Cannondale Hollowgram Si replacement suggestions?
Where would one buy alternative crank arms or crank sets for a bb3a BB?
I need to replace my crank arms with 165mm ones and I am having trouble locating anything online.
TIA
TIA
Expired Member
Quoted: 3674 Post(s)
Liked 5,435 Times
You can get adaptive bottom brackets that allow you to use a real Shimano crank. Another plus is that they actually thread together. https://wheelsmfg.com/bottom-bracket...ale-bb30a.html
Likes For shelbyfv:
Jedi Master
Pretty sure an Easton crank uses the same 30mm bottom bracket.
Sadly easton does not do 165
Any thoughts on this guy ? https://rotoramerica.com/collections...32581448499279
Also any idea what the difference is between
https://wheelsmfg.com/bottom-bracket...ano-black.html
and
I hope to put one of these on my synapse carbon
and
Jedi Master
and
and
Likes For kingston:
I think I'll skip the rotor crank option and go with wheel manufacturing + shimano ultegra instead.... 150gr is not going to make a difference for me. Or hope that someone will have cheap set of 165 hollowgrams on ebay
