Applying Chamois cream
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
After being off the bike for an extended period of time (think years and 80 lbs of weight gain) and I can absolutely feel it after a ride of an hour to an hour and a half. When I was riding a lot, I probably could have ridden on a split log for hours after developing a taint of iron after hundreds or thousands of hours in the saddle over the years.
So, in my opinion, yes, you'll feel it for a little while, but the muscles will adjust and strengthen. Eventually you will have an iron taint too.
Likes For Andy Somnifac:
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
I'm not sure that calluses are in order, but there's definitely a period of acclimation that you go through.
I just think that the acclimatization is built through riding and getting the sit bones used to the pressure. The chammy cream helps with friction/chafing - removing that doesnt help with acclimatization, IMO.
Likes For guadzilla:
Quoted: 741 Post(s)
Liked 412 Times
I was watching one of those Ask A Coach episodes from TrainerRoad and their position was that if you are needing to use cream every ride that probably have a fit issue of some sort.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
That's probably more due to the 80 extra pounds than anything else... Stuff's gonna rub when it's a tight squeeze! Fortunately, getting back on the bike will eventually have that taken care of all by itself!
Likes For sfrider:
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
I took 40 lbs off already, so we're only 40 up from my low, which has probably lower than strictly necessary. I had gotten down to 137kbs @ 5'9". I'm now a shade under 180. So, while I'm heavy, I'm not like morbidly overweight. I'm shooting to settle in at 150.
