Recommend a bike for a "tween"
Summer is here and my 12yo son needs a new bike. He's a "tween" so he's not quite physically a teen but too big for his kid's bike. As you'd expect, his old bike is a little department store single speeder with a coaster brake that is small, heavy and slow. I was hoping he'd be able to ride my old hardtail with 26" rims and 17.5" frame but he's only about 4'8" and 85 pounds so it's still too big. Maybe in a couple of years, but I have a feeling he's going to continue track on the low side of the growth curve and top out at 5'10" in at least 3 years at which point it will probably be perfect.
My hope is to take him for 10-15 mile rides on packed and paved multi-use trails with one section that has a moderate uphill grade. He's not adventurous so something like a hybrid would be sufficient. I'd like to teach him how to work the gears and feather the brakes and go out on some evening/weekend rides with us and not fall behind.
Can anybody recommend a make/model and/or a general rim/frame size? I'm thinking a 1x7 with 24" rims is about ballpark. All I see on Craig's list are 16"-20" kiddie bikes which is what he already has.
Bikes: Norther Klickitat Pass, Masi Giramondo 27.5, Soma Grand Randonneur
Quoted: 39 Post(s)
Liked 59 Times
If you've got a non-profit bike shop around I'd check out a smaller vintage mountain bike, even if the wheels are a little tall. There isn't a whole lot of sense in springing on one of the performance oriented youth bikes unless you imagine he'll ride the hell out of it. For what it's worth, I topped out at 5'7" at like 15 (I'm 29 now so I don't see that changing!). I'd be more interested/concerned about the distribution of the height- I'm all limbs so I generally ride a bike 1-2 sizes "above" what is recommended based purely on height while my brother (6'4") would need to ride a bike 2-3 sizes "below" the recommendation because he is all torso.
13"* frame 26" wheel like a steel frame Trek 820?
*short seat tube length... seat post can be longer ..
SuperGimp
I got a small women's bike when my son was in that situation, I think it was a 44 cm Fuji or something, but it had an adjustable stem, which proved to be helpful. It was dark blue, not girly in the least.
Likes For TrojanHorse:
Ask a shop. When my son was in that situation, the LBS found a Raleigh with 24" wheels that fit him. It was only little more expensive than a BSO.
I was actually looking at the Specialized Hotrocker 24 which has an 11" frame:
https://www.specialized.com/us/en/hotrock-24/p/154371
I found an older one locally on Craig's List for $75 but it looks like it's a 3X7, not a 1X - but that shouldn't be an issue.
Sunshine
Quoted: 10956 Post(s)
Liked 7,485 Times
My 12yo daughter has a 13"mtb with 26" wheels and a 44cm 650c road bike.
Both fit her well and she is about 4'9".
She used to have a 24" rigid hotrock and could still ride it, but it's obviously small.
Her current mtb fits well to the point thst she has control on the river bottom singletrack around us, so it definitely isnt too big.
My 8yo just started riding the 24" hotrock after we built it up with some better components. It fits her for paved riding and is too big for her on singletrack. She is 50" tall.
A suspension fork on a 24" entry level mtb is just unnecessary weight. It won't work well and will be heavy.
Just some general comments on frame size and bike options.
Good luck
Good luck
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
my advice would be to star him off right and teach him to choose his bike based on the need ,
guide him to understanding why bikes are made they way they are ,
show him the different styles of bike ,
and try to let him see the pros and cons of each choice ,
and maybe find a recycle a bike so he can build the bike up from a frame or non working bike so he understand what does what and why !!!!!!!
Bikes: 2017 Specialized Roubaix Comp, 2019 Cannondale Synopse 105 SE, 2015 Cannondale Quick 5, 2019 Specialized Fatboy
Quoted: 37 Post(s)
Liked 49 Times
At 12, I would expect he would be telling you what he wants based on what is socially acceptable in his peer group.
SuperGimp
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
+1 on looking into bikes with a 24" wheel size. I'd keep poking around Craigslist for something decent; many will come with knobby tires, but you could easily change them out for wide slick/hybrid tires that might be more appropriate for your intended use.
If you're willing to spend $300-$400, you can easily get into an entry-level bike of that size at a local bike shop, which is more likely to have 1x gearing rather than 3x.
Virgo
A 24" wheeled bike will likely be outgrown quickly. I recommend a smaller framed 26" wheeled bike, my daughter is 12 and fits a 15" frame fine at 5'1" and enough seatpost exposed for a rider 3-4" shorter.
Good luck
Good luck
I'm giving the owner of the $75 bike a call. In a couple of years he'll be big enough for my old bike with its 17.5" frame and 26" tires. We're not tinkerers but a trip to a co-op downtown and about $100 (new cassette and BB, drop the front derailleur and 22 and 42 tooth cogs) it should turn it into a decent (but still heavy) 1x8.
I tend to agree. We don't really need suspension, just sufficient gearing for climbing and good brakes from descending the hilly streets in the neighborhood to and from the trail head. My 5'3" wife has a Trek FX2 dual sport. It's sufficient but the 3X gives even her trouble. I'm about 5'11" and the only reason I have a hardtail is because I want to get off the packed trails and ride solo.
A 26" suited me fine until I realized that I was slightly too big for it. I'd have him ride my old bike but I feel like he needs an intermediary step from a single speed with 20" tires and a coaster brake. In fact, my old bike is probably a little too agile for him; it threw me OTB last September and I need to get it overhauled. See my previous comments on what my plans for it and my son are.
Well, the Craig's List guy never replied to my email. Tomorrow is father's day so I get to choose what we want to do. Guess where we're going? If you said to a LBS you'd have answered correctly!
Quoted: 1062 Post(s)
Liked 665 Times
My kids went through what seems like a gap in bike sizes, where they were too big for kids' bikes, but not big enough for adult sized bikes. A lot of parents I've talked to report the same problem. Some solutions carried a price premium, such as sizes tailored for women from specialty brands. It hardly made sense to pay a lot for bikes that would be outgrown in a few years. Or out of style as tastes change. We came up with a couple of solutions worth looking into:
1. Both of them had 24" wheel mountain bikes, but had run out of seat post. Amazingly, these bikes had both come with very short posts. We got roughly an extra year of use out of each bike by finding longer posts on eBay. And the bikes had come to us second-hand in the first place.
2. Keep a constant eye out for the small number of mainstream brands that make smaller frames. My spouse had a Fuji hybrid that she didn't really like but had a tiny frame, so it became a kids bike for a few years as each kid used it in succession. Also, there are some bikes in the "mountain bike" category that look surprisingly like hybrids if you put smooth tires on them, but have shorter frames.
3. The penalty of not getting to ride their first choice of bike was compensated by an assurance that they could get nice bikes when they got close enough to their adult stature.
4. I got them involved in the mechanical work required to provision their bikes. Getting familiar with a wrench will pay them back forever. And as an odd benefit, as they got older, they both realized that they would be heading to college eventually, and fancy bikes would be a liability. Plus they developed "hipster" sensibilities, and decided that they wanted cool bikes thrown together from old parts. Cross my fingers, but maybe our days of buying fancy new bikes are over.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 189 Times
Jump on that deal, $75 is terrific.
Hack
Quoted: 347 Post(s)
Liked 189 Times
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Not sure if my opinion helps but my son size is having this issue. Budged wasn't really an issue but we went with a Spec Hotrock. I know he will out grow it and we can just trade in. I am not thrilled to have him out grow and lose the value of the bike so fast but its important to have a bike he will enjoy riding and not fight to ride so I would rather drop the $$$ when he out grows. A good lbs is your friend for these type situations.
Budget is an issue here though. I don't want to drop good money after bad. Two years ago my wife used her American Express point to buy herself a medium sized 2017 Trek FX2 with a men's frame and the old style brakes but she's barely ridden it 10 times. At the time she felt its $500 price tag was still steep but since it was on credit card perks she justified it. When it came time for me to replace a 15 year old bike that I rode until the groupset wore out with another that cost $775 she thought it was "ridiculous."
Anyway, my son is just 3" shorter than she is at the moment. He's 12 and I'm expecting a growth spurt soon, so I'm thinking that he'll ride her bike next year. I'm hoping a little practice with less pressure on the local MUP will allow him to adjust from a single speed with a coaster brake.
My wife will essentially be out of a bike but as I said, we won't be dropping good money after bad. At the risk of sounding greedy, I'll be using the money saved to upgrade components on my new bike as they wear out instead. If our son builds his confidence and wants to try riding on trails with me, we'll take my old 26" MTB (which is also a medium that was ultimately too small for me) to a co-op and convert it to a 1x9.
simon D
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
6
07-30-13 01:45 PM
