Cut on tire
Cut on tire
Dear All experience bikers and mechanics. I just noticed 2 cuts on my 25mm 4000 sii. Please see attached pictures. I think they could be more than 1mm think but i don't seems to see the casing yet. Can anyone guvg me any idea if I need toto replace the tire?
1st cut
1st cut in different angle
2nd cut
1st cut
2nd cut
Quoted: 83 Post(s)
Liked 64 Times
If it bulges at all or you can see the fabric is damaged, replace it. Otherwise you’re fine. Rubber mainly protects the carcass and the carcass provides most of the strength.
Quoted: 1948 Post(s)
Liked 2,010 Times
Those are fine. It is smart to look for such things after a ride.
Quoted: 1572 Post(s)
Liked 643 Times
Neither of those would blip my radar.
My general test is to inflater the tire to your normal operating pressure and feel the cut with your finger. If you can feel a bump or a blister, you can assume that the tire casing has been compromised. If that's the case, I replace the tire.
Quoted: 6193 Post(s)
Liked 4,808 Times
I'd double check there isn't something still down in there that will eventually puncture the tube, then ride the heck out of it till the treads worn down to the threads or I simply get tired of the tires and want new.
If the tube is not bulging a big bump in that area, it's a non-issue for me and I'd just watch it till I was satisfied it is not continuing to grow. Cuts in the rubber only are not a big deal.
You yourself have to consider your ride environment. Are you racing for big bucks and have to minimize any risk? Or can you survive a flat on the road and perhaps a fall if it blows on a turn?
Falls have not bothered me yet in over 50 years, I've lived through many.
Just curious about the Super Glue tip. I've tried that, yet it dries very hard. Has anyone tried rubber cement? Does that work well on small cuts?
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Thank you all for the attentions and advices. Seems like the situation is not too bad. I took some more clearer pictures. If you don't mind, please review and provide further advices:
1st cut
1st cut
1st cut
2nd cut
2nd cut
Found a scratch in side wall too.
1st cut
1st cut
1st cut
2nd cut
2nd cut
Quoted: 2952 Post(s)
Liked 3,106 Times
Neither is an issue.
Liked 2,010 Times
I've been riding these.
Liked 2,010 Times
They might have one more ride in them. I have some patched tires re-stretching now. I just need to get around to remove and glue. If these would just flat and be done but they wont.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I've always wondered about the super glue advice.. like you say, my experience is that super glue dries hard/crystalline. Isn't putting super glue into a cut like putting in a custom shaped piece of glass that's already worked part-way thru a cut on your tire?
