Help with new Trek bike
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
I still don't see an explanation for why this is the second SRAM bike that's been leaking hydro fluid from faulty installation. Whether the rotors need to be replaced or not is a very secondary concern to that, or would be if it were my bike.
Bikes: 2020 Pinarello Dogma F12 Disc (Enve SES 3.4), 2021 S-Works Aethos (Roval Alpinist CLX II), 2024 Topstone Lab71 (Terra CLX II), 2006 Cervelo Soloist (10 speed Ultegra), 2021 S-Works Epic
Quoted: 74 Post(s)
Liked 74 Times
I have three bikes with AXS Red. I have a number of friends with either Red of Force. None of us have had any issues with the brakes. Come to think of it, I've never had any issues with any SRAM brakes. I really don't think it's a defect, though of course my data points don't negate that possibility. It sounds like the pads got contaminated to me.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Looks like Shimano has also had problems with brake recalls.
https://www.cpsc.gov/es/Recalls/2013...brake-calipers
Quoted: 1067 Post(s)
Liked 259 Times
"SRAM Hydraulic Road Rim Brakes" Seriously? I didn't know anyone made hydro rim brakes.
I can’t believe that someone who spent 14k USD for a high end project one Trek bike has to go through all this troubles 😳 When I bought 2020 Domane SL5 which is not even close in terms of price and I was not impressed with dealer service I received I returned the bike, took money and bought the bike from other trek dealer.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Also there's the fact that the shifting apparently sucks.
Likes For Bah Humbug:
On Your Left
Liked 2,433 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
Knowing a little more about them would help narrow it down. For Shimano, an inline connector points to factory fluid fill and pre-bleed - these would be pretty hard for even an LBS grunt to muck up. If there aren't any inline connectors, I would assume that the hose fitting/install and fluid fill was done at the shop.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Liked 9,456 Times
Yup. Again, I haven't played with SRAM, or even looked at an install manual, but I would have to assume that the connections are roughly identical. The only way that I could see things being more problematic would be something along the lines of port placement/angle - something that might make it more awkward/difficult to get the hose/connectors in squarely and securely. Also, I suppose that something silly like parts specs that are slightly different than Shimano could be problematic if the LBS wrench isn't paying close attention and they grab the wrong olive or barb or something.
Quoted: 74 Post(s)
Liked 74 Times
Trying to be helpful to the OP, there is nothing fundamentally wrong with the SRAM brakes you have. New pads should do it. You should probably insist on new rotors for good measure. No reason for you to accept resurfaced rotors at this point. As for the shifting, that’s also easy to fix. Again, there is nothing fundamentally wrong. For a competent mechanic, both issues would be easy to resolve don’t throw the baby out with the bath water.
No reason to demand new stuff forufor no reason just to make a point
Do you have the older version of SRAM Red brakes? I do, and they suck from a noise and maintenance standpoint. The newer version are suppose to be better. Mine would regularly have the pulsating feel.
In the end, the design on my version is flawed. The pistons do not release the full distance on both sides. I can't tell you why, I just know it's true. I'm about to get mine replaced under warranty. I buddy of mine is on his 3rd set - all replaced under warranty.
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Quoted: 110 Post(s)
Liked 203 Times
My 2016 Domane Series 6 was leaking brake fluid from the front brake lever and always needing bleeding to keep it stopping. I finally pulled the hood and could see the fluid was coming from the reservoir cover and I thought a bad seal or something but the seal was installed a little off the sealing area. My guess is that someone , at some point, opened the reservoir thinking that is where you add fluid and misassembled it. Back together now and seems fine, time will tell.
"ready to navigate"
"ready to navigate"
I built my first Project One Domane with Sram Red three years ago. I suggest using organic brake pads and bed them in. Never had any of the problems you list. I got my second Project One bike last year when someone ran me over and their insurance company was all too happy to buy me a new project one bike (plus). So I now have the exact bike you have with the exception of a ENVE 4.5 wheel upgrade. It's not the bike or components it's the folks servicing it. No excuse whatsoever for poor shifting with Sram Red Axs ( assume all new Domane Sram are now AXS), as this is a dead give away it was never set up correctly as the micro adjust is very good and simple. Over 5K plus on the new bike and no new adjust needed yet. Perfect shifts everytime. Also the Sram Red Axs allows you to set it up where the front derailleur shifts automatically so cross chaining is impossible unless you disable it. I belive one push on the right shifter side button cycles this on and off. Another tip. When washing the bike,do not use car soaps or cleaners as they can leave residue on the pads and routers. I only use Dawn dish soap and very rarly hear any brake noise at all. Maybe twice in the rain so far. Although I set up my own bikes, at the prices paid, I expect and am pleased with the quility and performance of the bike and the components. You should expect this bike to be set up perfectly and if you are new to bedding brakes the shop should be thrilled at doing it for you. I'm guessing typical retail margins are in the $1,000.00 for that bike. I have also talked to some great folks at Trek for advise and belive they will not stand for such poor set ups of one of their flagship bikes. I'm hoping, by now, all this is resolved, if not, start video taping the problems and send that to Trek. I'll bet you anything you'll get a call from someone that can fix them for you ASAP.
I would recommend leveraging social media, especially Twitter, to document your journey here. This is the worst "negative"PR that Trek or SRAM could ask for. Be fair, document every phone call and trip back to the shop. Take pics and video.
If they truly cannot remedy this to be 100% perfect for $14,000 (or hell, $3000) you should NOT accept anything less than perfect.
You are way beyond replacing brake pads at this point, they need to be replacing entire components and...if necessary...the entire bike.
