1972 Motobecane Grand Record - part-out, or...
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
Just picked up a 1972-ish Motobecane Grand Record, 52cm. It was in rather rough shape, paint-wise, looks like a clear-coat had turned to powder on the paint, and removing it or even getting down to something I could polish would involve completely re-sanding the frame, which would mostly destroy the graphics. It had a mish-mash of non-OEM parts, the only OEM parts were one Universal Mod-61 front caliper, Universal levers with destroyed hoods, Stronglight 49D crankset w/52-40, Stronglight Competition headset, Stronglight BB, and the cable-hanger quick-release levers.
Being that I almost never part-out anything, just mulling over whether to separate the F & F from the Stronglight headset and BB. They're in excellent condition, and seem to be somewhat scarce. But, would the frame then have any value without a headset and BB, or would it be better to attempt to sell the frame with the headset and BB?
Quoted: 3783 Post(s)
Liked 3,287 Times
An enthusiast seeking an original Grand Record would value finding one with original fittings. One path to take might be to remove all of the non-original fittings and offer the balance as a partial cycle. In this manner it could be kept together as far a possible.
Given your finish restoration skills the "clear coat turned to powder" must be a pretty bad problem.
Quoted: 5877 Post(s)
Liked 3,445 Times
With French bikes, I like to sell and buy them with HS and BB. If the frame is really trashed and this bike needs a paint job, then the value of the bike may be the HS and BB rather than the frame. It sounds like whoever buys this is going to want to repaint it.
Mike J
Quoted: 392 Post(s)
Liked 6 Times
Mike J
Quoted: 392 Post(s)
Liked 6 Times
Yes, I've never bought a frame without HS and BB, and without those, I wouldn't give $20 for the F & F. It's only 3 tubes 531, so not valuable. I'll probably salvage the HS and BB, and see if I can donate the frame.
Liked 3,287 Times
Does it appear to you that the clear coat is factory original?
Do not recall these as coming through with a clear coat but it could just be my poor memory or that never noticed....
Mike J
Quoted: 392 Post(s)
Liked 6 Times
It may not be a clear coat, possibly just severely oxidized paint. I can scrape it off with a fingernail in spots, just goes straight to the primer coat which seems to be fairly durable.
Liked 3,287 Times
Quoted: 339 Post(s)
Liked 623 Times
I don't know if this will work but if you could clean the frame without rubbing the paint off you could try spraying it with Rustoleum clear lacquer. This is an acrylic lacquer that is o/k for exterior use . One property of lacquer is that it dissolves into itself. Assuming that the original paint is lacquer( and given the condition you describe i think it is) the new lacquer top coat will dissolve the powdery lacquer underneath and leave a nice shiny surface.
I used to be a cabinet finisher and many times was able to rejuvenate the finish on old cabinets and furniture this way. By a can of rustoleum clear lacquer and spray on a small spot and see if it works. you might be pleasantly surprised. I have done this on a number of bikes with spectacular results.
Liked 3,287 Times
If the original paint is enamel would this result in a bad reaction?
Thrifty Bill
Quoted: 1236 Post(s)
Liked 957 Times
I would start with polishing compound, and if that doesn't work, rubbing compound. You can find both in the automotive section of your favorite store, Walmart, or whatever. Rubbing compound is more aggressive than polishing compound, so don't get carried away.
Mike J
Quoted: 392 Post(s)
Liked 6 Times
Thanks for the suggestions, all. I ended up donating the frame and fork and moved the Stronglight goodies to my '74 Peugeot PX-8. I replaced the cottered crankset on it with the Stronglight 49D square-tapered crankset and BB from the Moto, and also used the Stonglight Competition headset to replace the OEM Peugeot headset. Nice upgrades for the $60 cost of the Moto. Plus, I now have a nice spare set of wheels, Normandy Luxe Competition hubs laced to Weinmann alloy 27 x 1-1/4 rims. Thank you Moto.
Liked 3,287 Times
Sounds good Mike; great to read you got everything squared away.
Please don't forget to update the PX-8 thread!
noobinsf
8
10-25-15 09:29 PM
Geo_08
7
04-29-12 06:54 PM
