Luxos U not showing red cache light & not charging
I had one of the first generation Luxos U lights and it worked great for years, but the button just stopped charging the USB. I sent it back to Peter White Cycles, who replaced it free with a new one. The light works fine, but unfortunately, the red light on the button does not light up and it will not charge my usb device either! They told me to send that one back and they will check it, replace it and cover shipping, but this is getting to be a drag. I will have to bring an external battery pack to keep my phone charged on my next trip.
IIRC, the early-model Luxos had an electrical socket on the light, into which one plugged the button-switch and USB receptacle. This socket was prone to failure when water penetrated it. Because the socket was on the light, there was no real way to protect it from water.
B+M changed this design so that the button-switch and the USB socket were hard-wired into the light, and the connection protected with a rubber grommet. The result is less elegant, but also less prone to failure. This is the kind of Luxos U that I have ... keeping my fingers crossed
Quoted: 3459 Post(s)
Liked 1,465 Times
The first June 15, 2016 post at this link mentions water coming in the spade connectors in the back.
https://groups.google.com/g/randon/c/qob5ex7lrWg
I assume you have fenders to keep the tire spray off of your light? If not, tire spray from underneath the light may still get into the light.
Mine had the USB and button hard wired into the light. About a year after getting my replacement light, the replacement failed. Only the USB/handlebar switch failed. I eventually just cut the switch off and used it as a headlight. Then the tail light connections rusted off. Now the tail light is connected directly to the hub, parallel to the light.
It all works, but my headlight used to work in combination with the tail light, giving it a brake light effect by brightening for a moment when slowing down. I don't think that works with the tail light mounted parallel. Also, I had never fully appreciated the functionality off the button until it was gone: No floodlight/"high beams" setting anymore. I didn't use it a lot, but I did miss it when it wasn't there. But that's minor comparted to the other issue: It is so much easier to toggle between settings when the bike it in motion and the light is powered. Since the Luxos U shows you it's mode with an LED, when there's no power, you can't tell the mode. My solution is to put the light in standard, night mode, and just leave it there. The problem that's come up multiple times is that I lock up my bike, walk away from it, and someone helpfully thinks, "That poor person left their light on." And they find the headlight button and turn it off. If I'm lucky, they tell me about it and don't waste time looking at my connections to see if something has come loose. Either way, once I've figured out that light is getting power, the result is that I'm standing in the dark, lifting the front of my bike off the ground, spinning the wheel, and toggling the button to find the correct setting to get my headlight back.
I now have a new B&M light and have combined that with a Sinewave. I don't have that much time in with the Sinewave yet, but it seems functional. The light has a dial switch that is easily readable whether the light is powered or not, but it does lack a couple of the features of the Luxos U that I enjoyed like being able to easily toggle between modes while riding, and the High Beams mode. But after killing two Luxos U lights, I think I'm done with the idea of a light/charger combo.
RNAV
Road Cycling
39
10-17-16 01:54 PM
no motor?
6
06-15-10 09:16 AM
Richard Cranium
2
03-26-10 01:24 PM
tjspiel
17
12-07-09 08:48 AM
