Totally Tubular
#1526
“Senior” Member
On the earlier comment on Pit Stop ... I tried a couple of cans of it. It sealed a slow leak once for a Tufo well, but on a Corsa tire after a flat it worked for a few rides but not for long, Same hole opened back up later so just unsewed it up and repaired it normal the old way.
#1527
Quoted: 758 Post(s)
Liked 647 Times
A couple of beginner tubular questions:
Vermont roads--even paved ones, of which there are not many--tend to be rough. The narrowest clinchers I use are 28mm, so I'd like to start with some wide, relatively low-pressure tubulars. I can't see 22mm tires pumped up to 140 psi working out well for me. What's a good beginner option in a wide tire, preferably a butyl-tubed one?
Will tires of that width fit well on an early 70s rim that was probably designed with 22-24mm tires in mind? I can't give an actual width, because I don't have the wheels in hand yet.
Also, is anyone here riding on a set of Tufo HICC 28s? They seem to be reasonably priced--an important criteria for me--but I can't find much information about them.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
#1528
Bikes: many
Quoted: 1435 Post(s)
Liked 1,363 Times
My Redcay has 25mm Vittoria Rally tubulars (substantially cheaper than the Veloflex tubulars). Can't recall the rims at the moment, but again, no problem.
I'm not sure there is a truly wide tubular tire at an entry level price point. I get Vlaanderen for about $60 on sale. The Rallys can be found for about half that. I would be happy to ride my Redcay on Vermont roads.
I wouldn't worry about latex vs butyl tubes. The time it takes to bring the the up to pressure before a ride is minimal. In my mind, the improved ride is worth it.
#1529
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 170 Times
#1530
Quoted: 758 Post(s)
Liked 647 Times
I did a motel to motel tour of around 400 miles in New England (including VT) last fall on Vlaanderens and had no problems at all. I used rear panniers. We rode mostly on pavement but some hard pack and some gravel rail trail. I’m not obsessive about tire pressure and guess I was riding them at something like 70-75 psi using a thumb test. At home I pump them to 60psi up front and 75 in back and they are very comfortable. I weigh 170.
--Ogden Nash
--Ogden Nash
#1531
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
#1532
mycocyclist
Quoted: 901 Post(s)
Liked 802 Times
Two Sides
No it is not tubular specific but it comes recommended in a YouTube by “Caden” an Australian wheel builder who swears by this (generic version) of 3M double sided tape. I’ll double check the width and marking on the tape. In the video he explains the advantages of being able to position your tubular tire properly before peeling back the wax paper then inflating the tire.
As as far as my wider than normal Velocity Major Tom rims, I’ll try different tires and hopefully find some that are road specific that don’t end up with a gap at the base tape. 27 to 30 mm would be ideal and hopefully clear whichever frame I ultimately run these on.
Viewed the
#1533
Quoted: 1158 Post(s)
Liked 439 Times
Hmmm,
Viewed the video I suspect you reference, and right at the beginning he says it is a "new" tape by 3M specifically designed for tubular tyres. His shop's store offers it for sale. The video was posted in 2017.
#1534
I ride Vermont gravel daily, and the Vlaandaren is my favorite tubular for that purpose....70-80 psi, I weigh 175. Light, surprisingly tough given how soft the sidewalls feel-- a great riding tire. Not cheap, but you can find them for $50-60 on sale, which isn't terrible.
I used to use Tufo tires when I first started with tubulars--- those things felt like bricks by comparison. I still have one untouched, sits in my spare bag, hope I never have to use it....
I've been pretty lucky with "soft" sidewalls--- I guess the ad guys would call them "supple". Only one major sidewall cut in the last 5 years, on a 3 day old pair of Soma Supple Vitesse clinchers. I repaired the sidewall with dental floss, rubber cement, and a piece of an old tire as a boot--- still holding!
N
N
#1535
Quoted: 2304 Post(s)
Liked 2,742 Times
gluing tubular tires to rims is not a place I would prefer to cheap out on. ymmv
#1536
Quoted: 48 Post(s)
Liked 138 Times
Splurged and purchased an Rene Herse service course 25mm. I have about 250 miles on it. Ridden on streets, dirt, gravel. Running just on the front wheel. It's pretty dang nice at about 80 psi. Recommended. Waiting for the roubaix to get back in stock to put on the rear.
#1537
Quoted: 758 Post(s)
Liked 647 Times
Jantex tape release strip?
For my first venture into tubulars, I've pretty much decided to go with Jantex tape, rather than glue. (I was interested to find that it's been around for longer than I'd thought; Eugene Sloane recommended it by name in the 1970 Complete Book of Bicycling.)
I've read several reviews where users have complained about the tendency of the paper release strip to tear when pulled loose from under the newly-positioned tire. That sounds really annoying. But I also found one mention that the old paper release strips have recently been replaced by a tougher and more reliable plastic strip. Is this the case? I'd be interested to hear from anyone who's had some recent experience with this product.
--Ogden Nash
--Ogden Nash
#1538
Bikes: 1973 Schwinn World Voyageur | Francesco Moser SL | 1984 Ross Utopian | St. Etienne 531 | 1981 Peugeot PK10 | 2015 Cannondale SuperSix | 2012 Felt F65X
Quoted: 54 Post(s)
Liked 51 Times
+1 on the Vlaandaren. I have run them on Mavic GP4 rims, Campy hubs and the supple is real. I also run Stan's in them as I have had good experience with Stan's sealing on a latex tube.
I am now to the point that I run latex + Stan's in my clincher setups particularly with VO/Rene Herse lightweight tires to get that same supple feel that is great on chip seal roads.
#1539
Liked 2,742 Times
any one have any experience with vittoria corsa control? theoretically the replacement sorta for the beloved Pave?
I am about to pull the trigger on a second wheel set for the 85 team miyata...the current clincher conti gp 5000 in 28 are pretty good, but still want to go tubular for a number of reasons
#1540
Liked 2,742 Times
and one more any love/hate for conti sprinter gatorskin?
#1541
Quoted: 345 Post(s)
Liked 170 Times
#1542
Quoted: 1924 Post(s)
Liked 1,954 Times
I have had great experiences with the Gatorskin. They were my first Tubulars (size 22s) 9 years ago because they had a reputation of being the most durable and I didn't want to be repairing my first pair of tubulars if it was avoidable. I didn't know any better and they rode fine. Then I got a pair of Gatorskin 25s to do the BWR which is a mixed terrain event and I was very pleased with their durability. If your objective is to experience the smooth ride that fine tubulars are known for, the Gatorskin is not your tire. Continental Competitions were smoother (but a ***** to mount) and my nice tires now are the Vittoria Corsas. I plan to do the BWR again next year and I will get a new pair of Gatorskins unless someone can convince me that the Corsa Control as sidewall protection that comes close to the Gatorskin's.
#1543
Quoted: 48 Post(s)
Liked 138 Times
#1544
Veteran, Pacifist
Quoted: 3876 Post(s)
Liked 4,781 Times
I found a large can of mastik (unopened), so I may be gluing for a while. Rhetorically: how does a guy misplace a good sized can for 2 years?
#1545
They ride absolutely fantastically. But, they’re ridiculously expensive, are nearly impossible to actually REPAIR. The Tufo tape makes them easier to mount, but if you use tubular glue they’re a total pain in the ass. But, boy they sure ride fantastically.
#1546
Bikes: many
Liked 1,363 Times
Sorry, "they" being what? I found the Veloflex Vlaanderen tubulars on my Griffon to ride fantastically today.
I made this plea in another long-running thread, but I'll make it here as well. If you're responding to an earlier post in the thread, it really helps if you quote some part (even an itsy bitsy teeny weeny part) of that message. We are discussing many different brands and models of tubulars (and occasionally clinchers when someone goofs), so knowing what specifically you're writing about is helpful.
Likes For smontanaro:
#1547
Liked 2,742 Times
Refer back to post #1517 and a few after? Is that the tire you are asking about?
#1548
Liked 2,742 Times
I was about to measure my current tires to check for clearance options for replacements and realized I had no idea of what the 'standard' is for measuring tires. How do you measure a tired.... caliper for width or height or??? thanks
#1549
Bikes: many
Liked 1,363 Times
squirtdad I doubt there's any standard. I inflate to riding pressure then use calipers to measure the actual width. Then I measure the gaps (chain stay, brake bridge and chain stay bridge in back and fork crown and blades in front). That leaves me with a simple calculation with the smallest gap and tire width to determine the max tire width. I generally subtract 1-2mm from the result as a fudge factor.
#1550
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
My tubular tires and my clincher tires too are sitting unused, all except for those on the Bianchi which goes on the trainer now.
Real cyclists use toe clips.
jimmuller
jimmuller
