Help with SunTour and 7-speed freewheel questions
Want to ride more!
Bikes: Marin for dirt, Cannondale for road
Folks;
This edit comes 24 hours later. Please page down to my new details about the SunTour.
I've appreciated all the help available on this forum.
Let me start by saying I've tried to do my homework before asking for help. My question is about putting a 7-speed freewheel on my old (1987) Cannondale. The bike came with a SunTour 6-speed freewheel and according to the catalog, an indexed shifter for the SunTour Sprint rear derailleur.
See https://www.vintagecannondale.com/year/1987/1987.pdf
Page down to the SR800, and you're looking at my bike 22 years ago.
According to the SunTour dealer catalog for 1987, the Sprint 9000 rear der could take a 7-speed freewheel, but there is no notation for the Sprint being 7-speed compatible. I'd like to have a tighter cluster of ratios near cruising speed, and have ordered the SunRace 7-speed freewheel from AEBike (very reasonably priced!), with a 13-14-15-17-19-21-24 set of cogs.
See https://www.wooljersey.com/gallery/v/...s/SunTour/1987
Sheldon Brown (RIP, and a wonderful source of arcane details) says that one can mix various manufacturer's equipment, with the proviso that the SunTour rear der may not work on Shimano-spaced 7-speed freewheels.
So here are the questions:
1. Will my old SunTour Sprint rear der shift over the full range of cogs on the SunRace 7-speed freewheel?
2. Are the SunRace cogs spaced so differently on the freewheel body that the SunTour derailleur and shifter can't move chain on and off them reliably?
3. Is there a way to adjust the SunTour rear shifter to convert from its current index setting to friction? It does have a wire bail handle at the base of the shift handle, but no apparent markings to show whether the shifter is set on friction or index.
4. If I need to go to a Shimano rear der as Sheldon notes may be required (grrr, hope not, love the black and gold colors), what model Shimano have others used successfully?
This has gotten lengthy and complex. Thanks in advance for any help.
Joe F
Joe F
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times
1. Yes
2. No. SunRace is probably Shimano-compatible 7-speed spacing (6 x 5.0mm spacings) while Suntour 7-speed is 3 x 4.8mm spacings between the larger cogs and 3 x 5.0mm between the smaller cogs. I have a bike with Sprint shifting and have used my Shimano 7-speed touring wheel in it. The shifting works fine but it also works a little better if I swap the 3 spacers between the largest cogs to 8-speed (which makes the Shimano cassette an exact match of Suntour spacing).
3. Probably. My Sprint shifter (from 1989 I think) has 6-speed index, 7-speed index, and friction settings. They are clearly marked on the housing. I forget how to change as I never do but I think you loosen the D-ring a little, rotate the housing, and tighten the D-ring back up.
4. If you go to Shimano rear der, you will also need Shimano rear shifter to match. Shimano and Suntour indexing isn't the same.
Want to ride more!
EDIT: The rear derailleur is a Sprint 9000. There are markings on the shifter (small notches, apparently representing positions, with two, three, and four notches per position).
New question: Anyone know what the various positions represent? Anyone have an old manual for this shifter and derailleur combination. I've looked at Technical Bulletin on Accushift problems, but need documentation on basic product configuration.
Thanks again in advance.
JF
"According to the SunTour dealer catalog for 1987, the Sprint 9000 rear der could take a 7-speed freewheel, but there is no notation for the Sprint being 7-speed compatible. I'd like to have a tighter cluster of ratios near cruising speed, and have ordered the SunRace 7-speed freewheel from AEBike (very reasonably priced!), with a 13-14-15-17-19-21-24 set of cogs."
JF
Quoted: 1858 Post(s)
Liked 664 Times
This is kind of jumping to the "can't it just be simple" point of view, and not to belittle the issues you are encountering, I've been there!
BUT, I use that Sunrayce cluster in friction-shift setups and get very good shifting, with a Shimano or SRAM chain. The shifting is good enough that I don't feel the need for indexing. I use Shimano 600 6207 series downtube friction shifters on this bike. Maybe you could go that way?
Road Fan
Road Fan
cycles per second
Quoted: 44 Post(s)
Liked 71 Times
I bought my stuff new but I doubt that I still have the manuals that came with. I will take a look, though.
I bet the three positions are the settings for 6-index, 7-index, or friction. I found an old Bicycling article on Sheldon Brown's site...
https://www.sheldonbrown.com/bridgest...oneRB11989.pdf
"The AccuShift lever features 3 settings:
UL, for index shifting with Sun-
Tour's narrow-spaced Ultra-7 freewheel;
F, for friction shifting ; and RE (regular),
for index shifting with most standardspaced
5- or 6-speed freewheels."
Want to ride more!
Wow! Right on target!
Folks;
Went to the garage where my steed awaits, and sure enough, the little marks on the shifter bezel say, respectively, UL, F, and RE.
Wonders never cease on this forum.
Many thanks to all!
Joe F
Many thanks to all!
Joe F
Want to ride more!
Folks;
Latest on this issue: The SunRace 7-speed freewheel from AE Bike looks pretty good! The teeth are ramped and angled, no doubt to help chain climb up onto a larger cog.
What's interesting so far is that the 13-24 freewheel is not, as advertized, a 13-14-15-17-19-21-24, but a 13-15-16-18-20-22-24. Not much different, but different still. I'm not going to take it up with AE Bike, who were quick shippers, and at $11.99, the freewheel was priced right!
In fact, I like the freewheel's appearance, since it has a "straight-block" look, less dished and more nearly evenly graduated between cogs.
--JF
--JF
Want to ride more!
How to change spacing on the SunRace freewheel?
Gonzo Bob;
First, many thanks for the very helpful reply. Now that I've got the SunRace freewheel in hand, how does one change the spacing between cogs?
Or is this one of those questions that requires an answer far too complex for the Bike Forums.
In any event, happy holidays and thanks again!
--JF
--JF
1. Yes
cycles per second
Quoted: 44 Post(s)
Liked 71 Times
The Sunrace 7-speed will work fine with the Sprint shifters. You will just have to fiddle with the barrel adjuster to get the best compromise.
https://aebike.com/product/falcon-hg-...w5007-qc30.htm
Interesting reading this thread. Makes me wonder.. if you access this link you find the listing of SIX gears... for a 7 speed. Found this everywhere on the net.
?? anyone have any experience with these freewheels?
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Email inquiry sez the missing one is a 22... does that make any sense? When I set in the details with my 2nd post the gear set pic showed.. now it doesnt on that post.
Doesnt a 15 look right per the pic?
Edit: the Shimano shows 14 - 16 - 18 - 20 - 22 - 24 - 28 Teeth.. this freewheel ad copy data is just wrong.. a 20 and 22 vs the 21 listed.
Needs a 15er >>>>>.
This is what I believe near ideal for me....
For 27 X 1 1/4 / 32-630 tire with 170 mm cranks
With Custom Sizes Cassette
52t 40t
14t 18.0 13.8 << mph @ 60 rpm
7.1 %
15 16.8 12.9
6.7 %
16 1 5.7 12.1
12.5 %
18 14.0 10.7
16.7 %
21 12.0 9.2
14.3 %
24 10.5 8.1
16.7 %
28 9.0 6.9
Needs a 15er >>>>>.
52t 40t
7.1 %
15 16.8 12.9
6.7 %
16 1 5.7 12.1
12.5 %
18 14.0 10.7
16.7 %
21 12.0 9.2
14.3 %
24 10.5 8.1
16.7 %
28 9.0 6.9
cab horn
Quoted: 42 Post(s)
Liked 26 Times
