Wider tires, higher air volume, lower pressure. Why?
Quoted: 6556 Post(s)
Liked 58 Times
Would an engineer care to explain what higher air volume in wider tire has to do with being able to run lower pressure? I will tell you that while thinking about this recently, I came to the conclusion it has nothing to do with contained air volume. Assuming you want a uniform 15% tire depression ("drop") when the bike is loaded, two things happen when the tire is depressed. First the pressure increases inside the tire just s tiny bit. But the contact patch area increases significantly as the tire is squashed. It seems to me the reason you can lower pressure on a wider tire is that the contact patch with the ground is bigger on wider tires. The force at the contact patch has to support the bike. So a lower pressure times a larger area will give the necessary force (F=P X A).
Think about this as well: a lower profile tire would contain less air but have a larger contact patch. You should be able inflate it to lower pressure than a narrower, taller tire with a higher air volume.
Comments? I really want to know if I am making an obvious mistake.
Farmer tan
Size of contact patch.
I think you answered it yourself.
But I'm not convinced of the benefit. Larger tires at lower pressure feel sluggish.
Quoted: 1074 Post(s)
Liked 295 Times
Yep, that's it.
I've thought about that WRT homogenous tires.
How far that technology can be taken remains to be seen.
But it seems fairly obvious that "no one" has spent any particular effort on making a line of performance oriented homogenous tires.
You can get tires made for different air pressure equivalents, but this doesn't seem to be put in relation to tire width and profile.
Meaning for the same rubber spec, a wider and/or bigger radius tire will most probably ride harder than a narrower, smaller radius tire.
The trouble IRL though is that you often encounter fairly sharp lumps and bumps.
These kinda destroy the nice pressure/surface area equation.
You need a bit of height to deal with that.
And for road riding, there are the aero concerns.
A bit of handling or comfort is probably easily sacrificed for a rim/tire combo that forms a slightly more aerodynamic shape.
And of course the fact that bikes lean to corner.
Liked 295 Times
For the same design, a wider tire will be heavier. Ignoring pressure, heavier tires always feel less responsive.
Then there's the question of how much lower. Pressure low enough to allow significant wallowing and deformation isn't nice.
Don't forget the influence of tire tread and sidewall design.
My race-spec MTB tires for dry conditions ride nicer on half the pressure and twice the width than the 1.1" slicks on the commuter.
And maybe gives 1/4 of the mileage unless I shred the sidewall first.
Quoted: 1186 Post(s)
Liked 289 Times
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I presume the 15% rule of thumb is the arbitrary point where deflating more than this, has a negative impact on speed for given amount of work, while inflating more than this doesn't yield any gain but leads to more discomfort. I wonder about similar -- especially in the tubeless vs tubed discussions.. "I can run much lower pressures in my tubeless without flatting..." But why would you?
Quoted: 20810 Post(s)
Liked 9,456 Times
In any event, the two biggest factors would be comfort and keeping your tires on the ground instead of bouncing. If we're talking off-pavement, then there's also the grip factor - a larger contact patch on loose surfaces is a good thing.
wears long socks
Lower pressure can be run with wider clincher rims, because the wider rim minimizes the "pinch" on the tube. Just widening the tire doesn't help here.
Pressure is a measurement of weight acting on an area.
If you increase the area (wider tire) then less "weight" (force of air pushing tire out) is necessary to support the weight of the rider pushing down. As a bonus, when encountering a bump that compresses the tire (and air inside), the lower pressure air will allow more deformation of the tire.
So in a nutshell, the wider tire can support the same weight at a lower pressure, yet can act as a better "suspension" over bumps. But... if the rim bed isn't wider, it will be even more prone to pinching than a narrower tire on the same wheel.
Liked 289 Times
The reasons for lower pressure are comfort and traction. The latter not relevant for dry road conditions. Mountain bikers will often run with the lowest pressures possible for better traction. That's why tubeless was embraced in the MTB community while roadies just argue about it.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
The answer is, a wide contact point as opposed to a narrow one has less vertical depression for a given force. In other words, the rim is further from the ground when we hit the pothole, so it takes a bigger hit to get the pinch flat. "Narrow" being a misnomer IMO because it's really the length in the radial plane that's relevant. It just happens to also be narrower for bike tires. Just draw a horizontal line through the tire between the ground and rim. When that line is longer, the rim is lower.
If the area of the contact patch is axle load/tire pressure, then lower pressure increases the area and increases the length of the contact patch. But that's counter-balanced by the difference in shape of the patch, due to the wider tire. Which means at some pressure the wider tire is worse for pinch flats - we already knew that, but keeping in mind the "why" helps me conceptualize it abstractly.
Liked 58 Times
I am an engineer. You are overthinking it.
Liked 58 Times
Does it? I thought the pressure decreases a tiny bit under load, because the tire gets out of round (constrained volume increases). But that's not important to the question IMO.
But here is what I am objecting to. There is a rule of thumb that says no matter the tire size, it needs to contain the same number of air molecules to be "properly" inflated for a given rider and bike weight. So larger contained volume means lower pressure needed or P1V1=P2V2. I understand the gas law, but don't understand what it has to do with a tire being properly inflated for comfort and resistance to pinch flats. If you can explain why the number of air molecules needs to stay constant, I will stop arguing for the contact patch explanation.
wears long socks
The tire with more internal surface area will compress less at the same pressure (with a riders weight on it) because the pressure (pounds per square inch) in the tire is acting on more square inches in the larger (wider) tire.
Bikes: Nashbar Road
Liked 341 Times
I don't buy that "further away from the rim" explanation, because it is all relative. The curb or pothole doesn't have a limited "stroke". It can't just penetrate a fixed amount and then stop so that a taller tire would be more likely to isolate the rim edge from the road hazard. That isn't how it works. The hazard compresses the tire until the force pushing it is balanced by the force pushing back. That could be 1 mm or 1 m. The force pushing back is the internal pressure times the contact area of the road hazard on the tire surface. Greater contact area means greater force at same pressure. Even with a sharp pothole edge, the wider tire would have a wider contact area and balance the force with less penetration than a narrower tire.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
On many tires it will say "maximum inflation (I'll just say 100 for this example) - 100 P.S.I.) followed by (again just picking a number for an example) 120 P.S.I. with hook bead rim.
This is to prevent the tire from blowing off the rim. The hooked bead is more secure.
A wider, bigger tire has more surface area on the inside that is being pushed out by the air. Again, just using a number for as example, if you take off a tire, cut it in half. And lay it flat the bigger tire might have, say 50 square inches of surface to push against, the smaller tire might have, say 40 square inches. This increased surface area lowers how much pressure you can put in the tire, before it blows off the rim.
Many of the benefits already posted are true benefits. Lower rolling resistance due to different shaped contact patch, less likely to pinch fat at low pressure, etc. etc. No disagreement with them. Of course everything else being equal (it almost never is) the bigger tire is heavier.
But the lower maximum pressure listed on the tire is to prevent the tire from blowing off, due to the increased interior surface area of the larger tire.
Liked 58 Times
That is the same as the constant air molecules argument, but it has no theoretical basis. You are saying that the total force on both tire carcasses has to be the same. Why? We are not talking about uniform compression of the tire such as in a hyperbaric chamber. We are talking about compression at a small contact patch.
Quoted: 1814 Post(s)
Liked 923 Times
Six strokes of floor pump into road tire= rideable.
Six strokes into mtn bike tire= not rideable.
Not a very useful rule, IMO.
Bikes: 2 many
Liked 323 Times
The increased surface area of the bigger tire will also increase the force trying to push the tire off the bead. I think the lower maximum pressure listed on the tire, compared to smaller tires, creates lots of confusion.
In general, the contact patch governs traction, static loading, and rolling resistance.
Air pressure behaves like a non-linear spring, the more the tire compresses, the more the pressure rises. Lower pressure is a weaker spring, high pressure is a firm spring.
A taller tire effectively has a longer travel, and a tire with more volume will behave more like a linear spring.
In response to large bumps, the wide tire at lower pressure is going to be more supple and absorb more shock.
Liked 58 Times
Only if you keep the number of air molecules (and the temperature) the same. Why should you do that?
Liked 58 Times
