #277
guadzilla
Pointy Helmet Tribe
guadzilla's Avatar
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times in 295 Posts
You definitely should NOT be waving while riding them.
guadzilla is offline
Old 08-08-20, 12:29 PM
  #278
WhyFi
WhyFi's Avatar
I don't, not unless I see an arm band.
WhyFi is offline
Likes For WhyFi:
Old 08-08-20, 01:59 PM
  #279
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
Wait. Isn't Rapha the only item/article that's allowed to claim that distinction?
NoWhammies is offline
Old 08-08-20, 02:22 PM
  #280
WhyFi
WhyFi's Avatar
I got the trifecta, bro - Cervelo, Zipp, and Rapha. If people don't cheer me, they jeer me.
WhyFi is offline
Likes For WhyFi:
Old 08-08-20, 07:18 PM
  #281
sfrider
Asleep at the bars
sfrider's Avatar
Quoted: 234 Post(s)
Liked 203 Times in 135 Posts
Ha, I've got a Cervelo, ENVE SES, and Rapha. Maybe that's why every non-cyclist, overweight gym rat on a flat bar bike has to prove they're faster than me.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
sfrider is offline
Likes For sfrider:
Old 08-10-20, 02:42 PM
  #282
shona
Quoted: 47 Post(s)
Liked 5 Times in 4 Posts
Need info on tubeless
I just jumped into this thread. At the suggestion of somebody I just got tubeless tires put on my road bike. Yes, I know nothing about them. My main question is how much pressure should I have in them? In my tube tires I ride on 100. Also, can I add air using the tubeless valve? I have many more questions but I'll keep it to these two for now. Thank you,
shona is offline
Old 08-11-20, 05:23 AM
  #283
Trsnrtr
Super Modest
Trsnrtr's Avatar
Quoted: 10963 Post(s)
Liked 4,619 Times in 2,123 Posts
If you've been running 100 on regular tires of the same width, you can probably run 80 but you might want to try 85 first just to see how much deflection there is in the sidewall and yes, you air up just like a tubed tire.
Keep the chain tight!
Trsnrtr is offline
Old 10-06-20, 09:19 PM
  #284
sshakari
sshakari's Avatar
Bikes: Canyon Endurace, Merckx liege 75, Cinelli Vigorelli
Quoted: 167 Post(s)
Liked 114 Times in 61 Posts
Had my tubeless setup for about 6 months. Initially, I put the recommended amount of sealant and 3 months later another 1 oz. Wondering if it is time to add more or take the old sealant out and just put fresh?
I've ridden about 1200 miles and don't know how many flats I had. I used to get a flat every other ride, now I don't pay attention. I am also asking because I have the Dura Ace C40 wheels and Shimano says not to use tire levers. Im sure I can just insert a tube and pull the old sealant out without taking tires off or its just as well to add another dose and deal with it later?
sshakari is offline
Old 10-07-20, 06:09 AM
  #285
shona
Quoted: 47 Post(s)
Tubeless or Not
I have been told to add sealant every three months.
shona is offline
Old 10-07-20, 06:58 AM
  #286
WhyFi
WhyFi's Avatar
With your previous flat frequency, you're probably due (or overdue) for some sealant at that kind of mileage. Leaving the tires in place is certainly the most convenient. If your valves will allow a sealant syringe tube to pass all the way through, it's best to suck it out and a) see if it's still in good shape (watery/thin is no good - it should be more like the consistency of half & half) and b) how much is left.
For some people, that might be overkill. For others, it could leave them without puncture protection after the first 4-5 weeks. You really should check it if you don't want any surprises on a ride.
WhyFi is offline
Old 10-07-20, 07:04 AM
  #287
Trsnrtr
Super Modest
Trsnrtr's Avatar
I use a syringe through the valve body and did a fluid check last week after 3 months and a 1,000 miles or so. They started with 2 oz and were down between 0.5 oz. and 0.75 oz. since I had already sucked the used fluid out, I put new in. Took all of 15 minutes.
Trsnrtr is offline
Likes For Trsnrtr:
Old 10-07-20, 08:22 AM
  #288
crazyravr
Bikes: 1 for road & 1 for gravel
Quoted: 146 Post(s)
Liked 33 Times in 28 Posts
I went TL this summer. It was great until I recently got a flat. It was a cut in the tire that sealant would not seal, but it did let me get home 5km. That made me realize how much simpler it would be to stop, replace tube, pump and go. No more TL on road bike for me.
crazyravr is offline
Likes For crazyravr:
Old 10-07-20, 08:44 AM
  #289
WhyFi
WhyFi's Avatar
How big of a cut? And what sealant were you using? Did you have plugs?
WhyFi is offline
Old 10-07-20, 03:47 PM
  #290
sshakari
sshakari's Avatar
Quoted: 167 Post(s)
I did the same. Very simple and worked like a charm. Pulled old out & topped with new 2oz per wheel. Cheers!
sshakari is offline
Old 10-08-20, 08:01 AM
  #291
crazyravr
Quoted: 146 Post(s)
Stans sealant. 1/8-1/4" cut. I tried to plug but they popped out. I added more sealant at home hoping it would seal up. Nope. Went back to tubes and will deal with the few punctures I get per year over my 10K km + riding.
Old 10-08-20, 08:33 AM
  #292
WhyFi
WhyFi's Avatar
Stans sealant.
Well, there ya go.
WhyFi is offline
Old 10-08-20, 09:27 AM
  #293
Pizzaiolo Americano
Pizzaiolo Americano
Bikes: 2021 Trek Domane, Bianchi Intenso, Specialized Epic Evo, Surly Ice Cream Truck, Some other stuff
Quoted: 287 Post(s)
Liked 140 Times in 69 Posts
Well, there ya go.
Yep. Stans does not work great at higher pressures. I use it on MTBs but use Orange Seal on road bikes.
Pizzaiolo Americano is offline
Likes For Pizzaiolo Americano:
Old 10-08-20, 09:50 AM
  #294
WhyFi
WhyFi's Avatar
I honestly blame Stan's for about 80% of bad reputation that road tubeless has. Generally, people are willing to put up with a little futzing here and there if something works as advertised, but when early road tubeless adopters had piss poor results when carrying over Stan's, it just started the chorus of "tubeless is great for MTB but doesn't work for road!"
WhyFi is offline
Old 10-08-20, 10:20 AM
  #295
Pizzaiolo Americano
Pizzaiolo Americano
Quoted: 287 Post(s)
Well, there ya go.
Honestly, I was one of those. Rode tubeless MTBs for years using Stans. Once I decided to go tubeless on my road bikes, I had issues with it not sealing. I almost went back to tubes but tried Orange Seal on a whim (and maybe some advice here) and was happy. It works great at high pressure.
Old 10-08-20, 12:41 PM
  #296
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
I was one of those guys. 23mm tires, high pressures, and Stan’s sealant just doesn’t work. Now I love tubeless road. 23mm internal width hoops, 30mm tires, 60psi, and TruckerCo cream II works great.
noodle soup is offline
Likes For noodle soup:
Old 10-08-20, 01:08 PM
  #297
DangerousDanR
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times in 306 Posts
+1 on using Stans and failing, but working fine on Orange Seal. And I run 105 PSI because even after a major weight loss I am still at a slim trim 105-110 kilograms.
DangerousDanR is online now
Likes For DangerousDanR:
Old 10-09-20, 08:17 PM
  #298
fried bake
Quoted: 43 Post(s)
Liked 21 Times in 11 Posts
So the Schwalbe Pro One TLE are on their way out. 900 miles and I think that, while a good intro to tubeless, there are probably better out there. The good: Sticky, grippy, sponge cake armchair ride. The bad: random rear tire failure (no cuts) with a sidewall leak while descending. Still no idea what caused this to happen. Anyway, installed a tube which lasted just a couple rides before another puncture. And, at that point, it was time for a change.
Today I installed the Hutchinson Fusion 5 Performance11 Storm (who names these?) and went on inaugural ride. Mounted them right out the box with only a single tire lever for the last bit. They inflated and held air straight away with floor pump. So, easier to mount than the Schwalbe, even though they feel thicker, less supple in hand. As for the ride: no discernible difference in ride quality (which is a good thing) but I’m hoping for better reliability. Will report back after a couple hundred miles but so far I’m pleased with the decision. Shipped in two days from Merlin, and still cheaper than anywhere in the USA (even with the $27 shipping fee).
fried bake is offline
Old 10-09-20, 08:36 PM
  #299
WhyFi
WhyFi's Avatar
I was riding those Hutchinsons prior to the Pro One Addix TLE. They were fine, but I think that the Addix have a more supple ride and, on two occasions, with two different tires, they did take cuts that were just a little too large to seal on their own; it could have been coincidental, but those are a rare experience for me, so the fact that two took the same kind of damage was suspect.
WhyFi is offline
