Drawback to too big tires?
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,216 Times
So the bike I'm currently prepping came with 40mm Schwalbe Marathon. They feel decent, definitely plush, just wondering if there is a drawback to going big. Most of my bikes have/have had 32-35mm tires, which I enjoy, but these things look monstrous and too far in the fat direction.
Consider the difference at the contact patch which is the only place it really matters. A 3mm change in height is like adding a nickel under your tire. Is it really that radical a change?
Besides weight, is there any practicable drawback to a bigger tire? I've also got a new set of Conti Top Contacts in a 37 (which come out far closer to my 35 Clement USH than these 40 Marathons) I'm considering tossing on, but if there is no drawback I'll probably just run these into thr ground
What inner width do you have on your rims. Some rim manufacturers make wild claims like one of their rims will work fantastic on any tire from 23 to 57mm wide. But I think the chart on teh bottom of this page is the best chart out there.
Tire Sizing Systems
Tire Sizing Systems
I unfortunately have a set of rims that the manufacturer claimed would be good for up to 57 mm. And the dealer said they were the best rims you could buy for an expedition bike so I bought them thinking that the dealer had a clue. Unfortunately, the dealer had no clue, the rims are 19 mm wide (inner width) and the bike handles terribly if I try to run the 57 mm tires at low pressure because the rim is too narrow. The chart for 19 mm width says my tire should be no more than 44 mm wide.
That's also the pressure I use for bikepacking.
Stuart Black
Stuart Black
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Not planning on carrying a spare this trip, but when I do, it is a cheap folding generic sized one I got off the Wal-Mart clearance rack for $1. Mostly just concerned with something that'll get me to a shop to buy a proper replacement that doesn't take up too much room.
OK, OTOH, I brought 3rd of same , sidewall casing failure, 3 months in,
I left that one on a farm in southwest Scotland.
Liked 4,216 Times
You also have to consider that we don't live and ride in a vacuum so we are always punching a hole in the air. The act of moving the air out of the way is another acceleration...well, deceleration, that we have to keep putting energy into overcoming. There also some frictional forces which are mostly trivial.
And then there is gravity. Every hill is an acceleration to lift yourself up it. Yea, we get a bit of a freebie on the other side but that's paid for.
We are constantly accelerating on a bike when we ride. Weight makes a difference.
Stuart Black
Stuart Black
Quoted: 226 Post(s)
Liked 45 Times
A satellite in space doesn't need a constant tangential force to keep rotating around the earth , only the "tension" from gravity.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I think you are missing the dynamics of rotating weight. It's always accelerating (deceleration is only negative acceleration). Pick a point on the wheel. Move it. The spokes put force on the wheel to pull that point into a different direction. That's the "external force" acting on that point of the wheel. The point accelerates away from the straight line. And it just keeps on accelerating which means you have to keep adding force to keep the wheel moving.
If you're worried about winning a crit or a TT or any race, you'd have a point. Marginal gains everywhere. But people hauling 50 lbs of non-aerodynamic luggage like sleeping bags and tents and panniers don't care much.
Quoted: 3459 Post(s)
Liked 1,465 Times
But I carry my lightest smallest (folded volume) one regardless of cost. Since it is unlikely to be used, it lives in a zip lock in the bottom of a rear pannier.
Fraser Valley Dave
Bikes: devinci monaco (upgraded)
Quoted: 34 Post(s)
My first long tour included riding on hundreds of miles of varied pavement with a lot of tarred surface cracks.
Each tarred over crack stuck up above the normal road surface. I was very glad I had 2" mb tires on rather than
my usual 32's because I was carrying 50 lbs of gear. I don't remember the brand name, but they had a narrow
solid center which helped me attain my highest touring average of 85 miles a day on tours of over 1000 miles,
so I don't think using wide tires designed for pavement use as well as off road are going to slow you down that much.
Liked 4,216 Times
Entirely different system. The satellite has reached sufficient speed that it misses the earth when it starts to fall back down. The earth is pulling it down but it keeps missing the earth. Because it is moving in a vacuum, it continues until such time as something changes the speed.
Stuart Black
Stuart Black
I think I started with tires in the mid 30s, and when they wore out, tried 32s, but they gave a harsher ride, in my opinion, so I went back to my old size, and eventually switched to 40s. Then, in order to go fatter, I got a different bike. Now I'm on 2.15 Almotions (55mm), and apart from the tires being a little stiff, I'm very happy with them. My other wheelset is 2.5" ETs, and I'd probably use them on any trip that had a significant amount of unpaved travel. Rode them down the GAP last year, and they were great, but the rims don't fit in my S&S case and tires preclude me from using the bus rack, which I sometimes take advantage of.
What I've found is that wider means I can get away with lower pressure, which can offer significant improvements in ride quality on any non-paved surface. Tread and tire suppleness play into comfort a lot, too. My ETs are pretty buzzy on pavement stretchs but still roll fairly well because they are supple. Meanwhile the Almotions are great of pavement, but I think it's only because I'm running them tubeless that they're supple enough for comfort on other surfaces.
For me, I'm always happy to go with wide tires, but that's not the only factor. I only enjoy a stiff tire on pavement, and I'll still take a supple tire there if I can get it.
Liked 4,216 Times
No I really don't have to consider it, in the context of touring. The aerodynamic difference between a 35mm and a 45mm tire is moot IRL...because the difference in aerodynamics is orders of magnitude smaller than the drag of the rest of the system....unaerodynamic things like panniers and racks--never mind the rider.
Stuart Black
Stuart Black
Quoted: 226 Post(s)
Liked 45 Times
[QUOTE=cyccommute;20390391. Without force from the pedals, the wheel stops.
Entirely different system. The satellite has reached sufficient speed that it misses the earth when it starts to fall back down. The earth is pulling it down but it keeps missing the earth. Because it is moving in a vacuum, it continues until such time as something changes the speed.[/QUOTE]
Once the wheel is in motion it stays in motion.....no matter how much it weighs.......(in a frictionless world).
A satellite stays in motion ....no matter how much it weights....
You seem like an educated dude.......I hope your boss doesn't see this post.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I've probably mentioned this before, but I think wider tires give a much better, albeit slower ride. My ECR is awesome for what it was designed, but its sad on pavement. The large diameter Cupacabras float over potholes and cracks like they aren't even there, but rolling resistance gets to me on longer trip intervals. If the ECR were an Ogre, and I was rolling some 2.0" Schwalbes, I'd be flying.
But more importantly, the centripetal acceleration just redirects the motion along a circular path and causes no change in speed. Even though the velocities of points on the rim are constantly changing their direction, this doesn't change the energy of the wheel system, so no forces need to be applied to the wheel to keep it rotating.
Liked 81 Times
First, consider what the difference between 40mm, 37mm and 35mm tires are. 3, 2 and 5mm. 5mm isn't even a quarter of an inch. 3mm is just shy of 1/8" and 2mm is just shy of 1/16". Are those really that large a difference? Going from a 40mm to a 37mm is a trivial volume difference. Going from 40mm to 35mm is still trivial.
I'm not sure the weight difference is going to be all that great either. Frankly, I'd be more concerned about the crappy performance of the Continentals. I've had far too many problems with Continentals...including getting stranded at a campground in Atlanta, Texas after the 4th blowout in the first 26 miles of a tour (see Twisting Down the Alley) below. A Bell tire from Helmart is better...and I've had to use one to replace yet another Continental failure.
jef, which marathons are they? Regular ones or the plus ones?
As for running them into the ground, I have a pair of regular marathons that must have 10,000kms on them and they still look reasonable.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 175 Times
With my handlebar bag on, I can’t see my 50mm Mondials and my bike feels just as fast as another. Without the handlebar bag, I’m staring down at that fat sucker and my bike feels like a snail. I’ve concluded riding with my handlebar bag is faster than without.
Can't argue with logic like that
Quoted: 137 Post(s)
Liked 81 Times
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
Good point. Similarly, there's no comparison between my 25mm Schwalbe Marathon beasts and my swift 25mm Gatorskins. They're nominally the same size, but they're different tires for different uses. (When I supported my wife on her Katy ride. She started out with her favorite Gatorskins, but soon gladly switched to the Marathons.)
You'd be well served with fat tires. It's interesting that while racers are going as fat as they can fit on their bikes, tourers are still in the skinny is better mode.
Here is a link to an interesting article. Fast fat tired
Makes sense to me. When I switched from 700x40 to 26 x 2.15, I was always in danger of running into things because I was mesmerized by my fat, front tire. When I put my 2.5" ETs on, forget about it. My commute time, however, remained pretty consistent.
Liked 1,465 Times
Agree on travel time being comparable. I used to have two sets of wheels for a 700c touring bike. One set had heavy duty rims for touring, 37mm wide tires, etc. And one set were 25mm, high pressure, thin tread with supple casings. The 25mm tires felt unbelievably faster, but when I got home after a 20 mile ride the 25mm tires resulted in about a 3 percent reduction in moving time. I consider a 3 percent difference to be not much more than round off error.
Liked 81 Times
Also, interestingly enough, when I went to look for a rim size (none stamped that I could find), I notice these are also stamped both 40-622 and 700x38, so not even sure which they really are. I'll give them a go though, worst case I take them off after a few weeks.
