Talking through a new commuter build
In a few months my daily commute will be shortening down to two miles. Since I have to wear dress clothes (ties, slacks, etc.), I've always worn bike gear and changed at work. But with this short distance, I think I'd like to save some time and effort and just ride to work in my dress clothes (and rain gear over the top of that in the winter).
I'm trying to figure out the perfect commuter for year round riding that would be comfortable to ride in dress clothes. I think the ride is flat enough that I can get away with a single speed bike to cut down on maintenance and also to keep the bike cleaner. The ride will be mostly on residential streets and bike paths.
So far this is what I'm toying with, and I'd love to hear your feedback:
-Aluminum track frame with carbon or steel fork (depending on what I end up buying)
-Coaster brake in the back to simplify the design, on a 700c wheelset
-I've considered putting a disc brake on the front as a backup, but I'm going back and forth about whether I want to add the clutter and maintenance of another brake. Part of me thinks if I did his, maybe I might as well just run disc brakes front and back, but I've kind of liked the idea of just the coaster brake.
-Originally had thought about using drop bars, but maybe something more upright would be a better idea for comfort while riding in dress clothes?
-Full fenders and a chain guard to keep things clean
Any other thoughts?
Any other thoughts?
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
If you can get away with a single speed, why not?
Any frame material will work.
Coaster would be fine, but I would go disc simply for hand control.
Upright/flat bars for dress clothes commuting. At least enough that your tie hangs mostly straight down your chest.
Definitely full fenders and chainguard. Single speed makes this easier.
Consider your saddle carefully. The rear/crotch area of dress pants are no match for regular cycling duty (although four miles/day isn't much). A slick saddle will be easier on the fabric of your pants. Shoes or a shoe change is another consideration because no matter the fender coverage, your feet will catch a lot of grime in anything but the nicest weather.
A 2 mile commute could be walked comfortably in about 30 minutes (even if you're pushing a bike). I'd not carry anything more than a folding lock -- no tools, tubes, pump, etc.. Minimalist to the extreme.
-Kedosto
-Kedosto
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times
Any other thoughts?
Any other thoughts?
I don't like coasters, so I would just get real brakes...but that's me!
Something like this would be great for you: https://www.prioritybicycles.com/pro...iorityclassic2
Likes For jade408:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
It sounds like you’re trying to build a beach cruiser that for some willful reason has a track frame in the middle of it.
Likes For Darth Lefty:
Jedi Master
My commute is a little over a mile to the train station. I ride a beach cruiser with a rack and a commuter pannier. I've been commuting on this bike since 1992, and my longest commute has been 3 miles one way. The only weather that will prevent me from riding my bike is when the snow on the road is still too deep to get through. It's the perfect short-distance commuter IMO. I service the bearings every once in a while (like every 5-10 years) and put used motor oil on the chain every few years. Still using the original tires. I wear my regular clothes on the bike. That used to be a suit, but the world seems to have gotten more casual so now it's chinos and a blazer. I wear overshoes and an old REI rainsuit over my work clothes when the weather is crappy. When It's dark I wear one of those construction worker safety vests. Sometimes I'll clip a light on the back, but usually not.
I do very much appreciate any and all feedback- because in the end maybe I am just glorifying the beach cruiser and that may not be the idea cruiser. Feedback on using a coaster brake for this type of commute would also be nice, since that will be a first for me (since childhood).
Disco Infiltrator
Liked 2,105 Times
Perhaps you're right.
Take a second look at that Priority. I had a first generation version, the newer one fixes pretty much all the issues I had with it. It's pretty much all aluminum except the fork and spokes, weighs somewhere in the mid-20's even before any weight weenie improvements.
Genesis 49:16-17
Genesis 49:16-17
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
Have you considered the other option and take the l o n g way to work? I'm sure you could devise an interesting route that's longer than two miles.
Jedi Master
My coaster brake works great if that's a concern of yours. Regarding that priority, I wouldn't have a commuter without fenders, and belt drive seems like a gimmick to me. Chains last a long time on a single speed and they are super cheap to replace. I have another bike with drum brakes, a 3 speed IGH and dynamo lighting that would be an awesome commuter, but I don't like leaving nice bikes locked up outside. I run a waxed chain on that one so I don't need a chainguard.
Quoted: 417 Post(s)
Liked 95 Times
The Priority bike also has a coaster rear brake.
Personally, the last recent times I tried a coaster - once in Amsterdam, and once from a hotel bike rental, it was really hard for me to modulate. But I went from coaster brake to brake levers in basically my second kid bike. Around age 9-10, so I hardly remember using a coaster.
Disco Infiltrator
Liked 2,105 Times
The Priority has standard fender mounts, and a chain drive swap would cost maybe thirty bucks.
They put some thought into it, really.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Any other thoughts?
Any other thoughts?
Essentials include: IGH, dynamo, fenders, inexpensive.
https://www.fahrradmanufaktur.de/en/...gates-830-2019
Day in, day out, you won't beat this bike. Should last about 10 years of daily with zero adjustment/maintenance. Leave it outside and bikes don't belong inside.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,428 Times
If you're riding in a tie and don't want to look like a clown, don't ride a track bike. Definitely something upright, with the SS/chainguard you want a very townie kind of bike
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I had a similar idea for my 8-mile commute and set up a fixed gear/single speed bike. Steel frame, rim brakes front and back, fenders, full chain cover (not just a guard). Add a rack and trunk bag for convenience. Maintenance is as close to zero as you get without doing something weird. Eventually stuff wears out, but it takes much much longer and I don't ever really mess with it until it does.
I have been 100% satisfied with that setup, and I do ride in office dress clothes in the cooler months. The only downside is that I'm slightly slower on that bike because of setting up more upright as well as completely disregarding weight. The upside of that is that everything is almost ridiculously cheap when you ignore how much it weighs.
Of course, lights are permanently affixed. I leave the trunk bag on on rack - it's too convenient to do otherwise.
Regarding the handlebar style, I wanted flat bars originally but was sent drop bars, and after consideration decided that I just didn't care. I set them up a little higher, works for me. Personally I wouldn't trade for disc brakes because the rim brakes are simple, effective, and not even used that much since I settled on riding fixed.
Liked 2,568 Times
Quoted: 1949 Post(s)
Liked 2,010 Times
I just put north road style bars on my PX-10 and it is quite the nice light bike. Grab some light weight horizontal dropout, fender brazeon bike and put the coaster brake hub on it with nice cruiser bars. Plus if your are riding in nice clothes get one of those poncho things like from Caradice. I have wanted to try one of those but it gets a little windy here.
Jedi Master
The Raleigh Tourist seems to check a lot of your boxes and it's only $250 right now.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,428 Times
??? The MSRP of that leather saddle is almost half of the price of that bike!
If they had larger than 56cm in stock, I might've just bought one. (Almost thinking about buying one just so I can sell it for $400 after the sale is done)
Jedi Master
According to the Amazon reviews, everything about that raleigh tourist is super cheap. My daughter is moving off campus and needs a bike the last two years of college, so I've been looking for something in the disposable price range.
Why buy new? College towns/cities have tons of bike co-ops and she won't have to deal with the hassle of a theft annoying her. Also, the sunk cost (CO2 emissions have already been produced making the first bike).
