Shoes: Any experience with Giro Factor Techlace or Fizik R3 Aria?
Quoted: 35 Post(s)
Liked 5 Times
Anyone have any experience with either of these two pairs of shoes? I bought a pair of Mavic Cosmic Pros in May, but they're just not getting comfortable, so I'm going to look to sell them.
Anyhow, I'm looking at the Giro Factor Techlace and Fizik R3 Aria (2018). A few good deals out there for these, which is part of my reasoning for picking these two out of the bunch.
No experience with Giro in general. I do have a Fizik saddle that I love.
I realize fit/shoe is a very personal thing, I'm just looking for some honest opinions/reviews from anyone who may have worn either of these.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
Quoted: 35 Post(s)
Liked 5 Times
Will let you know soon when my Factors arrive. FWIW, I have Cosmic Pros, as well as Giro ACC model -- supposedly close match in fit to the factors. Sizing and width is pretty comparable between Mavic and Giro as far as I can tell (though I'm up in the high end of sizing -- I have 48-2/3 (what a weird size) Mavics, and wear 49s in Giro (and indeed, the Giros are a wee bit longer). Typically I replace the insoles in my shoes, so can't really compare them (I recommend the Sole Thin Sport moldables).
Advocatus Diaboli
Liked 1,531 Times
No, I think Mavic and Giro run the same size. IF my Mavics were available in size 49 I think they'd be the same size as my Giro size 49, but they aren't. 48.66 is Mavic's largest size. I also think my old Sidis are sized the same if this helps.
Quoted: 46 Post(s)
Liked 9 Times
Fizik and Giro run a half size bigger than Shimano. I'm a 44 in Shimano and wear a 43.5 in both Giro and Fizik (and a 43 in Sidi) - with a pinky's worth of space in the toe box. Street shoes I wear a 44 in Adidas.
I have Giro Sentrie Techlace currently. The Techlace system takes a bit to get right - you can't just jam it closed like a velcro strap - you need to adjust the laces then close it with the velcro tab. The swap-able arch support is great though.
John
John
Quoted: 35 Post(s)
Liked 5 Times
I went ahead and ordered the Giro Factor Techlace. They were $155 on Competitive Cyclist and I couldn't pass up that deal. The Fizik's were $80-ish more.
I went with a 44.5. My Mavic's are size 46, but I'm pretty sure they're too big. I re-measured my foot last night because I've had fit issues with just normal shoes recently. My longer foot is just over 10.5". I've always bought 11.5 in shoes. Whoops. No wonder when I got fitted for running shoes I was surprised to be thrown into an 11.
Hoping the 44.5 works. Will be bummed if they don't. But per Giro's site, the 44.5 is equivalent to an 11, so theoretically they should.
Quoted: 35 Post(s)
Liked 5 Times
Is there a general guideline when it comes to how much space between the and front of show there should be with cycling shoes? I know with street shoes I've always operated with a thumb width.
I feel pretty confident my shoes now are too large, as getting clears in the right position over the widest part of my foot is barely possible.
Non omnino gravis
I've got probably around 7,000 miles on a pair of Giro Code Techlace-- which is the same shoe just with an MTB 2-bolt outsole, and more expensive. I've no complaints. They're pretty much sneaker comfortable. I wear an EU48, they fit true-to-size-- I also wear EU48 in Shimano and Diadora.
I just got a pair of factors in 44.5 in the mail. I usually wear 10.5-11 and my foot is about 10.5 inches long and these fit me. I also have super narrow feet.
Advocatus Diaboli
Liked 1,531 Times
You also have to be wary about anecdotes of "i wear a size 11 usually..." etc. Size 11 in which brand and type of shoe? I wear a US size 13 in most every american dress shoe, a size 14 in most every athletic/skate/running shoe. A pair of boots from the UK though, I'm in a 46. My cycling shoes seems 49 is correct. Not sure why there's no universal truth in shoe sizing, it's a mess. And Comp Cyclists filter for shoe sizing is wack as it's all US size based when generally NO cycling shoe sold today is actually labelled in US sizing.
Quoted: 35 Post(s)
Liked 5 Times
After I told you Mavics and Giro were pretty darn close in sizing, you went 1-1/2 sizes smaller (or did you mean 45.5 by chance)? Oh, and SteepandCheap would have been a better deal and it's the same company as Comp Cyclist.
Like I said, feet are weird. I wear most dress/casual/street shoes in 11.5. but, I also have a pair of Adidas sneakers in 12. And while they're clearly too large because I can do a thumb's width and a half between my big toe and shoe end, they're comfy and I'm never had discomfort. On the contrary, I have a pair of Birkenstock's in 44 and they fit perfectly. My running shoes are also pretty comfy and are size 11.
I just went with the option that seemed closest to my foot size with giving a little, but not too much, theoretical room. If they don't fit, I'll return them.
Thanks for the tip about Steep and Cheap. Never have heard of them.
