S.O.S! Swap 24 speed or higher into a Trek 7000 Frame
[/IMG]
I want to keep my 2011 trek alpha1 frame because:
A. The geometry is perfect for me.
B. The frame is heavy duty, just how I like em.
Here's The Spec's:
Frameset
Frame
Alpha White Aluminum
Fork
High tensile steel w/curved blades
Wheels
Alloy hubs; Bontrager 550 36-hole alloy rims
Tires
Bontrager H4, 700x35c
Drivetrain
Shifters
SRAM MRX, 7-speed twist
Front derailleur
Shimano M191
Rear derailleur
Shimano TX51
Crank
Shimano M131, 48/38/28 w/chainguard
Cassette
Shimano 14-34, 7 speed
Pedals
Nylon platform
Components
Saddle
Bontrager Boulevard
Seatpost
Alloy, adjustable suspension
Handlebar
Bontrager Approved, steel, 50mm rise
Stem
Alloy, adjustable rise
Headset
Threaded, semi-cartridge bearings, sealed
Brakeset
Tektro V-brakes w/Tektro alloy levers, Kraton inserts
Colors
Platinum/Sparkling Silver
So after years and years of riding, it was time to strip it. Now it's down to the handlebars and frame.
The Project.
Buy a used hybrid from Craigs List with 24 speeds or higher (already have another 21, time for a change) and swap everything over.
The Question
Which bikes/models/years can be the perfect donors.
NOTE:
IF I CAN FIND A MODEL WITH 36 SPOKES WITH DOUBLE WALL RIMS, THAT WOULD BE AWESOME.
I need all the suggestions I can get Hybrid Kings...
Here's The Spec's:
Frameset
Frame
Fork
Wheels
Tires
Drivetrain
Shifters
Front derailleur
Shimano M191
Rear derailleur
Shimano TX51
Crank
Cassette
Pedals
Nylon platform
Components
Saddle
Bontrager Boulevard
Seatpost
Handlebar
Stem
Headset
Brakeset
Colors
The Project.
The Question
NOTE:
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
You don't need to buy a whole bike to swap to 24 speed. Just need new wheels for 8/9/10 speed and cassette and shifter. Unless the other parts are worn out. Are they?
Quoted: 897 Post(s)
Liked 9 Times
I agree, a whole new bike seems like overkill, unless you already know where you can get an old hybrid for like $25 bucks or something dirt cheap.
IMO, this really seems like a lotta trouble just for one extra gear cog. You could throw a rear wheel from an 8 speed road bike back there and use the same chain and rear tire that you're using now. Your old 7 speed grip shifter might work on 8 speed (sometimes there's an extra "click"). If not, 8 speed grip shifters are like $15 brand new.
Cycleway town
I swapped almost everything over from a '97 GT RTS-3 onto a Marin Alpine Trail but there will always be parts you can't swap over, due to variations in sizing.
One i found was the bottom bracket - the GT had a longer tube so it used a 73mm BB over the Marin's 68. Then the steerer tube was barely long enough (i got away with it with no spacers). The seat post was no good, and neither were the cantilever brakes.
As some have said though, it depends what you want to achieve - if you just want to upgrade from 18-speed to 27-speed (or in-between) then all you need is a rear cassette and a shifter.
Bicyclerider4life
Not sure why you want 24 speed.
Anyway, all you need is an 8 speed cassette, and an 8 speed shifter to upgrade. Your rear derailleur should have enough adjustment to handle 8 speeds.
Much cheaper than buying a donor bike.
Big Dave Crowe
Hybrid Bicycles
8
10-12-17 06:11 PM
XCSKIBUM
Recreational & Family
1
08-25-16 10:01 AM
fisch2332
Hybrid Bicycles
1
09-02-11 08:16 AM
fisch2332
Commuting
6
09-02-11 05:00 AM
