Mystery 80s Japanese touring bike?
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
I acquired this mystery bike from FB Marketplace (local listing), because I could see the potential in this "diamond in the rough." Lugged steel, canti posts, what appeared to be decent components; for $20, I can't really go wrong. Had to look past the horrible rattle-can paint job and general parts disarray, no big deal.
As near as I can tell, before I start removing paint, it seems I have an 80s Japanese touring bike, of fairly decent quality. Here's what I know so far:
Serial #: J810057 (The frame is 57cm x 57cm, so that makes sense; made in '81, possibly? And the "J" I'm not sure of.) Any idea about this format, T-Mar?
SR triple crankset
SR Randonneur bars
SR Royal stem
Dia-Compe levers (no brakes, but likely were Dia-Compe cantilever, based on remaining hardware)
Sunshine hubs
Araya 27" alloy rims
Shimano rear derailleur (not familiar with model, haven't looked at number yet; I'm guessing not original stock)
Suntour BL front derailleur (broken, but could be fixed)
Suntour downtube shifters
KKT pedals (probably not original stock)
Lugged crown fork and nice looking scalloped seat stays and lugs
Original color appears to have been blue
Headset and BB bear further exploration
This will be my first real grounds-up refurbishing bike project, beginning with the paint issue. Should be fun.
More pics...
SR triple crankset
SR Randonneur bars
SR Royal stem
Sunshine hubs
More pics...
The frame looks to be similar to that off the Miyata touring line. The code with the letter J would indicate that the year of production is 1981, followed by the rest of the numbers.
I'm wondering what model of the touring line it could have been. Based on the parts, either a 6xx or 1000?
It also looks to be repainted or someone tried to at least.
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times
My best guess without serial number is ‘83 ‘84 610 (if it is a Miyata, but it does look like one) the above the chainstay cable stop makes it ‘84 or earlier, and no bottle mount on the seat tube makes me suspect 610. Check the rear drop outs, if there’s a threaded hole for adjusters, might be an earlier 1000.
But that’s all moot with no serial number.
Oh! Sorry, J makes it an ‘81 1000.
https://www.ragandbone.ca/PDFs/Miyat...%20Catalog.pdf
which did come in blue.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,695 Times
That chain stay protector is a very Miyata thing to do- so my guess is either Miyata or Univega.
EDIT: I didn't see @Chr0m0ly's post above...
Commence to jigglin’ huh?!?!
Le savonnier
Quoted: 729 Post(s)
Liked 602 Times
Funny, when I took it into my LBS today, my friend said "Looks like a Koga-Miyata!" So, in the ballpark, also.
Le savonnier
Quoted: 729 Post(s)
Liked 602 Times
I'll likely keep it to it's original color, but possibly powder coat it, depending on what I find under the "custom" paint job.
Only downside to the 81 and 82 models were the lack of bottle(only one) and fork mounts. But what you could do now that you have a bare frame to work with, is to take it to a frame builder to add fork and extra mounts.
You don't have to worry about keeping it "original" anymore. You can truly customize it to your liking and have a kickass ride. This is a great opportunity for you. I wish I had one like it.
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 386 Post(s)
Liked 691 Times
This looks very much like a Univega gran turismo or specialissima frame of the early 80s (pre-1984). By 84, both those models had fork mounts and seat tube cage mounts.
High quality framesets built by miyata. Univega actually used to spec these to a higher standard than the equivalent Miyata frameset of the same year.
Quoted: 386 Post(s)
Liked 691 Times
The rear dropouts look identical to an '82/83 gran turismo, and quite different from the '81 miyata 1000, which has the threaded adjuster hole and raised lip around the dropout slot. Also the head tube lugs don't look like they belong to an '81 miyata (which are 'pointier' along the tubes). In fact they look very much like what the miyata factory was using for the the univegas in 82/83.
The fact that it has canti posts definitely point to a miyata 1000 (univega specialissima and gran turismo were all center-pull in '81). However I wonder if the posts were added later-- might be the primer/paint differences on the posts playing tricks.
Good mystery, but the serial combined with canti posts point to '81 miyata. Take out canti's and I'd be convinced it was a univega due to dropouts and head tube lugs. Perhaps factory used different head tube lugs and rear dropouts from the univega models just because.
My first thought is about an 83 Gran Turismo. The fancy chain slap protector combined with canti brakes and above chainstay cable routing limit it to just 2 or 3 years. At any rate I agree with everyone else in that it looks like a Miyata or (Miyata made) Univega. IIRC both the Specialissima and the Miyata 1000 had cutout lugs that year. Diamonds for UV and M for Miyata. I don't see any cutouts so GT seems like a more likely possibility. The shop where I worked sold at least 10 Gran Turismos for every Specialissima. They are much more common.
If the frame is stripped and weighed, that'd give further indication.
Le savonnier
Quoted: 729 Post(s)
Liked 602 Times
https://www.ebay.com/itm/Restored-Vi...d/153450974620
I won't really be able to dig into it some more until the next weekend or two.
Le savonnier
Quoted: 729 Post(s)
Liked 602 Times
I believe this Nishiki Gran Turismo is probably the exact representation of what I have, down to the color, which I can see in a couple of places on my bike.
Quoted: 796 Post(s)
Liked 522 Times
Univega GT -nice score for $20. Hope you share pics of the reclamation project.
Quoted: 4722 Post(s)
Liked 3,036 Times
The subject frameset is a 1982 Univega Gran Turismo, manufactured by Miyata.
sozzled
3
03-07-14 10:55 AM
