Wahoo Releases ELEMNT ROAM computer
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Some folks were wondering if/when Wahoo might update their line...they added a new top-tier device
https://www.bicycleretailer.com/new-...ew-elemnt-roam
DCRainmaker already has his review posted. Yay for media blackouts:
https://www.dcrainmaker.com/2019/05/...th-review.html
ATLANTA (BRAIN) — Wahoo Fitness has announced a new GPS bike computer model, the ELEMNT ROAM. The new model features a 2.7-inch screen, the same as the ELEMNT model, but an aero mounting system similar to that on its BOLT model. The ROAM also has a color screen and enhanced navigation features.
The new ROAM will retail for $379. The ELEMNT model is now reduced in price to $299 (from $349) and will be phased out over the next year. The BOLT continues in the line for $249 and the ELEMNT MINI is $99.
– New color 2.7” (68.6mm) screen, flush with top of unit, not reflective
– Added ambient light sensor (adjusts display settings automatically)
– Added ‘Get me started’, which gets you to the starting point of your ride (used pre-ride)
– Added saved locations
– Added ability to get back to route (aka ‘Back on Track’)
– Added ability to retrace a route back to the starting pint
– Added ‘Route to Start’ using shortest possible route back to start of ride (used when you want to be done)
– Added new additional map zoom levels
– Added elevation graph on the map page
– Added new app integration with MTB Project and Singletracks for pulling routes (requires phone)
– Redesigned out-front mount to support larger size of units
In addition, there are two features that will not be present at launch, but will arrive down the road
– Strava Turn by Turn Navigation – This will automatically give turn by turn guidance for Strava downloaded routes (Late May 2019)
– On-Device Elevation – This will give elevation information for routes created on the app/unit (Mid-Late June 2019)
Quoted: 942 Post(s)
Liked 527 Times
I saw that, I like it but my bolt already does everything I need so I cant justify it right now. Battery life has to be lower with the auto dim function and color screen.
Non omnino gravis
They claim it doesn't, because it's in the same size case as the Elemnt, so bigger battery than what's in the Bolt. If I want nav, I've had a Hammerhead Karoo for over a year, and it sometimes works. For an everyday bike computer, the Bolt is the best I've had. If Hammerhead can ever get their software figured out, it's really an unbeatable platform. That said, my Karoo sits in its box, and I use the Bolt every day.
I know for 100% sure that I wouldn't pay the premium for the added nav features on the new Wahoo. The Bolt is still the best buy in their lineup.
Quoted: 942 Post(s)
Liked 527 Times
The battery life on my ELEMNT has been dropping lately, so it might be time to look at a new unit (or else see if it's possible to have the battery replaced).
I do like a few things about the new ROAM, though at that price point I would also have to look seriously at the Edge 830 and even 1030. For my uses, the seamless cloud integration with RideWithGPS and Strava are killer advantages for the Wahoo though. With Garmin you need a ConnectIO app for that I believe.
J.
Quoted: 18883 Post(s)
Liked 10,646 Times
Liked 10,646 Times
J.
My use model is to import routes from RideWithGPS directly to the Wahoo, then at the end of the ride push the tracks back up to RwGPS as well as Strava. This can be done directly over WiFi or tethered through the Wahoo phone app, with no desktop PC needed. From what I've read, the Garmins can push tracks up, but not pull routes down (except from their own cloud service). My understanding is that the only officially supported method is to export the RwGPS route to a TCX file then copy it to the Garmin via USB. There's a third-party ConnectIQ app called dynamicWatch which I *think* can sort of replicate the use model of the Wahoo but I'm not sure.
Quoted: 4260 Post(s)
Liked 1,363 Times
Liked 406 Times
Had it happen to all 5 of my favorite Connect IQ data fields back while I was on Garmin.
Liked 1,363 Times
Problem with relying on ConnectIQ apps...is they're released and are awesome, then Garmin updates the platform which breaks them. And the developer is gone and doesn't update them after a revision or two.
These apps use the same facility that Garmin itself uses to transfer routes. So, it might be less likely that this would break.
I think there were also some "growing pains" with the IQ SDK, where there were significant changes between versions. I think that might have cooled down a bit (which would mean providing long term support might be easier).
Unfortunately given the reported performance issues with the ROAM, I don't have a lot of good options if my ELEMNT battery finally dies and it has been discontinued. Hopefully the issues with the ROAM are just temporary and will be fixed with future updates, rather than something unfixable, such as if they cheaped out and put a seriously underpowered CPU or too little memory in it.
Liked 10,646 Times
It's been since last year that I've done this. RWGPS gives me better TBT on my Garmin, but you're right, it involves jumping through some hoops. I didn't realize that was so easy with a Wahoo.
I'll look into dynamic watch, thanks for the tip!
Liked 10,646 Times
Garmin has a lot of really fantastic stuff, including the radar. As readable as their screens are in the sun, they're really low resolution. I know a big part of that is for battery life, but Garmin charges a premium, and it just doesn't feel like a great value for maps with the limited detail it's capable of showing. Karoo has a better screen and it sounded like there was good nav and good visualization of the map data. Bike computers need to move in that direction.
Hammerhead says they are going to support the Varia Radars and I think that is something that should be done pretty easily with their Android OS. Given my tech background, I've been pretty active in side loading android apps into my Karoo and with the addition of Osmand and Komoot I get the best of all worlds of mapping. From some of the gravel riding we've done in the last year, we found that you just can't make it work with a single map source because none of them have all the detail you want. With the Karoo, and with Osmand side loaded, we were able to have both topo and TbT nav at the the same time. It's also pretty cool that using Komoot and Osmand both on the Karoo will give audio turn by turn directions if you have a BT earbud or a BT speaker connected. That, I have to say, is really nice and makes going back to the crappy buzzer/beepers that Garmin uses just not acceptable anymore.
Hammerhead has been hiring some pretty heavy weight navigation devs and some industry heavyweights have put some money into the company recently. Prior to the beginning of this season in North America, they really worked on reliability and stability which has improved. It's not perfect, but having had a lot of experience with other bike computers suppliers such as Garmin and Wahoo, none of them can really make the claim of having perfect reliability and stability either. So - I tend to really prefer the Karoo over the other two. Once they incorporate the Radar, (or let someone else do that through an Android App Store), then for sure, it's my top choice. Right now, the combination of side loaded Osmand/Komoot plus the Karoo mapping and display is pretty hard to beat for gravel/touring.
J.
Non omnino gravis
But aside from an underdesigned quarter turn mount, the Karoo hardware is exceptional. Best screen on the market without question. The software is basically terrible. Hammerhead pushes out updates on a very regular basis, and they tend to break more than they fix-- I had no usable power data for about 4 months, and others still don't have consistent connection now. Perhaps hubris, HH deciding to "close" the software and using their own tweaked Android platform. If they had just open-sourced the OS from the beginning, someone would have built a stable software package for it, something that the people at HH have as of yet seem incapable of doing.
I miss my Karoo. I was easy to operate, and again-- that screen. But having to carry not just a second GPS unit due to the flakiness of the software in general, but batteries and cables on every... single... ride, that got tiresome after a year of doing it. I couldn't usually get 2 rides out of the Karoo (unless it was like a pair of 90 minute rides,) no matter the screen settings or sensors connected. I charge my Bolt once a week, and it requires no back-up recording.
The potential is certainly still there, but no sensible person could ever claim that the Karoo wasn't an unfinished product that was rushed to market, and remains woefully incomplete here well over a year later. Mine was schizophrenic from day one, working perfectly on one ride and eating the next. Battery life was like spinning the wheel of fortune-- might be 7% per hour, might be 25%. Absolutely no way to tell.
J.
Non omnino gravis
Unless battery life has increased by 100% in the last 2 months, it stays in the box. I still follow the FB group posts daily, and it's most definitely not all sunshine and rainbows. Basic functionality still isn't there.
I'm not rushing out to try to sell it, but I'm certainly not rushing to put it back on the bikes, either. My original Karoo's charge port failed one day before it's first birthday. It was replaced by the Bolt immediately-- less than 36 hours later. I have since put 2,000 miles in with the Bolt, and it has been perfect, every day, every ride. 6-7% battery use per hour. If the Karoo could do a legitimate 10% per hour, and not randomly reboot at least once a week, it would get rehired. But it simply can't or won't, so it doesn't.
Sure, it's not "sunshine and rainbows" but guess what, it's not over on the Garmin Edge 1030 forum either. My main point is this - they are making solid progress for which they deserve credit. It's reliable for my use case now and is the only bike computer I'm using since the snow melted.
J.
Non omnino gravis
You're not doing better than 10% per hour, you simply aren't. Because the Karoo continues to have deeply flawed battery management software, so the OS thinks the battery is dead when the gauge shows anywhere from 40 to 20 percent. I had mine do the "rapid drop to zero" from as high as 51% displayed. Thirty percent = zero seemed to be pretty common, my first Karoo could never, ever be trusted below 40% on the gauge. So I might average "ten percent" per hour for six hours, but that's all the Karoo would do. From 40% to auto shutdown, less than 2 minutes. So it was really using about 16.5% per hour. The actual mAh drained from the pack is irrelevant, because the Karoo thinks it's dead. So it is.
I was on the ATG from its inception, so it was normal behavior for me to let the battery run until it would go to rapid drain, every time. I had a 10,000mAh USB pack on the bikes at all times. Worst ever? 100% to rapid drain in 2h45m. Best ever? 100% to rapid drain in just under 8 hours. My Karoo was used to log around 250 rides, out of which ~40 were either errored (usually complete loss of one or more sensors,) corrupted (frozen during saving,) bad data, "eaten by device," etc. That's an 84% success rate, give or take. Everything I state about the Karoo is 100% objective. I logged in excess of 10,000 miles with it, unit on-time exceeding 800 hours. No guessed numbers, nothing from extrapolation. Just as my very first charge on the Bolt still had 16% battery remaining after 14 hours of on-time. I've never once had it drop below 20% charge before 12 hours of use.
Credit where credit is due. They could have fixed this by now. Every time I get an email asking me about suggestions for the next gen device, it's like the knife twists. I knew going in I was paying to be a beta tester. Turned out I was paying to be an alpha tester. It's been out a year. Forget all of the things we were promised-- basic functionality still isn't there. I hold out hope. But for now and the foreseeable future, the Bolt is my everyday computer. It just works.
Also, I'd have to say that if you haven't used it recently, then we're not talking about the same device.
I also have a Wahoo Elemnt and an Edge 1000. The Element is pretty near bulletproof but it's a pretty basic unit too and nothing I'd ever want to use for any navigation in unfamiliar terrain (you'd better have a phone with google maps handy if you do). If it didn't "just work" it'd be a loser because it doesn't do a lot either. That's what they get for the simplicity - strong reliability.
It also looks like Wahoo is kind of running out of gas - the ROAM is overpriced and under featured for sure. To me, it looks like Wahoo ran out of gas on their software development. That's too bad, the Elemnt is a nice product but maybe not all that extensible unless they disprove that on the next pass. For my daily rides, I'm taking the Karoo.
Yes, it's true - it shouldn't have taken this long. But I am glad to see Hammerhead making pretty good progress. While it may feel good to bash them for their past fooling around, not a lot can be done about that. If they have development moving in the right direction now, that's good and maybe they get somewhere.
Lord knows we need something else out there other than Garmin (and their mediocrity). Overall, the state of bike computers as consumer electronics probably places them as a class down near the bottom anyhow. Somewhere, somehow maybe someone will fix that larger problem.
Non omnino gravis
We will forever be in agreement about Garmin. The last good computer they made was the Edge 500. That thing is the Nokia 3310 of bike computers. And head-to-head against the 1030, the Karoo is still an absolute winner. I will never buy another Garmin product.
I really just want the Karoo to be what they promised it to be.
