Do all folders wobble? First time rider.
I just started to realize the advantage of a fold-able bike. Funny that it took all this time.
So I am quite interested in picking one (or two) up.
My first trial was at Canadian Tire with the cheap Schwinn Tango that they sell.
Because I am used to only triangle frames, I found this bike quiet unstable (flexible).
Is this the typical feel for most folders?
I think that I am taller and heavier than the Tango wants to bear.
Would something like the Dahon Classic III or Bike Friday heavy rider versions have more of a stable cruiser feel for me?
Thank you for suggestions.
Not all folders fold in the middle, or with a single hinge in the middle. The folder below has a traditional geometry, and two hinges.
* Disclosure - the only single-tube folders I've ridden are FSIRs.
They'll all feel weird to you at first because of the small wheels and quick handling. You'll need to try a few to see what works, I've been happy with the ride and handling of numerous Dahons.
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
There are two things at play in your experience. One, anyone riding a small wheeled bike the first few times is going to oversteer and that can be interpreted as "wobbly". It takes getting used to and then it isn't noticeable at all to the rider. Two, a cheap bike is going to ride badly regardless of size, but a cheap folding bike (assuming it has a hinge design) is going to magnify all those issues. Find a bike shop that carries a name brand or two and ride them for more than 10 minutes.
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
No! A folding bike should never feel wobbly. If it does, the hinge latch may need to be adjusted. If it feels wobbly, it may not be safe to ride. Contact the seller of manufacturer for assistance.
My wife's aluminum (non folding) step through has the same wobbly feel to me. She thinks so too so she usually rides her Cannondale.
Locally there are some options. I guess that I should just keep trying them out.
Thank you for your input.
Abu Mahendra, I know this Dahon. Really quite expensive. I will look for a cheaper alternative.
Bikes: Tyrell CSI, Dahon Mu LT11, Doppelganger Aurora 219
Quoted: 150 Post(s)
Well there is your problem... Clown bikes are for clowns
But seriously look at the design of that frame, of course its not going to be remotely strong. Try a more standard folding bike. I have owned two folding bikes, they have issues but stiffness isnt really one of them unless riding hard. Like punning hard on the bars while accelerating can cause flex in the handle stem which is annoying, but I have never really felt frame flex.
Quoted: 3459 Post(s)
Liked 1,465 Times
I am not familiar with the bike you tried.
But I can say that my folder (Airnimal Joey) has a very tall seatpost and seatpost extension. At first I noticed a lot of fore and aft flex at the saddle that made me somewhat concerned. But after several hundred miles on the bike I do not notice that at all.
The trail length , steering geometry, of small wheel bikes is pretty short.
but front loading , weight in panniers or a low mount front bag,
steadies that light front end nicely ..
(Brompton puts it on a headtube QR mount),
+ you get to bring useful things with you..
55+ Club,...
Bikes: 9+,...
Quoted: 1112 Post(s)
Liked 847 Times
You can't base your opinion of all folding bikes based on riding a cheap Schwinn folder that's designed to be bottom of the barrel. If you stated height, weight, and your location, maybe we could help you locate some places for you to test ride a real, quality folding bike.
210lbs
Vancouver Island Canada
Fairfield Cycle has Brompton and Tern but are closed tomorrow for the stat holiday.
55+ Club,...
Bikes: 9+,...
Liked 847 Times
Then, after the holiday, start test riding. You should be able to notice a difference,... That schwinn you rode is considered one of the worst folding bikes.
Bikes: *1998 GT Forte Ti 700c, Totem KDS-D 26" fatbike, BirdyGT 18", Brompton M2LX 16"
Quoted: 88 Post(s)
Liked 5 Times
Try a Brompton, Birdy, Bike Friday or Moulton if you can just to feel what the top end can be like. These 4 can't have any frame play by design; just make sure the clamps are tight and feel the stiffness. A side folder like a Dahon/Tern that isn't set up correctly might have some hinge play or 2 piece stem flex. Side folders can be adjusted stiff, but you wouldn't know unless you ask the dealer to test ride it before you and they are competent enough to recognize the hinge adjuster is loose. I can't see any flex in the BB on my Birdy, but my classic 700c road bike's BB sways a few mm under power.
55+ Club,...
Bikes: 9+,...
Liked 847 Times
Both of my steel Dahon (P8 & Speed 3i custom) folders have no flex/play whatsoever. The Dahon Curve has a small bit in the telescoping handlepost. None of them wobble,...
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 590 Times
Very familiar with the CTC Schwinn Tango. A few years ago my wife and I used them on our camping trips. They are not great bikes and use the cheapest parts available. We sold them to some occasional users and purchased a Giant "Expressway" and Giant "Halfway" (now out of production) What a difference, after 6years they are still one of our favorite rides. Last year my Halfway saw 500 miles in March alone. The only upgrade was to Schwalbe Marathons to prevent the flatting problems with the Kendas. I'm 6' 205 lbs and the bike is very stable.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
55+ Club,...
Bikes: 9+,...
Liked 847 Times
My full sized folding bike (TernJoeP24) rides like any full sized bike as well. And it has a higher weight limit,...I believe 264lbs. My Dahon's all have a 230lb weight limit,...but can easily handle more.
PS: I weigh 230lbs,...I would definitely know if my bike was wobbly or flexing.
Thank you for all the responses.
I stayed away from any bike $1800+ (sorry Brompton).
MEC store was sold out both times that I went. They build them up and sell them out usually on weekends. They will give me a call when one is built.
That leaves Tern Link.
As soon as I got on it and powered in I could feel a slight flex and with each bump that I hit.
The weird thing though is that after 45 seconds of riding I didn't notice it anymore. Maybe I just got accustomed to the different feel.
Rides fine.
Rides fine.
Quoted: 980 Post(s)
Liked 582 Times
I also have an older Dahon Mu XL, which has a remarkably stiff frame. The only flex is from the handlepost which is an extendable type.
FWIW, I'm around 210 pounds and carry a backpack.
Mine has flex
I have a 3speed workman with no flex at all.
I also have a UNIS,has flex on trails and makes for a softer ride,I love it.
I took the wife to try out the MEC bike. 34 lbs and the steering geometry seems wrong.
The wife said the same.
We both liked the Tern Link.
I think that the MEC bikes, which also have Tern parts, are popular because of price.
Still looking though. Probably need 2 now.
OP
I bought a Dahon Vitesse i7 20inch, 26lbs, Shimano Nexus 7-speed.
This seems to be a quality product. It is also nice that a tall guy like myself and a short gal like my wife both can ride this comfortably.
Actually perfect for her. I could use just a little higher handlebar.
