S Bag Frame in a T Bag
Quoted: 8 Post(s)
I just ordered a 2018 S6L Black Edition and couldn't be more excited! I'm a big fan of the T bag but I don't like how the M bars look and really wanted the S bar. I was curious if any has done this or had the ability to try this out. But I was wondering if it's possible to to swap out the T bag frame with an S bag frame and use it with the S handle bars.
It is and it is a good idea to do this if you want to use a t-bag on a Brompton with a S-bar. The handle grip sits a couple of cms lower, when in the bag it is just reachable for your hands (with minimal lower comfort). The big advantage is, that the grip will not conflict with the cables as it does with the grip of the original frame in combination with the S-bar.
cautionary issue is, can you turn the handlebars over the filled bag, and not hit, or snag
it with the brake levers?
The T bag is hanging from the top of the frame tube shoulder. and
the velcro straps on the bottom, pull it tight around the frame.
the frame is 30cm./11.5" tall S bag frame is shorter
(I dont have one to measure for you )
so, I expect the T bag will drape somewhat loosely around the shorter S frame.
how do you plan to make up the height difference?
perhaps get their S bag, frame included, and make up for the missing volume, with a big Carradice saddle bag..
for my size, the height of the M bar is right,
You, OTOH, consider looks more important.... OK
The Carradice saddlebags are fine but not a replacement for the T-Bag. It is a second piece of luggage and it does neither go off as quickly nor does it help with the bike standing stable with the luggage attached in folded mode or with just the rear wheel folded. On longer trips I often use both combined - T-Bag and Carradice Camper long flap - offers a serious amount of space together.
BTW: It may be worth noting that the bag and the frame can be bought separately from Brompton, thus it is possible to avoid buying the large frame that you do not need bundled together with the bag. Alternatively you can cut off the handle off the large frame and replace it with a homemade soft handle - solves the issue as well but makes the positioning of the bag on the bike slightly less comfy (but still ok). You could alternatively also try to bend the handle slightly forward, using a hot air vent. Should in theory also help but I never tried that.
Other than that it is possible to use the bigger frame as it is but Brompton does not recommend it for a reason. One issue is that the cables will rub on the handle and, over time, the outer brake cables becoming defective in that area, resulting in a sudden and undesired loss of brake power with the factory fitted jagwire cables. You can avoid that by taping the cables using duck tape in the affected areas. The other issue with the big frame on the S-Bar is, that in sharp corners the brake cables may get cought by the handle and you may loose the ability to steer and be locked in cornering mode as long as you do not manually free them again. Happens rarely but when it happens it is no fun. Been there done that.
